building sql sub setup need help with good made subs - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 07-22-2012   #1
Rep Power: 0 ssmokeyy will become famous soon enoughssmokeyy will become famous soon enoughssmokeyy will become famous soon enoughssmokeyy will become famous soon enoughssmokeyy will become famous soon enoughssmokeyy will become famous soon enough
Default building sql sub setup need help with good made subs
Hey guys im looking at doing 3 or 4 sub setup for more output but i want it to be really clean.
Here is what im loooking at
2 alpine type s 15's
4 type e 12's
3 jbl gto 12
4 rf punch level 2 8's
4 kicker comp c10's
4 polk db 10's
2 alpine 12 type r's if i save up more money.
Amp im using is the ed nine.1 so i got lots of Power and i can turn it down if the subs can't handle it.
Setup i have is This
alpine cda-117 with imprint
jbl gti mk2 front active
kicker zx 650.4
ed nine.1
all top of the line wiring and rca's.
main goal is to have best tonal quality second loud.
ssmokeyy is offline   Reply With Quote Quick reply to this message
Old 07-22-2012   #2
Rep Power: 61 djbreal87 will become famous soon enoughdjbreal87 will become famous soon enoughdjbreal87 will become famous soon enoughdjbreal87 will become famous soon enoughdjbreal87 will become famous soon enoughdjbreal87 will become famous soon enough
Default Re: building sql sub setup need help with good made subs
Rockford, Polk, or Alpine would be good. I also was designing an SQL set up, and I went with 2 Arc audio Black 12's (adding a third later) but they are 450$ a piece for new, and good luck finding them used anywhere (I cant) so im thinking it might be out of your budget with the speakers you listed.
djbreal87 is offline   Reply With Quote Quick reply to this message
Old 07-22-2012   #3
Witch would be a better deal
2 type s 15's or 2 type r 12's this is going to be a sealed box. can the 15's keep up with rock? I know speakers have changed is the only reason i ask 15's used to be a bit slower because of how much cone they had to move. but with new tech this might have changed.
Old 07-22-2012   #4
Coppertone's Avatar
DRKNESS
Rep Power: 125 Coppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of light
Try using three CDT QES 12's for what it is that you desire.
(2.5GT) Limited Legacy / Alpine INA-W910 / Alpine PXA-H800 / Alpine C800 / Sinfoni T25T / Sinfoni T65W / Brax X2400.2 / Brax X2000.2 / JL Audio 12TW3-D4
For sale NIB / Sinfoni Tempo 10 / Sinfoni T65W / Rear view camera....
Old 07-22-2012   #5
SkizeR's Avatar
DIYMAddict
Rep Power: 199 SkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of lightSkizeR is a glorious beacon of light
my Fi Q 10 gets as loud as my old subs (2 Alpine type R 12s) and certainly sounds better.. take a look at it... https://ssl.perfora.net/www.ficaraud...iew.shopscript
1990 300zx Build Log
Old 07-22-2012   #6
brandon.'s Avatar
Rep Power: 59 brandon. will become famous soon enoughbrandon. will become famous soon enoughbrandon. will become famous soon enoughbrandon. will become famous soon enoughbrandon. will become famous soon enoughbrandon. will become famous soon enough
Fi subs get loud but retain great sound quality. Other subs to consider are the Image Dynamics Q and Max series.
Current setup (in progress) Sony XNV-660BT, Image Dynamics CTX65cs, Image Dynamics Q450.4, 12" Fi SSD
Currently looking for a sub stage amplifier. 500-800watts x 1 @ 2 ohm
brandon. is offline   Reply With Quote Quick reply to this message
Old 07-22-2012   #7
Im going to go with alpine this time around. Now need to make up my mind if i should use 2 12 type r's or 3 type s 12's. Here is the thing i want to be around 142 db. good news is the Car is one of the smallest 4 doors in the world. Its a stylus and im putting the subs in the back seat taking out the back seat building a fiber glass box and walling off the trunk so no sound pressure will be lost that way. I used to have a type r about 6 to 7 years ago like 3 gen's back. loved the sound but one wasn't loud enough.
Old 07-22-2012   #8
SkizeR's Avatar
DIYMAddict
i have their Q model. gets decently loud but still has great SQ if you put it in the right box..
*edit* i used to have 2 12 inch type R's in a sealed box and switched from that to the 1 ten inch Fi Q in a T-line box tuned to 32 hz and it is much louder and better souding than the two type R's
Old 07-22-2012   #9
legend94's Avatar
Rep Power: 169 legend94 is a jewel in the roughlegend94 is a jewel in the roughlegend94 is a jewel in the roughlegend94 is a jewel in the roughlegend94 is a jewel in the roughlegend94 is a jewel in the roughlegend94 is a jewel in the roughlegend94 is a jewel in the roughlegend94 is a jewel in the roughlegend94 is a jewel in the roughlegend94 is a jewel in the rough
Buy 4 of the image dynamics id series that are 79 for each 12.
legend94 is offline   Reply With Quote Quick reply to this message
