car heater working intermittently - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 05-26-2009   #1
60ndown's Avatar
Rep Power: 197 60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute
Default car heater working intermittently
mostly not working nowdays.
toyota matrix.
fuses all look good,
water is full
what next?
Old 05-26-2009   #2
benny's Avatar
Rep Power: 131 benny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nice
Default Re: car heater working intermittently
Jinkies. Coolant level isnt going down at all? I dont know how those are set up, could you have a blockage to the heater core? What do you need heat for anyway?
benny is offline   Reply With Quote Quick reply to this message
Old 05-26-2009   #3
GlasSman's Avatar
Rep Power: 166 GlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enoughGlasSman will become famous soon enough
Check the squirrel cage fan.
Beyond that it's major......heater core.
---Custom fabricated speaker baffles and templates---
GlasSman is offline   Reply With Quote Quick reply to this message
Old 05-26-2009   #4
ocuriel's Avatar
Rep Power: 150 ocuriel will become famous soon enoughocuriel will become famous soon enoughocuriel will become famous soon enoughocuriel will become famous soon enoughocuriel will become famous soon enoughocuriel will become famous soon enough
Could be 1 of many things.
Air door actuator, thermostat, heater control valve, etc.
ocuriel is offline   Reply With Quote Quick reply to this message
Old 05-26-2009   #5
chad's Avatar
DIYMA Psychopath
Rep Power: 914 chad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond repute
X2 agreed
Old 05-26-2009   #6
Mack's Avatar
Rep Power: 120 Mack will become famous soon enoughMack will become famous soon enoughMack will become famous soon enoughMack will become famous soon enoughMack will become famous soon enoughMack will become famous soon enough
Is your fan and AC working, or just not blowing hot air?
RIP '99 Ranger.......
'14 Focus - AudioControl LC6i, PA4002, IDQ 12 v2
Mack is offline   Reply With Quote Quick reply to this message
Old 05-26-2009   #7
60ndown's Avatar
ac and heat = nothing,
the fan makes no sound, doesnt seem to be spinning (comes on occasionally), guess ill get a screwdriver out and see if i can find anything obvious ........
Old 05-26-2009   #8
60ndown's Avatar
gets way down to leik 60 in the mornings......
Old 05-26-2009   #9
benny's Avatar
fans seized up possibly.
Old 05-26-2009   #10
ocuriel's Avatar
So the blower doesn't work at all? Does it only work on high?
Old 05-26-2009   #11
IBcivic's Avatar
Back Yard Installer
Rep Power: 150 IBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really niceIBcivic is just really nice
could be the module that controls the fan's speed.... i've had that happen to me in -30 weather....no fun at all...
IBcivic is offline   Reply With Quote Quick reply to this message
Old 05-26-2009   #12
Rep Power: 125 Foglght will become famous soon enoughFoglght will become famous soon enoughFoglght will become famous soon enoughFoglght will become famous soon enoughFoglght will become famous soon enoughFoglght will become famous soon enough
If you haven't already tried this:
Turn the fan on to all the different speeds (if you have numbers) and see if it responds to only a few, if only 1 setting, or possibly none. Figure that out first.
Then jumper the always hot Wire to the blower motor. If that works, you know the motor is ok, and its probably the blower switch. If the jumper doesn't work, check to see if there is a clear ground (the beeping continuity test). If that is ok, check for 12v at always hot wire. If all of that checks out, you need a new blower motor.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Foglght is offline   Reply With Quote Quick reply to this message
Old 05-26-2009   #13
fourthmeal's Avatar
DIYMA Been here long time
Rep Power: 913 fourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond repute
Did a little research and noticed no major occurances of this on a Matrix. Not knowing what year you have I guessed an 02 and then searched + and - 2 years from there, with all engine packages picked.
Only the Celica really has a problem w/ no heat, and it comes from the heater core failing. You can tell because there will be no flow through the heater core.
No other problems common to the Matrix. The Celica is the one w/ the issues.
Oh yeah it helps me greatly to know exactly what model and what year we're talking.
2017 Colorado just starting
fourthmeal is online now   Reply With Quote Quick reply to this message
Old 05-26-2009   #14
Boostedrex's Avatar
DIYMA Sneetch
Zuki Audio
Sales and Customer Service
Rep Power: 172 Boostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really nice
I'm with this guy.
MECA Judge for California
Team DIYMA, Zuki Audio, and Stereo Integrity member
Boostedrex is offline   Reply With Quote Quick reply to this message
Old 05-26-2009   #15
Fixtion's Avatar
Rep Power: 137 Fixtion has a spectacular aura aboutFixtion has a spectacular aura aboutFixtion has a spectacular aura aboutFixtion has a spectacular aura aboutFixtion has a spectacular aura aboutFixtion has a spectacular aura aboutFixtion has a spectacular aura aboutFixtion has a spectacular aura about
wear a jacket.
2011 Hyundai Elantra AMT
STOCK
Fixtion is offline   Reply With Quote Quick reply to this message
Old 05-26-2009   #16
Mack's Avatar
I'll agree as well. My "resistor pack" on my Ranger went out, and only the slowest and fastest speeds worked. The resistors on the middle speeds opened up, so no Power to the motor. ~$20.00 dealer part for me.
If this doesn't seem plausible, I'd break out the DMM as well.
Old 05-27-2009   #17
Aaron'z 2.5RS/WRX's Avatar
Rep Power: 284 Aaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond repute
If the fan works on HI, you need a blower motor resistor pack... If you have fan it's likely the diverter... All the info you need can be had on MO. c o m OR GenVibe. c o m
I'm on Genvibe with my DD Vibe... Same as the Matrix..
Aaron'z 2.5RS/WRX is offline   Reply With Quote Quick reply to this message
Old 05-27-2009   #18
mjgonegm's Avatar
Rep Power: 0 mjgonegm can only hope to improvemjgonegm can only hope to improvemjgonegm can only hope to improvemjgonegm can only hope to improvemjgonegm can only hope to improve
Dude THATS HOT !
mjgonegm is offline   Reply With Quote Quick reply to this message
Old 05-27-2009   #19
chad's Avatar
DIYMA Psychopath
Originally Posted by mjgonegm View Post
Dude THATS HOT !
no shit! Us Illinois people are in shorts, sandals, and wife-beaters!
Old 05-27-2009   #20
94VG30DE's Avatar
Rep Power: 134 94VG30DE will become famous soon enough94VG30DE will become famous soon enough94VG30DE will become famous soon enough94VG30DE will become famous soon enough94VG30DE will become famous soon enough94VG30DE will become famous soon enough94VG30DE will become famous soon enough
Ditto. If I am hearing the symptoms correctly (only one blower speed) I would be looking at blower motor resistor as my first test.
94VG30DE is online now   Reply With Quote Quick reply to this message
Old 05-27-2009   #21
60ndown's Avatar
it either works or doesnt, if its not, there is no fan at any speed.
im guessing its a loose Wire in teh dash.
imma look in there eventually.
Old 05-28-2009   #22
Intermittent problem cat says you might have a loose ground somewhere, or a bad blower motor.
Old 05-28-2009   #23
fourthmeal's Avatar
dude you still haven't told me what year and model. I can't do much research without it. I know it is a Matrix but what trim?
Old 05-28-2009   #24
60ndown's Avatar
lol cat?
Old 07-10-2009   #25
60ndown's Avatar
after removing hu, and a few dash parts to look for loose Wire or anything obvious etc i had no luck.
but in the passenger foot well under dash there was.... is a shiny box with a sticker that sais 'car computer' i thumped it with my fist, fan came on thumped it again speed increased third time third improvement
car now has normally functioning ac and heat
who knows why?
