need help adding some bass in my 2013 Honda accord - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 11-21-2012   #1
Rep Power: 0 jaxxx will become famous soon enoughjaxxx will become famous soon enoughjaxxx will become famous soon enoughjaxxx will become famous soon enoughjaxxx will become famous soon enoughjaxxx will become famous soon enough
Default need help adding some bass in my 2013 Honda accord
just recently purchased an 2013 Accord, I like everything about the car besides the sound system. Fiest thing I would like to do is add more bass to the car. I do not want earthshaking bass but want just more thump to make my music sound better.
I want to keep my budget around $200.
Any suggestions??
I can run a LOC from the subwoofer connections but Im not sure how to set up a gain for the amp since its a stock headunit.
I would also like to use as little space as possible. The stock system has a subwoofer in the middle of the rear deck.
jaxxx is offline   Reply With Quote Quick reply to this message
Old 11-21-2012   #2
RNBRAD's Avatar
Rep Power: 66 RNBRAD will become famous soon enoughRNBRAD will become famous soon enoughRNBRAD will become famous soon enoughRNBRAD will become famous soon enoughRNBRAD will become famous soon enoughRNBRAD will become famous soon enough
Default Re: need help adding some bass in my 2013 Honda accord
If it was me, I would go something like this or very similiar. You need speaker level inputs and it's nice when the amp can sense when the inputs or on and powers up the sub amp automatically. This unit does that.
Kicker PT10 (11pt10) 100W Sealed Amplified Loaded Sub Enclosure
System 1 of 3: Amptech Alt, Stealth reg, Alpine IVA-C800, DVA-5205, CHA-S604, MB-Quart Premium-316, Mcintosh MCC443m, MCC427, Audio Control DQXS, Epi, ESP-2, Kicker XPL 12's.
RNBRAD is offline   Reply With Quote Quick reply to this message
Old 11-21-2012   #3
t3sn4f2's Avatar
Rep Power: 224 t3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to all
MS-BassPro SQ | 10" (250mm) premium powered car audio subwoofer system | JBL US
JBL MSBassPro SQ
Edit: nevermind didn't see the budget.
Old 11-21-2012   #4
I was just reading through the reviews, one person said that you do not have to connect the box to your battery.. is this true??
can I just hook this box straight from the speaker wire of the stock subwoofer and the box will use that as a gain also??
Old 11-21-2012   #5
RNBRAD's Avatar
jaxxx, it will require a power and a ground. It only pulls about 5 amps tho, so you don't necessarily have to go clear to the battery for power. Might find a good power source from your fuse block, but make sure someone helps you with this if you have never done it. You will tap into the speaker wire of your stock subwoofer or unplug it all together and run them into this amp for the signal. That's it, signal, power, and ground your done. It will turn off/on automatically with your stock stereo. It also has a bass control knob you can mount under your dash that will control the gain of the subwoofer to your liking.
Old 11-21-2012   #6
RNBRAD, sounds simple enough. how does this box compare to an infinity basslink 2 or a bazooka subwoofer?
Old 11-21-2012   #7
rton20s's Avatar
Rep Power: 312 rton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond repute
If you're really on a tight budget, and don't want to piece it all together yourself and build (or have built) an enclosure, I would say this...
400W Boston Acoustics G110PS Loaded Enclosure+GTA-2602 Amp+Tunk Kit
Pretty much everything you need, save for the LOC and it is right in your budget.
Old 11-21-2012   #8
RNBRAD's Avatar
I have not compared all 3, so cannot help you there.
Old 11-21-2012   #9
Rep Power: 77 audiobaun will become famous soon enoughaudiobaun will become famous soon enoughaudiobaun will become famous soon enoughaudiobaun will become famous soon enoughaudiobaun will become famous soon enoughaudiobaun will become famous soon enough
JBL GT-BASSPRO12 CAR AUDIO 12" POWERED SUBWOOFER ENCLOSURE PORTED BOX SUB WOOFER 050036313216 | eBay
Found this..Ive always bought Bazooka 8-10",and have never been disappointed.Kicker made a Substation at one time that was great.May be hard to find those BNIB anymore
audiobaun is offline   Reply With Quote Quick reply to this message
Old 11-21-2012   #10
Bazooka BTA10100 100W 10" BT Powered Amplified Subwoofer Bass Tube Enclosure 607520008907 | eBay
This is an excellent deal here
