Old 01-30-2010   #1 (permalink)
Default Midrange for Morel-based system
Hello
Upgrading to 3Way... Will be working semi-active.
I am looking for a recommendation for a mid-range driver which will require no special box (either infinite baffle cone or simply a dome mid).
It should integrate nicely, sound-character-wise in my Morel-based system (Supremo midbass/MT-23 tweeter), and also be readily available for purchase and international shipment (ebay/parts-express/etc), lastly it should be budgetary as much as possible (sub $180 for pair). I should mention that it'll be initially installed without any pillar/fiberglassing work.
Please see attached picture for my configuration - the midrange driver is marked as "CDM54?" - which is also a consideration (I can get a used pair).
another note: I am not sure the MX22.2 xovers I have truly xover-point at 1.8Khz, it's probably a bit higher.
I'll be glad to hear your recommendations
Thanks
mb
mindbomb is offline   Reply With Quote
Old 01-30-2010   #2 (permalink)
Default Re: Midrange for Morel-based system
looks like the CDM54 would be a perfect match and if you can source some local and in your budget ??
that's where i would start
rgs yuri
yuri is offline   Reply With Quote
Old 01-30-2010   #3 (permalink)
CDM54 or 88 seem like the obvious choice here.
rommelrommel is online now   Reply With Quote
Old 01-30-2010   #4 (permalink)
I agree, especially if you can get them for $180 a pair. I auditioned an older version of the Morel 2.5" dome and I was impressed. As long as you keep the high pass crossover from the midbass around 800 Hz they are very good. Expecially off axis, in fact they are a little hot on axis. My frind choose the WR4 which is a cone mid but it is harder to install.
jimbno1 is offline   Reply With Quote
Old 01-30-2010   #5 (permalink)
CDM54 is dome driver and can not play lower then 500-600hz. LPF should be at 3.8-4.5k.
The higher he play the better.
Try to find 3way morel crossover, like MX-33
nomed is offline   Reply With Quote
Old 01-30-2010   #6 (permalink)
Ok, since I am totally unsure if I will be able to get the CDMs for that price, any other recommendations we can think of?
also, the 300 hz I put in the diagram is absolutely flexible and can be upped to 500-600 hz in the HU with a click of a button - no problem here.
Anyone knows what is the _real_ crossover point of the MX22.2 (which I already own)? Would it fit and sound right under the configuration I described??
Old 01-30-2010   #7 (permalink)
Dayton RS52's are cheap, the Morel CAM558 is cheap for morel but I don't know much about it.
Old 01-30-2010   #8 (permalink)
careful running midbass up to 500hz-600hz in a 3-way setup. All depends on your install and mounting locations as to whether that's going to work for proper imaging. Better bet is to limit midbass to 200hz-250hz and let midrange go from there. Again depends on install. Where are tweeters/midbass located? I love the sound of dome mids but their limited on the low side of things and need to be mounted next to midbass if at all possible.
Pioneer DEX P99RS | HAT L1 Pro SE's | HAT L4's | (4)Dyn MW 170's | Dayton 10HF's | (4) Xtant 121M Monoblocks | TRU Tech B2200 | TRU Tech SSLD6i | Soundstream Class A 10.0
gymrat2005 is offline   Reply With Quote
Old 01-30-2010   #9 (permalink)
The MX33 has a 6db/12db lowpass on the CDM-54 at 315 Hz.
Old 01-30-2010   #10 (permalink)
depends also on the distance you have between the midrange and midlow.
if you want/need to run the Supremo in the lower end, you may want to use a Dotec/ Hybryd instead
at least, I replaced md88 and I'm doing this but I have a Piccolo as Tw who will help
TPMS is offline   Reply With Quote
Old 01-31-2010   #11 (permalink)
mmm... why is that?
Actually the supremo midbass's are mounted in the (sound deadened, sealed) car doors, and the tweeters and future mids will be located on-axis on the dashboard/A pillars (not much of a distance difference here).
Is that a problem?
Also - regarding the Dayton RS52 recommendation. Firstly, thanks for that. Secondly - isn't the fact that they are 8 ohms will hinder my configuration plan? (impedance mismatch from the cross-over?)
Old 02-01-2010   #12 (permalink)
bump
Old 02-01-2010   #13 (permalink)
I too was going to upgrade the Elate for a 3-way active setup and looking for the mids. Obviously the suggest was either the CDM-88 or the CDM-54
But my setup kinda restricted my midbass to be crossed at 400hz, therefore, those 2 drivers are out of question.
I was then suggested the MW114s for that they're decently price and good. However, I'm still looking to see if there's any alternative before pulling the trigger.
ATK_Designs is offline   Reply With Quote
Old 02-01-2010   #14 (permalink)
AWC
AWC's Avatar
I can score a few 3.5 inch cone midrange drivers from Audio Development. I don't know much about them but google takes care of that. Say $200.
The CDM 54 is a great driver, though. I love mine.
Not to be trusted with actual advice, though wise and powerful, has been twisted and made evil by the forces of democracy. Not to be considered real. Can cause infections. Possibly an imaginary figment of the author of this reality's creation and, therefore, seriously considering transmogrification into someone else...someone with mad yoyo skillz.
AWC is offline   Reply With Quote
Old 02-01-2010   #15 (permalink)
I don't understand all these comments about the CDM-54 not being able to play down to 400/500 hz when the MX33 passive has a selectable 6/12db crossover at 315hz.
Old 02-02-2010   #16 (permalink)
Where did you get that info?
Morel Loudspeakers - Mobile Audio - crossover Networks - Accuset MX-33.4E
their site clearly states 700hz for mid crossing...
Old 05-31-2010   #17 (permalink)
trigg007's Avatar
he's referring to the discontinued 33.3... Morel Loudspeakers - Mobile Audio - Crossover Networks - Previous models - Accuset MX-33.3
trigg007 is offline   Reply With Quote
  DIYMA.com » Comparative Data & Reviews » Product Selection & Comparisons
Second Skin Spectrum
