Sundown 6-Channel Ideas : Discuss - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 11-21-2016   #1
Approved Vendor
Sundownz
Rep Power: 210 sundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond repute
Default Sundown 6-Channel Ideas : Discuss
We are currently in process of launching a 5-channel in our SAE series... the new 1100.5 model. This will be a "testing the waters" model to see how amps of more than 4-channels do for our dealers.
I've had a thought to do a higher-end counterpart in the SAX line with significantly more features... this is very early brain-storming but this is my thoughts on it so far :
Something like this (FR Class-D probably) :
CH 1-2 @ 100 x 2 @ 4 ohms (stable to 2 ohms per channel)
CH 3-4 @ 150 x 2 @ 4 ohms (stable to 2 ohms per channel)
CH 5-6 @ 200 x 2 @ 4 ohms / 400 x 2 @ 2 ohms / 800 x 2 @ 1 ohm / 1600 x 1 @ 2 ohms bridged
CH 1-2 Crossover:
HPF Filter @ 50-5000 Hz (no x10… unless we can make it fit)
NO SUBSONIC
BYPASS switch (bypass all crossover features even sub-sonic) – so it selects HPF or BYPASS.
CH 3-4 crossover:
LPF Filter @ 500 – 5000 Hz (no x10… unless we can make it fit.. if so make it 50-5,000)
Subsonic @ 10-500 Hz
BYPASS switch (bypass all crossover features even sub-sonic) – so it selects LPF or BYPASS.
CH 5-6 Crossover:
LPF Filter @ 50-500 Hz (no x 10 at all)
Subsonic @ 10-100 Hz
* 6 Input RCAs
* “Input Select” switch so we can pick 2, 4, or 6 inputs
* Try to retain the remote for CH 5-6 if we have enough panel room
* Try to do a clip LED for each pair of channels if we have enough panel room
* Thermally controlled fan on a ~30 second delay (so it won't make sound when the system turns on)
* Potentially marine-grade water resistance. I can see it being very nice on a boat.
I am looking into use one of our wider case tools (like the 7500D or upcoming NS-2... we have 3 width cases that we use) so I can fit everything on the end-panel & to keep length down. More of a squarish shape.
So... assuming that is all possible how do you all feel about it ? Obviously it's way to early for me to guess at pricing... but assume not cheap as it's alot of power / features.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- I DO NOT USE PMs -- Email me at sundownz@sundownaudio.com
sundownz is offline   Reply With Quote Quick reply to this message
Old 11-21-2016   #2
Hillbilly SQ's Avatar
Blue Collar Audiophile
Complacent Audio
Incoherent rambler
Rep Power: 253 Hillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond repute
Default Re: Sundown 6-Channel Ideas : Discuss
The staggered power looks fine. Should do great. Not high on all the features, but those of us who only need a gain pot and nothing else on an amp are few and far between.
'14 Grand Cherokee Limited, OEM U-Connect 8.4a, JL Fix 82, c-dsp 6x8, Arc xdi1200.6v2, Soundstream tn1.1200d, stock rears controlled properly by minidsp 2x4 with rear fill plug-in, Alumapro Alusonic 12 ported, SB Acoustics SB17NRXC35-4, Seas Neo Aluminum...Rearfill done properly is a helluva drug!
Old 11-21-2016   #3
metanium's Avatar
Rep Power: 137 metanium will become famous soon enoughmetanium will become famous soon enoughmetanium will become famous soon enoughmetanium will become famous soon enoughmetanium will become famous soon enoughmetanium will become famous soon enough
Great news Jacob. I love the all-in-one system amp concept and have owned and used literally 12 different 5-channel models in the past 10 years. I think your targeted power output is perfect, channels 5-6 being absolutely BEAST. I also appreciate the staggering of power between Channels 1-2 & 3-4, as it make sense regardless if the user is running a full-active front stage only or front & rear.
I see a couple of things listed potential specs, that I have questions about. Can Channels 3-4 also have a high-pass, in order to create a band-pass for mids? Maybe it can be set-by and equal to the Channel 5-6 low-pass filter. Also, will you include differential-balanced inputs? I see 5&6-channel amps being used for integrating with factory HU's in many of the newer cars. Utilizing the balanced-differential inputs allows direct connections to many of these systems w/o a LOC.
Also, if you need beta-testers, I'm your man! ;-D
2014 Toyota Tundra: Pioneer AVH-X4800BS Arc XDI1100.5, NVX XSP6ACT, Sundown SD-3 10
Old 11-21-2016   #4
Rep Power: 49 nadcicle will become famous soon enoughnadcicle will become famous soon enoughnadcicle will become famous soon enoughnadcicle will become famous soon enoughnadcicle will become famous soon enoughnadcicle will become famous soon enough
I agree with metanium here.
It's not that I will necessarily or absolutely use the amplifier and all of its built in crossovers, but rather having the ability to do so that would make me happy that the options exist.
Having a 6 channel board for a full front stage with channels 1+2 for highs, 3+4 for a bandpassed mid/mid-range, and 5+6 for mid-bass/sub without external crossovers is big, but so is full bypass for some people.
nadcicle is offline   Reply With Quote Quick reply to this message
Old 11-21-2016   #5
Approved Vendor
Sundownz
CH 3-4 :
Good question. The subsonic will act as the HPF to allow band-pass -- this is why it can be set up to 500 Hz =)
I will check into the balance-differential inputs.
- Jacob Fuller
Old 11-21-2016   #6
Approved Vendor
Sundownz
Indeed... I figure having a true "bypass" switch would help out guys not using any on-board crossovers as well. My goal for the switch would be to completely bypass the crossover sub-board (other than gain) when selected.
- Jacob Fuller
Old 11-21-2016   #7
metanium's Avatar
Jacob,
Any idea when these might be released?
Old 11-21-2016   #8
bnae38's Avatar
Rep Power: 33 bnae38 will become famous soon enoughbnae38 will become famous soon enoughbnae38 will become famous soon enoughbnae38 will become famous soon enoughbnae38 will become famous soon enoughbnae38 will become famous soon enough
CH 1-2 Crossover:
NO SUBSONIC
CH 3-4 crossover:
CH 5-6 Crossover:
* 6 Input RCAs
Wow, that'd be nice. One amp solution for guys like me if i used passives on coax (gear in sig).
Ch5/6 would typically take up enough real-estate for a medium size amp as it is, based on specs. What kind of footprint would it be?
Concur on low noise differential inputs, the quieter the better.
2012 Subaru Impreza Sedan. Pioneer P880prs, Helix Dsp.2, JL 12w6v2 x2 sealed, Arc KS600.2, Arc KS900.6, SI TM65v1, Illusion Audio C3cx. Ipod Classic - apple lossless. Just keep tryin' to get a little better.
bnae38 is offline   Reply With Quote Quick reply to this message
Old 11-21-2016   #9
Rep Power: 126 naiku will become famous soon enoughnaiku will become famous soon enoughnaiku will become famous soon enoughnaiku will become famous soon enoughnaiku will become famous soon enoughnaiku will become famous soon enough
I really like this idea, while most amps it is fairly simple to defeat the crossover, on others I have questioned myself. Having a simple switch would be really helpful and quick to set.
This is nice as well. I used to have some JBL MS amps and they had an input select switch. Made it really cool when bridging channels for midbass, I wish my V9 had a similar switch so I did not have to use Y-cables.
A tablet, a DSP, some amps, speakers and a suitcase
naiku is offline   Reply With Quote Quick reply to this message
Old 11-21-2016   #10
fourthmeal's Avatar
DIYMA Been here long time
Rep Power: 918 fourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond repute
That sounds like a REALLY nice amp! an Arc KS900.6 killer. Channels 5-6 sound like a crazy beast, being able to run to that level of load. Id' be good with 1/2 that but if you can fit that much under the hood, I wouldn't want to be one to try and stop you.
2015 Durango R/T, Build MS-8, Massive NX4 pair, Massive N3, ID X6x9, Wavecor center, Alpine SPX Pro tweeters, Sundown SD3 10's
2017 Colorado, Helix V Eight, Arc 500.1, ID8's, Audible Physics AR3 & AR20
Old 11-21-2016   #11
quickaudi07's Avatar
Rep Power: 122 quickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the rough
I honestly would never need any crossovers as far as High End SQ user, I have a DSP. I think you should focus more on sound quality and power production of the amp vs putting crossovers in...
or make 2 amps, one with, and one without like Patrick from Zuki Audio did...
but 6ch would be great and will this be class AB or D... I prefer class D..
Also Erick which im sure you know who that is,, from Image Dynamics,, he was about to release 8ch mp that you could bridge the least channels. but since you going to have a amp with so much balls inside of the amp. than you should be all set for any great 3way active setup so no need for crossovers unless someone isn't using dsp and wants to be difficult
BTW you started on a project of a nice SQ sub with huge XMAX.. hows that going?
2013 VW CC and as I said down low!
When You Think Your Done! Reality is..... is just the beginning
quickaudi07 is offline   Reply With Quote Quick reply to this message
Old 11-21-2016   #12
Me on the other hand, I love loud clean music, and this will be pefrect one amp solution for either 2 way or 3 way active...
I like it loud so anything under 100 w rms, wont cut it for me..
Thats why I have Mosconi Zero 4 amp and Zero 1 just for that power
Old 11-21-2016   #13
sq2k1's Avatar
Rep Power: 25 sq2k1 will become famous soon enoughsq2k1 will become famous soon enoughsq2k1 will become famous soon enoughsq2k1 will become famous soon enoughsq2k1 will become famous soon enoughsq2k1 will become famous soon enough
I like the staggered power idea for the amp. What would be killer would be an 8 channel amp based on the same concepts for an all in one package for those doing an active 3 way system and trying to keep an install as minimal as possible. I like the power output of the sub channels with the 1 ohm stability per channel/ 2 ohm mono capability very much. Just throwing my 2 cents into the discussion.
sq2k1 is online now   Reply With Quote Quick reply to this message
Old 11-21-2016   #14
brumledb's Avatar
Rep Power: 42 brumledb will become famous soon enoughbrumledb will become famous soon enoughbrumledb will become famous soon enoughbrumledb will become famous soon enoughbrumledb will become famous soon enoughbrumledb will become famous soon enough
Have you ever looked into Class G/H technology? An amp such as you described but with G/H all around or at least on (A-D), now that would be cool. Alternatively, A/B on channels A-D (like the Audison 5.1k) would be nice also.
2014 GMC Sierra Crewcab
OEM Headunit-->Helix DSP Pro
Audison 5.1k--->Xtant Tweets, AF GB25, (4) ID8's
PG Ti2 1000.4-->GZNK 165SQ
(Proper Acoustic Rear Fill)
brumledb is offline   Reply With Quote Quick reply to this message
Old 11-21-2016   #15
Rep Power: 52 norurb will become famous soon enoughnorurb will become famous soon enoughnorurb will become famous soon enoughnorurb will become famous soon enoughnorurb will become famous soon enoughnorurb will become famous soon enough
Class A on ch 1/2, class D everything else.
norurb is online now   Reply With Quote Quick reply to this message
Old 11-21-2016   #16
PorkCereal's Avatar
Rep Power: 102 PorkCereal will become famous soon enoughPorkCereal will become famous soon enoughPorkCereal will become famous soon enoughPorkCereal will become famous soon enoughPorkCereal will become famous soon enoughPorkCereal will become famous soon enough
I like it, very stout sub stage at 2 or 1 ohm. That's the problem with many multi channel amps is a weak sub stage. Not sure it would replace my arc 1200.6 but would be tempting.
Sent from my SAMSUNG-SM-G935A using Tapatalk
'15 Focus ST, SI M25, TM65v1, BM MKiv x2, ARC 1200.6, JBL MS 8
PorkCereal is offline   Reply With Quote Quick reply to this message
Old 11-22-2016   #17
Approved Vendor
Sundownz
I've had some GH samples from a build-house that does that technology. I was having a hard time getting through to them about doing custom PCBs & the quoted pricing was pretty high even on stock boards. I feel like it would put me out of the running with the majority of our customers.
The SAE-1100.5 that we will be releasing 1Q or 2017 an AB/D model (75x4 + 800x1) -- the issue I have with that on the more powerful SAX 6-channel would be size. It would end up being pretty gigantic. Assuming our narrow casing probably 30" long.
- Jacob Fuller
Old 11-22-2016   #18
Approved Vendor
Sundownz
If you are talking about my JF-SQ project then I have that sitting in my office behind me. I will be re-starting development next year on that... I didn't feel like the suspension was up to par and I've recently gained the ability to have 3D FEA simulations done for suspension components.
- Jacob Fuller
Old 11-22-2016   #19
Approved Vendor
Sundownz
We are *very* early on in the brain-storming process. I am trying to work out the sizing and estimate what it would cost to produce to evaluate it's marketability as soon as I can =)
- Jacob Fuller
Old 11-22-2016   #20
You need to get on my buddy, I seen what that sub could do and i was wow stoked! Ill be the first one to get cant wait to see the performance.
Good Luck !
Old 12-23-2016   #21
Rep Power: 105 cdubb will become famous soon enoughcdubb will become famous soon enoughcdubb will become famous soon enoughcdubb will become famous soon enoughcdubb will become famous soon enoughcdubb will become famous soon enough
Send a message via Yahoo to cdubb
OMG, if I had the spare funds the 5ch would be ideal....
cdubb is offline   Reply With Quote Quick reply to this message
Old 03-14-2017   #22
reker13's Avatar
Rep Power: 124 reker13 will become famous soon enoughreker13 will become famous soon enoughreker13 will become famous soon enoughreker13 will become famous soon enoughreker13 will become famous soon enoughreker13 will become famous soon enough
The 6-channel specs look perfect to me only concern would be the size if its ~30" long. I'd probably have to go with two smaller format amps instead on a typical install.
"The Universe is shaped exactly like the Earth if you go straight long enough you end up where you were." Modest Mouse
reker13 is offline   Reply With Quote Quick reply to this message
Old 03-14-2017   #23
Rep Power: 130 t-roy will become famous soon enought-roy will become famous soon enought-roy will become famous soon enought-roy will become famous soon enought-roy will become famous soon enought-roy will become famous soon enough
Power would work great I could make the size work as well. What kind of a time line would there be?
t-roy is offline   Reply With Quote Quick reply to this message
Old 03-29-2017   #24
djnsmith7's Avatar
Rep Power: 0 djnsmith7 will become famous soon enoughdjnsmith7 will become famous soon enoughdjnsmith7 will become famous soon enoughdjnsmith7 will become famous soon enoughdjnsmith7 will become famous soon enoughdjnsmith7 will become famous soon enough
I really like the flexibility this amp will offer & the increase in power for channels 5 - 6 over the 1100.5. This offering will cover the 1100.5 demographic as well as folks looking for higher Mono output. Excellent all-around package for entry / mid-level systems.
djnsmith7 is offline   Reply With Quote Quick reply to this message
Old 04-04-2017   #25
DejaWiz's Avatar
Rep Power: 123 DejaWiz will become famous soon enoughDejaWiz will become famous soon enoughDejaWiz will become famous soon enoughDejaWiz will become famous soon enoughDejaWiz will become famous soon enoughDejaWiz will become famous soon enough
I like the idea of staggered power, but not in a 30" footprint. How about something like this?
FD with RPS
CH 1-2 @ 100 x 2 @ 2-4 Ω
CH 3-4 @ 150 x 2 @ 2-4 Ω
CH 5-6 @ 200 x 2 @ 2-4 Ω / 400 x 1 @ 4 Ω bridged
CH 1-2 Crossover:
HPF Filter @ 50-7000 Hz
BYPASS/ALL-PASS switch (select HP or AP).
CH 3-4 crossover:
LP/HP/BP Filter @ 50 – 7000 Hz
BYPASS/ALL-PASS switch (select LP, HP, BP, or AP).
CH 5-6 Crossover:
BYPASS/ALL-PASS switch (LP or AP).
* 6 Input RCAs
* Marine-grade water resistance. I can see it being very nice on a boat.
...900W total RMS rated, so it very well might be crammed in a chassis size range similar to the NVX/PPI/Polk 5ch triplets, the PDX line, AudioControl LC-6.1200, and the like.
(around w:12-15" x d:7-9" x h:2-3")
...If this is possible to do and carry a retail price tag between $600-800, I think you may have an absolute winner on your hands.
2011 Kia Optima EX
Factory HU | Blaupunkt Vc660 | Infinity Kappa 800w Infinite Baffle | Soundstream TN4.900D
DejaWiz is offline   Reply With Quote Quick reply to this message
