Is it safe to drive without a sway bar?? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 10-10-2010   #1
Rep Power: 95 Vital will become famous soon enoughVital will become famous soon enoughVital will become famous soon enoughVital will become famous soon enoughVital will become famous soon enoughVital will become famous soon enough
Default Is it safe to drive without a sway bar??
So my rear sway bar broke - common thing in 2007+ Altimas according to Nissan's forums but Nissan doesn't seem to give a fukk so no recall.
It's sunday night, everything is closed, tomorrow is Columbus day - everything is closed as well.
I'm all packed for 1,000 trip tomorrow morning and now this sway bar shit happens. I know u can drive around for sometime without out but is it safe to drive 1,000miles at 65-75mph without a sway bar??
Vital is offline   Reply With Quote Quick reply to this message
Old 10-10-2010   #2
t3sn4f2's Avatar
Rep Power: 225 t3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to all
Default Re: Is it safe to drive without a sway bar??
I certainly would not. Have you at least removed it so the broken ends don't get caught on something?
Old 10-10-2010   #3
Originally Posted by t3sn4f2 View Post
I certainly would not. Have you at least removed it so the broken end doesn't get caught on something?
I found out about it from pepboys retard while doing getting my oilchange done. I asked him to remove which he did.... by CUTTING MY STABILIZER BAR which basically holds a sway bar. Apparantly he had a hard time taking the bolt out so cutting endlink (stabilizer bar) seemed like the right thing to do to him.
Here's some pics btw.
And before anyone blames Stillen's sway - don't. There are NUMEROUS complains on NissanClub forum from Altima owners on this same issue. Mostly stock sway bars brake, i think i'm the first one with broken stillen bar.
All brake in the same exact spot thou.
Old 10-10-2010   #4
Rep Power: 129 Foglght will become famous soon enoughFoglght will become famous soon enoughFoglght will become famous soon enoughFoglght will become famous soon enoughFoglght will become famous soon enoughFoglght will become famous soon enough
You are perfectly safe to drive without a rear sway bar. Car will understeer quite a bit more. Might feel a little goofy when cornering, like driving a boat.
I'd put the stock one back on though and order a new link.
And you are also the first person who used the word BRAKE when you should have used BREAK. Always see it the other way around.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Foglght is offline   Reply With Quote Quick reply to this message
Old 10-10-2010   #5
Austin's Avatar
Rep Power: 123 Austin has a spectacular aura aboutAustin has a spectacular aura aboutAustin has a spectacular aura aboutAustin has a spectacular aura aboutAustin has a spectacular aura aboutAustin has a spectacular aura aboutAustin has a spectacular aura aboutAustin has a spectacular aura aboutAustin has a spectacular aura aboutAustin has a spectacular aura about
So what piece broke? its hard to tell. Was it the small one or the bigger red one? they both look like they were cut, but the small one more.
Austin is offline   Reply With Quote Quick reply to this message
Old 10-10-2010   #6
ItalynStylion's Avatar
Stereo Clarity
Rep Power: 138 ItalynStylion will become famous soon enoughItalynStylion will become famous soon enoughItalynStylion will become famous soon enoughItalynStylion will become famous soon enoughItalynStylion will become famous soon enoughItalynStylion will become famous soon enough
The red one is the sway that broke I believe and the endlink is what was cut.
As long as it's not dangling it's fine to drive on. The car will feel a bit funny but it's ok. Just don't drive it like you stole it and you'll be fine. Lots of off road guys don't have any sway bars at all.
ItalynStylion is offline   Reply With Quote Quick reply to this message
Old 10-10-2010   #7
Red is sway bar black is endlink (stabilizer bar)
Old 10-10-2010   #8
Rep Power: 165 King Nothing will become famous soon enoughKing Nothing will become famous soon enoughKing Nothing will become famous soon enoughKing Nothing will become famous soon enoughKing Nothing will become famous soon enoughKing Nothing will become famous soon enough
perfectly safe with a little more vigilant driving
disgusted..........
King Nothing is offline   Reply With Quote Quick reply to this message
Old 10-10-2010   #9
Yeah, sure
If it were me I'd load that car down and drive 70 mph up to 95 mph and look for twisty roads
Just think of the cool post you could make
PS take the broken parts with you to place at the scene , just in case you want to sue l8r
Old 10-10-2010   #10
mjgonegm's Avatar
Rep Power: 0 mjgonegm can only hope to improvemjgonegm can only hope to improvemjgonegm can only hope to improvemjgonegm can only hope to improvemjgonegm can only hope to improve
yeah Just drive slow and don't take corners hard and under steering will be a big issue
mjgonegm is offline   Reply With Quote Quick reply to this message
Old 10-10-2010   #11
60ndown's Avatar
Rep Power: 201 60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute
the break/cut looks very clean to me,
you sure the guy at pepboys wasnt trying to get himself a little work?
if it had 'fatigued' over time, wouldnt there be oxidation in the break/cut?
call me a cynic.
[/QUOTE]
Old 10-10-2010   #12
anti-sway bar is the red thing in the picture
Old 10-10-2010   #13
60ndown's Avatar
doh!
yea that ^ things worn out
Old 10-10-2010   #14
Rep Power: 91 mayhem will become famous soon enoughmayhem will become famous soon enoughmayhem will become famous soon enoughmayhem will become famous soon enoughmayhem will become famous soon enoughmayhem will become famous soon enough
You're fine to drive it that way, watch the ramps...the car will not handle as well and if you get to the limit it'll bite you hard.
No replacement for displacement.
mayhem is offline   Reply With Quote Quick reply to this message
Old 10-11-2010   #15
Rep Power: 192 sqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the rough
Sway bar makes that end of the car lose traction sooner, in a corner. That means the rear of the car will stick better, causing the front to push more. It will under steer more than it did before, roll more too. You can drive it long as nothing is falling off, just stay away from abrupt turns and note it might not like crosswinds as much.
They don't want to fix it? What did they do hire American executives to run the company or what....
Old 10-14-2010   #16
PSYKO_Inc's Avatar
Rep Power: 134 PSYKO_Inc will become famous soon enoughPSYKO_Inc will become famous soon enoughPSYKO_Inc will become famous soon enoughPSYKO_Inc will become famous soon enoughPSYKO_Inc will become famous soon enoughPSYKO_Inc will become famous soon enough
It will be fine to drive. Many cars do not even have rear sway bars from the factory. Also, sway bar and stabilizer bar mean the same thing. The part that got cut was the endlink.
97 Chevy S-10 Ext. Cab 4.3/T56 swap bagged & shaved
CarPC - Peerless CSX 851123 - Blaupunkt VC100 w/passives
Audio system rebuild in progress...
PSYKO_Inc is offline   Reply With Quote Quick reply to this message
Old 10-14-2010   #17
ryan s's Avatar
Rep Power: 391 ryan s has a reputation beyond reputeryan s has a reputation beyond reputeryan s has a reputation beyond reputeryan s has a reputation beyond reputeryan s has a reputation beyond reputeryan s has a reputation beyond reputeryan s has a reputation beyond reputeryan s has a reputation beyond reputeryan s has a reputation beyond reputeryan s has a reputation beyond reputeryan s has a reputation beyond repute
The guy working on it cut the endlink to remove that end of the sway bar...the sway bar itself broke first. Plenty of people chop the endlink in half, especially if it requires an Allen key to fit in the center shaft to hold it while the nut is turned (Honda )...
But yeah...x7 or whatever for driving it as-is...it's just more body roll and understeer. The DX version of my car didn't have a rear sway from the factory and I still see those cars on the road, driving fine
'11 Accord Coupe with Premium Audio. Decent. System in planning stage...
"Plan for the best, EQ for the rest" - Zaph
ryan s is offline   Reply With Quote Quick reply to this message
Old 10-14-2010   #18
ogg
ogg's Avatar
Rep Power: 123 ogg will become famous soon enoughogg will become famous soon enoughogg will become famous soon enoughogg will become famous soon enoughogg will become famous soon enoughogg will become famous soon enough
It kind of depends on the particular car but he should be fine. Crosswinds might be a bitch, though. My Impreza used to get blown all over the place with the dinky factory sway bar but when I upgraded to a bigger bar it was rock solid.
ogg is offline   Reply With Quote Quick reply to this message
