Audible: Capable of being heard; loud enough to be heard; actually heard. Physics - The Science of matter, energy, motion and force that can be actually heard!!
XR = Extended Range Series........M = Magnesium Alloy
The XR transducers uses a Magnesium Alloy Cone Using a Special Proprietary process during cone production. This process is used to combat cone resonances/breakup at high frequencies PLEASE NO PLAYING WITH THE CONES!
XR3M: 3” Magnesium/Aluminum Alloy Super wide-band transducer.
The XR3M Super Wide-Band 3" Transducer with Rosewood Phase Plug or the XR3M-LE with Ironwood phase plug. The XR3M is a High Resolution and Detail unit, with the right amount of warmth, mid-range is sweet and smooth, Highs are very extend and natural. Lower mid-range is very full and full of body, making them sound like a larger driver.
Simply put there is no other Mid/bass transducer for the mobile audio market like the XR6.5M. Bottom line is, the XR6.5M is the most versatile car audio mid/bass in production.
The XR6.5M is an all-in-one 3-way unit. Yep it is a Mid-bass/Mid-range/Tweeter all in one, just pick your sub.
It can be use in your traditional 2-way, just pick your tweeter.
The XR6.5M can be use as a stand alone mid-bass unit in a traditional 3-way, just pick your mid-range and tweeter.
Yes, and do all the above at a truly reference level.
Revc= 4.000 Ohm
Fo= 73.630 Hz (At the drivers F3)
Sd= 13.685m M?
Krm= 76.979m Ohm
Erm= 0.382
Kxm= 722.917m H
Exm= 0.082
Vas= 3.135 Gal
Cms= 446.208u M/N
Mmd= 8.032m Kg
Mms= 8.953 g
BL= 4.611 T��
Qms= 5.501
Qes= 0.843
Qts= 0.731
No= 0.688 %
SPLo= 91.521 dB
The AR3K Ultra Wide-Band 3" Super Wide-Band uses a large woven Kevlar cone. The AR3K are quite natural and neutral with open and transparent yet smooth mid-range with great detail and dynamics with the right amount of warmth. Highs are extend, but not quit to the level of the XR3M. Which for some users will work better. Like for the users who are going A-pillar mounting on-axis, with the XR3M you may found yourself wanting to cut the very top end around 16khz or so. With the AR3K it will be a little smoother.
But as always it will come down to angles and installations and a little proper tuning
AR6K: 6.5” Kevlar cone mid/bass transducer:
This is a driver to can do it all. Midrange is open and detailed, mid-bass is fast and control. With is stiff and light weight Kevlar cone the AR6K well please just about anyone’s music taste. With a true 3db down open air tested Fs of 57hz the AR6K plays low and deep. Attack and Decay is outstanding, impact is great. With the high sensitivity and great power handling dynamics is superb.
Revc= 4.000 Ohm
Fo= 56.910 Hz
Sd= 13.685m M?
Krm= 95.345m Ohm��
Erm= 0.363
Kxm= 661.728m H
Exm= 0.088
Vas= 5.603 Gal
Cms= 797.576u M/N
Mmd= 8.885m Kg
Mms= 9.806 g
BL= 4.821 T��
Qms= 10.129
Qes= 0.603
Qts= 0.569
No= 0.627 %
SPLo= 89.988 dB
MSRP: AR3K---------$450
MSRP: AR6K---------$450
MSRP: AR Duo-------$900
GF6.5: 6.5” Glass Fiber mid/bass transducer:
Based of the XR and AR 6.5" transducer's motor, but with an outstandingly stiff, but light weight Glass fiber cone the GF6.5 is an outstanding choice for anyone looking for a high performance 6.5” to use as a mid/bass unit in a 2 way or as mid-bass in a 3 way setup. The GF6.5 will delivery the goods.
With its shallow mounting depth, coming in at less then 3” it can be mount in place where other high-end drivers can not and still match or exceed their performance.
Revc= 4.000 Ohm
Fo= 77.716 Hz (At the drivers F3)
Sd= 13.685m M?
Krm= 140.823m Ohm
Erm= 0.324
Kxm= 519.355m H
Exm= 0.105
Vas= 2.995 Gal
Cms= 426.293u M/N
Mmd= 8.918m Kg
Mms= 9.838 g
BL= 4.537 T��
Qms= 2.051
Qes= 0.933
Qts= 0.641
No= 0.551 %
SPLo= 89.431 dB
MSRP: $315 per pair
PP6.5: 6.5” Poly cone transducer:
One word impactful, ok it’s not a word! The PP6.5 is smooth and warm thru its midrange. Mid-bass is fast and control and yep impactful.
Revc= 4.000 Ohm
Fo= 75.556 Hz (True 3db down)
Sd= 13.685m M?
Krm= 106.497m Ohm
Erm= 0.357
Kxm= 754.397m H
Exm= 0.079
Vas= 2.824 Gal
Cms= 401.977u M/N
Mmd= 10.118m Kg
Mms= 11.038 g
BL= 4.929 T��
Qms= 5.390
Qes= 0.863
Qts= 0.744
No= 0.517 %
SPLo= 89.152 dB 1w/1m
MSRP: $315 per pair
For Diyma pricing and question please PM and me email directly.
Tested Specs for the XR3M-LE by Erin Hardison using Woofer Tester 2 for impedance sweep and SoundEasy for On/Off-Axis Measurements:
Impedance:
Fs = 166hz
Qts = 1.06
Le = 0.0606 mH (taken at 1khz)
Re = 3.38 ohms
Qms = 8.3495
Qes = 1.2256
Note: In picture below, title says "Rosewood" but this is the Ironwood Phase Plug version.
Frequency Response on a 66x81" Baffle:
Orange = 0 deg
Blue = 15 deg
Pink = 30 deg
Green = 60 deg
Burgundy = 90 deg
Something truly Melodic this way comes!!!
This will be very helpful to provide to those who hear a demo of one of the cars that have chosen to use these drivers and want to know more about them. Thank you also for your tireless dedication to your customers and to providing innovative products that has generated excitement in the industry.
Thank you Jason!!! Individuals like yourself is why I do my best to keep it going. You guy/gals who have a true passion for music and great sound. I have some new products coming down the line that I think you all will truly enjoy quite a bit.
Now if I can only get a system done for myself.
Will it be a 2"? Man I'll never run anyone elses drivers as long as you keep the good stuff coming. That's why I ordered another X-Soul2 set for backup. Would like to shoehorn a 3" in the dash but that's iffy at best
11 Ram Quadcab HEMI...80prs...Audible Physics Arian...H-Audio x2...Fi x10...PPI PC1000.1...Mosconi One 120.4...One comfortable tow rig
HU, Amps, Drivers. 2011 MECA Modified Street Georgia State Champion 2011 MECA Modified Street World Finals Runner-up Team DiYMA - 2011, 2012 MECA Team of the Year 2012 MECA Modified Street Georgia State Champion
You guys are killing me , An 8" is coming just have a few other drivers to finish up first. Then the 8". Hmmmm XR4M, hmmmmm might have to think about that one, need to talk designer/builder and see what we can come up with.
