MS-8 plus JL Audio: XD(10.1ch) or HD(8.1ch) setup?
Guys,
I have an MS-8 based system which I am either: 1) adding another XD amp to, or 2) replacing 1x XD amp with 2x HD amps. Here are the basics (details in pics): JL XD600/6+XD700/5
Re: MS-8 plus JL Audio: XD(10.1ch) or HD(8.1ch) setup?
I thought you already had the HD amps...
If you ask me, I would say go for the HD set-up and never look back. No second guessing about power, headroom and SQ. PLD between the mids and tweets is not an issue, so going active is not really an advantage. Plus, you know that if you went with the XD amps, sooner or later the upgrade bug could bite you in the ass and then it would have been better to just go with the HDs from the beginning...
The power numbers aren't that much of a big deal. Its a 3dB difference in RMS power but the peak power difference actually isn't that much due to bi-amping advantage. In other words, the peak overhead is there on the 75 watts as well. The Rainbow drivers are only rated to 80w anyhow.
The PLD isn't the reason to biamp (Time alignment/Ms-8 channel assignment) will be identical in each setup.
In terms of strict power balance, I pretty much love the XD setup, but I'm mentally committed to the HD setup...but I am wondering if its entirely due to cosmetics...Tough choices! I can't believe I didn't think of this allocation before.
I like both set ups but I am partial to the HD for power and aesthetics.
The value of the visual effect can carry a lot of weight in terms of overall satisfaction once the build is complete. So go with the HD's
The range of what we think and do is limited by what we fail to notice...
I'm the kind of person that loves high-end but in your case, I would go with the XD:
XD600/6 - L/C/R like you suggested
XD700/5 - front channels bridged to midbass
MS-8 - internal amp for rears
Rears really don't need much power and your midbass will love the extra headroom...
Kelvin
Lycan
I'd do the HDs because you don't NEED power balance. The rears are going to be turned down anyway so why waste the amp power? Also, since you can't access the top of the amp stacked on the bottom it'll be a pain to adjust. With front mounted controls setup will be a lot easier.
Kelvin
Thanks,
I've found from my trial and error that the MS-8 give much much better results with level matching on the drivers. If I do this with some drivers on MS-8 internal power, I might as well not have power on the other channels. I run the XD600/6 to my front stage right now (except center) and i get much better results with the gain turned down. The SQ is pretty near amazing but I bet I would not get much less volume if I deleted the XD600/6 due to the fact that the system is level matched. Thus, this is the reason I decided to amp all my channels.
Though they won't be playing much due to Logic7, the won't really be "turned down"
Yes indeed, the front mounted controls are a godsend.
I've ran the XD700/5 (on MS-8) and the HD900/5 & HD600/4. I usually don't run rears at all, but definitely saw their benefit when running the MS-8 w/Logic 7. I tend to agree w/Quality Sound on not needing power balance and with Subwoofery on using the internal MS-8 to power the rears.
I would run the HD's, but run 150 x 4 (L & R, 2-way active on 600/4), 150 x 2 (Center, 2-way active on 900/5), 150 x 2 (Midbass on 900/5), 500 x 1 (Sub on 900/5), and rears on MS-8 internal amp.
All 8 front drivers getting their own 150W channel, 500W on sub, plus rears on MS-8?......This wins!
2010 Toyota Tundra Crewmax: Factory HU w/Bluetooth, iPad Mini, Audison Bit Ten D, JL HD900/5, LPG 26NA, AP-3, HAT L8, Sundown SD-2 8's
I'd probably go HDs in your case. However, I found that the rears amped at 75W with L7 turned on actually gave me an increase in midbass output, or so it seemed. My rears were playing pretty loud and down to 70 Hz or so, but the soundstage was still up front where it belonged. I kinda miss that setup now... If you like loud, dynamic music, as i do, amp the rears even just as an experiment, and see how you like it.
2011 MINI Cooper S :: [build log] :: [new CarPC project]
HAT L6SE, L3SE, L1 Pro R2. 4x Alpine SWR-843D, 2x JL XD700/5, 2x XD500/3, Alpine H800, RUXC800, Mac Mini CarPC
No matter which way I slice it; my overall system power is going to be limited by my least powerful driver in terms of SPL. Either the MS-8 will level match the stronger channels to that driver, or (as I have found), you get AMAZINGLY BETTER RESULTS by turning down power to match all channels within a few dB.
There is no way I am giving only 30w to the rears. That is the whole reason for this project...to power them! (and more importantly the center).
In other words, it does no good to give my front stage drivers a gagillion watts of power when I have to dial that back down (or let MS-8 do it) to match the 30w that the rears are getting.
Have you other MS-8 users not noticed this? or is my experience different?
Neil, this is because Midbass is being played out of phase from the rears, to anchor it up front...from what I understand. Thus imaging should be IMPROVED with more power to the rears.
Exactly. Phase steering wins again. Makes me so sad that I'm selling my MS-8(s). power the rears, you'll be glad you did!
My rears and sides are on MS-8 power. Since they are run in parallel (1 ohm per channel), they are very loud. During level matching, I had to bring up all other channels to match the rears (amps set to 2V initially). power to the rears I have found does not matter much, since they are HEAVILY attenuated during normal listening with L7 turned on. In my and Taibanl's case, the rears are 4" so they don't contribute to midbass, plus we have 8s under the seats.
Exactly... Apples to oranges. I had well-sealed 6x9's with a few cu.ft. in the back with the crossover set much lower. That means they'd take more power than a set of 4's that were crossed high. I think Logic7 sounds much better with the rears playing as low as it will allow, with considerable power for dynamic transients. I'm not an SQ purist, I listen to certain types of music music very loud, and having the rear speakers assist the front in the midbass department while not screwing the stage up is pure bliss.. Crazy amounts of visceral energy that kicks you in the chest. Kind if reminds me of Patrick Bateman's epic midbass array thread.
They dont contribute to midbass per-se, no. They do very much contribute to midbass imaging.
Ive already run the spl calculations, the rears will be 6dB quieter on the HDs than the front stage. That might mean i have to turn down my 150w to the equivalent of about 37.5w
I also am skeptical that the 900/5 will only put 75w into two ohms (rated power)
Originally Posted by taibanl
Thanks,
As quality_sound pointed out, the rears are much lower in level than the front - believe that I read something like 5-6dB lower
Therefore you don't need much power. In the MS-8 thread, I can't count how many times Andy suggested to use the MS-8 internal amp for rears and said that it would be fine... Rears lowest suggested HP is 100Hz, since most rears are smaller in size, a lot prefer to HP those around 125Hz-160Hz. So again, don't need much power for that application.
Keep the XD600/6 and amp the rears with the MS-8. My opinion
Regarding level matching, I know about its importance - especially with the MS-8. Having more power on the midbass doesn't mean you can't level match. I prefer giving more power to the midbass for those dynamic peaks. If you check the MS-8 target curve, you'll see that there's a rising slope below 160Hz down to about 60Hz <-- midbass and upper bass range right there...
Kelvin
Lycan
FRONT stage information is ALSO played through the years at -6dB for rear fill/rear seat pax. Logic 7 steered information (i.e. recorded out of phase) is not attenuated.
Therefore you don't need much power. I maintain that you need to have matched power for calibration, not for playback though, as you suggest.
In the MS-8 thread, I can't count how many times Andy suggested to use the MS-8 internal amp for rears and said that it would be fine...I already have "fine", I have more than "fine" but the front stage in my vehicle is limited by the lack of amped rears. I know this to be a fact. Rears lowest suggested HP is 100Hz, since most rears are smaller in size, a lot prefer to HP those around 125Hz-160Hz. So again, don't need much power for that application.
Keep the XD600/6 and amp the rears with the MS-8. My opinion That's pretty much my current setup that I am building on
Regarding level matching, I know about its importance - especially with the MS-8. Having more power on the midbass doesn't mean you can't level match. Right now, I have 200w to each mid bass... true, they love it but I have the sensitivity turned down significantly to match. I know 150w per (the HD based setup) would be plenty I prefer giving more power to the midbass for those dynamic peaks. If you check the MS-8 target curve, you'll see that there's a rising slope below 160Hz down to about 60Hz <-- midbass and upper bass range right there... Very familiar with that curve
Kelvin
Kelvin,
Thanks for the detailed post. I am 100% certain I am going to amp all channels, its just a matter of what the channel allocation will be. I already have an amazing soundstage with MS-8 and the XD 600/6 has more room to turn up...but the combination of the two is the limfac.
I am leaning toward the HD setup for cosmetics and headroom on the front stage. That being said there is a certain appeal to the matched power of the XD setup. In the XD setup my quietest driver would be 107.8dB in the HD setup it would be 106.5...So in some sense this is splitting hairs.
It was more a question of whether I would get more SQ out of having a dedicated amp channel for each individual driver (XD), or just having tons of headroom (HD).
In other news...just finished modding my center to handle more power :-)
Originally Posted by Andy Wehmeyer
OK... the rears in L7 play loudly or not so loudly depending on what information in the track gets steered to the rear. On some tracks, there won't be much output on others, there may be a lot. Ideally, the rears would be able to play as loudly as the fronts for those times when the recording dictates that they should, but this isn't super critical.
When MS-8 does the calibration, it looks for the rears to be about as loud as the fronts--it level matches them. If you amplify the front and not the back, MS-8 will reduce the level of the fronts. That means that if you've paid for 1000 watts for each of the front speakers and don't want to buy an amp for the rears, you won't experience Logic7 as it's supposed to be experienced.
In the MS-8 thread, I can't count how many times I've disagreed with Andy The guy's smart and has more experience than most anyone here, but that doesn't mean that everything he says is gospel. He has a style or preference for how to put a system together, but I assure you, in certain situations or styles of music, it would fall apart quickly. Rebecca Pidgeon at 85dB? sure... Skrillex or Bassnectar at 110 dB? Forget it There's no end-all be-all to car audio, otherwise this forum would be obsolete. I could quote Andy-isms about following recipes and stuff about now, but I'm too lazy Just do what works for you, experiment, and listen to cars at local SQ events!
This is why...
Exactly. If you listen to electronic music, you'd be very suprised how much information is purposely mixed exactly 180 degrees out-of-phase. Listen to Rusko - Hold On with L7, I could go through and pick out a few others. You need some headroom back there, all the way down to 70 Hz or so, it will get all distorted and flattened.
I have learned I get much better results, taking Andy's word, than not.
That being said....
Andy gives advice based on his known working applications of the product (the test BMW being one). He sometimes is lost when dealing with new applications (other BMW's with mid bass holes, etc). Sometimes it has taken the user community to come up with permutations that Andy doesn't expect to fix problems that the MS-8 can't handle (kaigoss mod).
The bottom line, is that the MS-8 doesn't always give predictable results. I think one case of this is with mismatched levels. Based on my experience, the processor is very very happy when it doesn't have to level match. Thus, I would like to get the same results I have gotten when I level matched...and make said results louder.
