Old 08-12-2012   #1
Doc ProMos's Avatar
Rep Power: 17 Doc ProMos will become famous soon enoughDoc ProMos will become famous soon enoughDoc ProMos will become famous soon enoughDoc ProMos will become famous soon enoughDoc ProMos will become famous soon enoughDoc ProMos will become famous soon enough
Default Restoration Log of a PPI Black ProArt 25
Well whoever had this amp definitely did a number on it.... not only is the chassis scraped and dinged to hell, but it looks like someone got a wonderful idea to clean it with a solvent.... then to make matters worse they tried to repair it.... 😱.... so here's what I'm starting off with, after most of the TIM has been cleaned off...
thanx for checking it out.... I'll update periodically.... Keith
Doc ProMos is offline   Reply With Quote
Old 08-12-2012   #2
Prime mova's Avatar
Rep Power: 26 Prime mova will become famous soon enoughPrime mova will become famous soon enoughPrime mova will become famous soon enoughPrime mova will become famous soon enoughPrime mova will become famous soon enoughPrime mova will become famous soon enough
Send a message via Yahoo to Prime mova
Keith, can't wait to see your restoration job ...are you going to do the screening yourself or farm out?
"Life is what happens when your making other plans" John Lennon
Prime mova is offline   Reply With Quote
Old 08-12-2012   #3
Doc ProMos's Avatar
Default Re: Restoration Log of a PPI Black ProArt 25
The screening I will farm out to someone....the sooner I locate someone the better....keith
Old 08-12-2012   #4
Rep Power: 33 spooney will become famous soon enoughspooney will become famous soon enoughspooney will become famous soon enoughspooney will become famous soon enoughspooney will become famous soon enoughspooney will become famous soon enough
Very interested to see how this turns out. I just bought a PPI A300 and its in horrible physical and functional shape. I can get her going again but the cosmetics I'm not always so great with. Do you know of a person who can or has recreate the Art series graphics? I considered stripping the heatsink to bare aluminum and having it polished.
spooney is offline   Reply With Quote
Old 08-12-2012   #5
Doc ProMos's Avatar
I am about to set up a silk screener to do some amps, usually the initial cost is the expensive part.... I'll let you know when I get it set up.... also another option is to buy a fried amp with a good chassis and swap it out.... Keith
Old 08-31-2012   #6
Doc ProMos's Avatar
Finally have gotten around to doing a little work... I want the restore to be as factory as possible and needed to replace the part BYW29F-200 and found a supply of them since it's been updated... so here is the board after the defective parts had been removed and the CB cleaned up a little from someone else's handy work...
All four will be replaced even though it appeared only one had been broken and the leg re-soldered...
Old 08-31-2012   #7
SaturnSL1's Avatar
Rep Power: 34 SaturnSL1 will become famous soon enoughSaturnSL1 will become famous soon enoughSaturnSL1 will become famous soon enoughSaturnSL1 will become famous soon enoughSaturnSL1 will become famous soon enoughSaturnSL1 will become famous soon enough
Why would you wipe away the art?!
Some people suck
SaturnSL1 is online now   Reply With Quote
Old 08-31-2012   #8
PPI-ART COLLECTOR's Avatar
Diyma Ninja
BMI Inspections
Rep Power: 110 PPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond reputePPI-ART COLLECTOR has a reputation beyond repute
Subscibed with intrigue.
Great to see someone else is seriously restoring these treasures.
Keep up the good work.
Note-Looks like the cap on the left in pic exhibits evidence of leaking.
Bret
PPI-ART COLLECTOR
EVERYTHING LOUDER THAN EVERYTHING ELSE-Meat Loaf
TEAM GRIZZ
PPI-ART COLLECTOR is offline   Reply With Quote
Old 08-31-2012   #9
Doc ProMos's Avatar
I agree and since it's on the table i am gonna recap it also... i have been looking through your restoration thread frequently Bret... it's what got me wanting to chronicle one myself...
Old 09-01-2012   #10
Looking good so far man. I got my A300 going again. Still kinda ugly outside though. Hope you don't mind if I post a few pics. If its a problem I will remove them.
Before repair:
After replacing the toasted power supply fets and gate resistors:
Old 09-02-2012   #11
Doc ProMos's Avatar
Nice work...
Old 09-16-2012   #12
nitrofish72's Avatar
Rep Power: 50 nitrofish72 will become famous soon enoughnitrofish72 will become famous soon enoughnitrofish72 will become famous soon enoughnitrofish72 will become famous soon enoughnitrofish72 will become famous soon enoughnitrofish72 will become famous soon enough
Great job Guys. These amps deserve to stay alive. My all time favorite, beautiful looking, super clean power.
nitrofish72 is offline   Reply With Quote
Old 09-29-2012   #13
Doc ProMos's Avatar
I could have picked an amp to restore that was a little less f'ed up.... It took me a while to figure out what the original problem was, but while looking for it I found several other problems... a small tracing at the end of the rectifier was severed...several of the caps vias were missing and part of the power IC's solder was missing.... so I have jumped the tracing, replaced all the FETS and rectifiers, replaced all the caps including jumping the pulled vias...and lastly I replaced the ps IC.... low and behold the amp works... Keith
Old 09-30-2012   #14
Diyma Ninja
BMI Inspections
Bret
PPI-ART COLLECTOR
TEAM GRIZZ
Old 10-01-2012   #15
XaznKewLguyX's Avatar
Rep Power: 73 XaznKewLguyX will become famous soon enoughXaznKewLguyX will become famous soon enoughXaznKewLguyX will become famous soon enoughXaznKewLguyX will become famous soon enoughXaznKewLguyX will become famous soon enoughXaznKewLguyX will become famous soon enough
looookin good!
XaznKewLguyX is offline   Reply With Quote
Old 10-02-2012   #16
Prime mova's Avatar
Impressive
