I need some opinions and/or suggestions on picking an amp for a new daily driver install. I'm not doing anything too fancy and I'm more concerned about SQ but would like to play it a little loud from time to time. I'm trying to keep it between $200 - $300 for the amp, but will spend a little more if the quality difference is there. Here's what the amps will be powering:
Fronts - ID CTX65CS
Rear - ID CTX 65
Sub - Alpine SBR-S83V
Right now I'm trying to decide between 2 Powerbass amps, the ASA 1100.5X which is a 75w x 4 class A/B amp and the XAX 5670FD which is 100 x 4 class D. My concern is the sound quality between the 2 and the power ratings with the speakers that I'm going to use. Any opinions either way or maybe a different amp altogether? I was using an Alpine PDX-5 before, and was happy with it, but thought the sub output was a little weak.
I have considered this amp...is 75x4 enough for the ID speakers or do you know if this amp is underrated at all? Should using class D for full range be a concern anymore?
For other options above that price threshold, I would suggest a Kenwood XR-5S,
used JL 500/5, Memphis Belle or maybe even a Zuki.
That JL 500/5 looks like it might work...do you know much about them, like are they underrated etc? I agree, i don't think I'm going to find an XD700/5 for $300, but I would go up to $400 if I had to. I don't want to over do it for a DD, but I don't want crap either...
I checked out the Aura amp you mentioned and it looks nice, but l worry it might be under powered for the ID speakers. Am I worrying too much about about 40w vs 100w for components?
I'm guessing I should avoid Powerbass since no one has said anything about them. I hadn't heard of them, but a Google search said they were decent.
I am in a similar boat. Going with the Arc XDi805. MSRP is $469.00. I don't think you can go wrong with it. Does 80x4@4ohms and 400x1@2ohms. Small footprint and uses the new Philips chip.
