Crown molding on vaulted ceiling - have the formulas, but getting the wrong angles - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 2 Weeks Ago   #1
Rep Power: 54 syc0path will become famous soon enoughsyc0path will become famous soon enoughsyc0path will become famous soon enoughsyc0path will become famous soon enoughsyc0path will become famous soon enoughsyc0path will become famous soon enough
Default Crown molding on vaulted ceiling - have the formulas, but getting the wrong angles
I'm trying to replace the cove molding around the hearth. As u can see from the pic, there should be a vertical molding running up the wall, a short horizontal piece running across the brick, and a longer piece running along the vaulted ceiling. I already got the angles for the vertical and short horizontal piece. But I'm having trouble making the correct angle for the short piece to vaulted ceiling corner.
I found the formulas below on Rake Crown Moulding Miter Angles . The spring angle of the cove molding is 45°. I calculated the roof pitch angle as such:
Height of south wall is 94”. Height of south side of hearth is 108.5”. Distance between them is 115”. So it’s 108.5-94=14.5”. Tangent is defined as opposite divided by adjacent, so that’s tan X = 14.5/115, and X = 7.18°
Trigonometric Crown Angle Formulas for Vertical Plane Crown Molding Angles (cathedral/vaulted ceilings/rake gables)
Crown Miter Angle = arctan (cos( Spring Angle) ÷ tan((180° - (Roof Pitch Angle * 2)) ÷ 2 ))
And, just like math class, here is where I show my work:
Miter angle = arctan (cos 45°) ÷ tan((180°-(7.2° * 2)) ÷ 2))
Miter angle = arctan (0.70710678118654752440084436210485) ÷ tan((165.6) ÷ 2))
Miter angle = arctan (0.70710678118654752440084436210485) ÷ tan(82.8)
Miter angle = arctan (0.70710678118654752440084436210485) ÷ 7.9158150883058268442674417219033
Miter angle = 35.264389682754654315377000330019 ÷ 7.9158150883058268442674417219033
Miter angle = 4.45°
Crown Bevel Angle = arcsin (sin( Spring Angle ) * cos((180° - (Roof Pitch Angle * 2)) ÷ 2))
Bevel Angle = arcsin (sin( 45°) * cos((180° - (7.2° * 2)) ÷ 2))
Bevel Angle = arcsin (0.70710678118654752440084436210485) * cos((165.6)) ÷ 2))
Bevel Angle = arcsin (0.70710678118654752440084436210485) * cos(82.8))
Bevel Angle = arcsin (0.70710678118654752440084436210485 * 0.12533323356430424537311875981651)
Bevel Angle = 5.08°
A couple things I thought of:
1) Am I following the correct order of the parentheses? I went thru it several times and I think I am.
2) Do these formulas assume that the molding is laying flat or pushed up against the fence of the miter saw? Other formulas on the same page assume the molding is laying flat. I also tried pushing it against the fence, but that didn't work either.
3)The angle from the wall to the vaulted ceiling is technically 97.2°. So I tried that rather than 7.2°, but that didn't work either.
By experimenting, it looks to me like a miter angle of 25° and a bevel of 30° is pretty close. And that is nowhere near the numbers I've got from any of the things I've tried w/ the formulas.
Old 2 Weeks Ago   #2
Default Re: Crown molding on vaulted ceiling - have the formulas, but getting the wrong angle
BTW, the original moldings were cut as if the ceiling was flat, and then they just caulked the hell out of them to fill the gap. I'm putting up stained moldings, so I can't get away w/ that!
Old 2 Weeks Ago   #3
Notloudenuf's Avatar
NCSQ Founding Member
Rep Power: 132 Notloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really nice
Could you try mathway to help you solve this problem???
https://www.mathway.com/Trigonometry
I'm curious now but I have no helpful answers.
Old 2 Weeks Ago   #4
FordEscape's Avatar
Rep Power: 42 FordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of light
Have you considered hand-coping rather than miter-saw cut joints? IMHO it's easier to get the angle and profile correct for each joint with a scribe and with minimal practice you'll get much better-fitting joints for the long-haul. Yeah, I'm olde skoole.
2014 Ford Escape ~ OEM SYNC Non-Sony 8" Touchscreen HU
DSP & Amps by JBL MS series ~ Midrange & Tweeters by HAT Legatia ~ Midbass & Subs by SI TM/BM
FordEscape is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #5
I have been coping the inside corners for the base moldings, but this is for an outside corner.
Old 2 Weeks Ago   #6
Mathway gave me the same answers. So at least it looks like I'm doing the parentheses in the right order. Maybe the formula is just wrong??
Old 1 Week Ago   #7
ryanr7386's Avatar
Rep Power: 84 ryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enough
Scraps, play with the miter until it fits if all else fails.
1994 Ford Thunderbird SC System - Undecided on HU, Helix DSP Pro, ADS Amps & Speakers. On Going Build
ryanr7386 is offline   Reply With Quote Quick reply to this message
Old 1 Week Ago   #8
BigAl205's Avatar
Diyma Ninja
Rep Power: 589 BigAl205 has a reputation beyond reputeBigAl205 has a reputation beyond reputeBigAl205 has a reputation beyond reputeBigAl205 has a reputation beyond reputeBigAl205 has a reputation beyond reputeBigAl205 has a reputation beyond reputeBigAl205 has a reputation beyond reputeBigAl205 has a reputation beyond reputeBigAl205 has a reputation beyond reputeBigAl205 has a reputation beyond reputeBigAl205 has a reputation beyond repute
Is the distance between the two measured level (parallel to the floor) or is it measured diagonally across the ceiling?
BigAl205 is online now   Reply With Quote Quick reply to this message
Old 1 Week Ago   #9
Rep Power: 0 rexhenly will become famous soon enoughrexhenly will become famous soon enoughrexhenly will become famous soon enoughrexhenly will become famous soon enoughrexhenly will become famous soon enoughrexhenly will become famous soon enough
https://www.youtube.com/watch?v=9QpnWgGNtOk
rexhenly is online now   Reply With Quote Quick reply to this message
Old 1 Week Ago   #10
BigAl205's Avatar
Diyma Ninja
Originally Posted by rexhenly View Post
That's only for flat ceilings, not the sloped cut that the OP has
Old 1 Week Ago   #11
Rep Power: 0 nhtunes will become famous soon enoughnhtunes will become famous soon enoughnhtunes will become famous soon enoughnhtunes will become famous soon enoughnhtunes will become famous soon enoughnhtunes will become famous soon enough
First you have to do a bong hit and it will all come together. Just like my sub box.
Create a short piece 12" and another the length of that short return. Just use a normal outside corner 90 degrees-2-45's. With the long side going toward the peak slide until the bottom of the short piece hits the brick. (The ceiling looks like it is straight?) If it looks right redo it with the correct lengths.
nhtunes is offline   Reply With Quote Quick reply to this message
Old 1 Week Ago   #12
In this case here is the difference.
If its parallel to the floor the angle is the 7.1863 degrees that he came up with
If its measured diagonally (hypotenuse) the angle is 7.2435 degrees
Old 1 Week Ago   #13
Yeah that's plan. Unfortunately, changing 1 angle also changes the fit of the other. So I can't just make a 90° corner and then change the bevel until I get the 7.2° pitch. Becuz as soon as I change the bevel, the 90° corner isn't 90° anymore. So it takes A LOT of trial and error. It took me about 30 cuts just to get in the ballpark (miter angle of 25° and a bevel of 30°)
I measured it parallel to the floor.
Old 1 Week Ago   #14
Can't get away w/ that becuz the other side of the short piece is an inside 90° w/ the long vertical piece. So if I tilt the short piece up 7.2°, that will screw up the other corner.
Old 1 Week Ago   #15
the other piece that creates the inside corner is a simple 90.
you will have to be creative if you are going to cope into the wall and match the molding.
Old 1 Week Ago   #16
So I think what u'r saying is that I should make the outside corner as a simple 90. Then I can tilt the short piece by 7° so the long piece will match the pitch of the ceiling.
This creates 2 problems, both of which can be solved:
1) the short piece will have a small gap where it should touch the ceiling (a gap that can be caulked).
2) The inside corner will be wrong, but that can be remade as a cope adjusted to account for the pitch of the ceiling.
In fact, I can set my miter to 7° to cut a scrap piece, and that will provide a good pattern for the cope.
This is a lot faster than the trial and error method!
Old 1 Week Ago   #17
Get the top of the molding to fit the ceiling. The ceiling is the only continuous plane that will work. Ignore the angle of the brick, the molding will slide up to and hit at its bottom (you may have to back cut so it is a good fit) stare at the diagram I posted and it will come to you. I don't write well enough to explain.
Old 1 Week Ago   #18
BlackHHR's Avatar
Shop Ratt
Hybrid Audio/ Audiotec Fischer USA
Logistics Manager
Rep Power: 59 BlackHHR will become famous soon enoughBlackHHR will become famous soon enoughBlackHHR will become famous soon enoughBlackHHR will become famous soon enoughBlackHHR will become famous soon enoughBlackHHR will become famous soon enoughBlackHHR will become famous soon enough
I owned a interior mill work company. Installed mill work work for 25 before retiring and working for Hybrid.
Crown molding is stupid easy to cut. On a slide saw, miter box or over head radial arm saw the angles are marked on the bottom left right swing and on the back of the left right tilt.
If you have conventional crown, ( home depot builder grade). The back is tilted to the 33.9 ( clearly marked ) and the bottom swing is 31. something I do not remember. The are also indented. These two numbers will turn a square 90 degree corner.
For a the inside of a trey ceiling with 22.5 turns, the tilt and swing are 15 degrees . Also clearly marked and indented on the saw.
Lay the crown down flat, with the bottom facing you. Do not bed it in the saw up side down and backwards. That is so 1960 to do that.
You will not be able to make the transition from the rake of the ceiling to the out side corner. You will have to make a small turn first around the corner, then turn up the ceiling. Like exterior cornice is done. We also installed cornice on high end homes in Metro Atlanta.
Example of transition.
Below is pictures of what I was doing 10 years ago.
We also have more recent pictures from a few years back, but they are really dark stained work and are very hard to see the cuts and angles. That would be the last image in the volley.
Denon DCT-1 / Denon DSV-1
Helix DSP PRO MKII
Brax MX4 >> Left channel L1ProR2, L3SE, L8SE
Brax MX4 >> Right channel L1ProR2, L3SE, L8SE
Brax MX2 >> C15SW-D2
BlackHHR is offline   Reply With Quote Quick reply to this message
Old 1 Week Ago   #19
ryanr7386's Avatar
Nice!
Old 1 Week Ago   #20
Honestly, I thought adding the transition piece was just a lazy way of doing it, and that if u had the right formula, u could calculate the correct angles to do it in a single joint.
But after your comment and some additional research, I realize it's not that simple. It can be done, but it involves ripping the molding that goes on the flat part of the ceiling to change the spring angle to account for the slope of the ceiling. I don't have the equipment, the skill, or the experience to do that.
So I'll trying coping the inside corner and tilting the short piece that runs along the side of the brick. Given that it's only a 7° angle, the gap at the top of the short molding should be pretty small. If I can't get that to work, I'll do the transition piece.
Thanks for your help!
Old 5 Days Ago   #21
Rep Power: 0 grinditout will become famous soon enoughgrinditout will become famous soon enoughgrinditout will become famous soon enoughgrinditout will become famous soon enoughgrinditout will become famous soon enoughgrinditout will become famous soon enough
That man knows who Randall Brothers is. Also, mostly just grab some scrap, and play around, when I have been doing crown lately, I put little triangles in every so often and 2 where I land my joints.
grinditout is offline   Reply With Quote Quick reply to this message
