Best $60 Sub? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 02-17-2017   #1
Rep Power: 0 Dragonfish42 will become famous soon enoughDragonfish42 will become famous soon enoughDragonfish42 will become famous soon enoughDragonfish42 will become famous soon enoughDragonfish42 will become famous soon enoughDragonfish42 will become famous soon enough
Default Best $60 Sub?
Yes I know, that's a contradiction in terms but of all the cheap $60 subs which is the best? Way too many options to be able to sort through them all without some better informed opinions.
Forgot to mention - SQ not SPL is important to me.
Dragonfish42 is offline   Reply With Quote Quick reply to this message
Old 02-17-2017   #2
Hillbilly SQ's Avatar
Blue Collar Audiophile
Complacent Audio
Incoherent rambler
Rep Power: 251 Hillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond repute
Default Re: Best $60 Sub?
Check the classifieds on here. I bet someone has a $100 sq sub in great shape that's in your budget. If buying new, can't help ya there. Lots of budget subwoofers sound pretty good as long as you don't expect too much in output. MOST of the time it's all in the box and install, but some subs just don't have any hope whatsoever.
'14 Grand Cherokee Limited, OEM U-Connect 8.4a, JL Fix 82, c-dsp 6x8, Arc xdi1200.6v2, Soundstream tn1.1200d, stock rears controlled properly by minidsp 2x4 with rear fill plug-in, ID15v3, SB Acoustics SB17NRXC35-4, Seas Neo Aluminum...Rearfill done properly is a helluva drug!
Old 02-17-2017   #3
That's exactly what I'm trying to avoid, the "no hope" subs. Thanks!
Old 02-17-2017   #4
Complacent Audio
Incoherent rambler
What size subwoofer are you looking into? What impedance are you needing? How much power? A good chunk of us on this forum (me included) are sitting on equipment that's either new or gently used but just don't advertise for sale unless we see it might fit someone's needs. If I see a good deal and have the funds with possibility of using it I pounce on it.
Old 02-17-2017   #5
A single 8" or 10", I'll be using a Planet Audio AC1500.1M Monoblock:
1500 W MAX Power, 1 Channel 1125 W X 1 RMS @ 2 ohm 563 W X 1 RMS @ 4 ohm
I'm going to build a custom slotted box tuned to somewhere around 36Hz, I primarily listed to classic rock and hard rock/metal but some of what I listed to still booms.
Thanks for the help!
Old 02-17-2017   #6
Complacent Audio
Incoherent rambler
Your best bet will be to find a good deal on a single used sub.
Old 02-17-2017   #7
Rep Power: 30 MikeS will become famous soon enoughMikeS will become famous soon enoughMikeS will become famous soon enoughMikeS will become famous soon enoughMikeS will become famous soon enoughMikeS will become famous soon enough
Tang Band W6-1139SIF 6-1/2" Paper Cone Subwoofer Speaker They say it outperforms many bigger ones.
Then theres peerless sls 8"
MikeS is offline   Reply With Quote Quick reply to this message
Old 02-17-2017   #8
Rep Power: 121 Lycancatt has a spectacular aura aboutLycancatt has a spectacular aura aboutLycancatt has a spectacular aura aboutLycancatt has a spectacular aura aboutLycancatt has a spectacular aura aboutLycancatt has a spectacular aura aboutLycancatt has a spectacular aura aboutLycancatt has a spectacular aura about
two great options but I suspect neither will be enough for the op in a car..i loved the tangband 6.5 but I killed it trying to overpower road/wind noise.
my first thought is a jbl gt5 series ten or if your budget will stretch just a tad, alpine type s ten.
Old 02-17-2017   #9
I had a used JBL GT5-10D in my cart last night and this morning it was gone
Old 02-17-2017   #10
Ok, I'm down to 2 options:
JBL GT5-10D
Image Dynamics ID8 D4 V.4
I found both for pretty close to my budget.
Old 02-17-2017   #11
Rep Power: 166 Mless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enough
I seriously think that GT5 and Type E (older one with non accordion surround) do really really good for what they are!
Out of the 2 you listed, get the 10".
Old 02-17-2017   #12
yep, get more cone area every time
Old 02-17-2017   #13
street.terror's Avatar
Rep Power: 72 street.terror will become famous soon enoughstreet.terror will become famous soon enoughstreet.terror will become famous soon enoughstreet.terror will become famous soon enoughstreet.terror will become famous soon enoughstreet.terror will become famous soon enough
And out of left field, 2 of these! http://www.parts-express.com/dayton-...oofer--295-484
I have two I'm my truck in slot ported boxes. They're great.
I did a build with 4 of them ported and the output off 200 watts was just unreasonable for what they are.
Sent from my SM-G930W8 using Tapatalk
SQ confuzzles me
street.terror is offline   Reply With Quote Quick reply to this message
Old 02-17-2017   #14
Rep Power: 6 ThatG37Sound will become famous soon enoughThatG37Sound will become famous soon enoughThatG37Sound will become famous soon enoughThatG37Sound will become famous soon enoughThatG37Sound will become famous soon enoughThatG37Sound will become famous soon enough
I love my JBL GTO804s. But I also run 4 of them. Got them for about $60.
I have a great Diamond Audio D3S which sounds amazing. If you were closer I would totally sell it to you for cheap! It has sat in my garage unused for about 10 years now. It needs a home.
ThatG37Sound is offline   Reply With Quote Quick reply to this message
Old 02-17-2017   #15
Rep Power: 93 neuspeedescort will become famous soon enoughneuspeedescort will become famous soon enoughneuspeedescort will become famous soon enoughneuspeedescort will become famous soon enoughneuspeedescort will become famous soon enoughneuspeedescort will become famous soon enough
i used these in a few different cars and box configurations a few years back. can't find them anymore. hands down the best non-spl 8 i have ever put my hands on.
neuspeedescort is offline   Reply With Quote Quick reply to this message
Old 02-17-2017   #16
Yes, they are great for SQ. A lone they lack serious output, but 4 of them fixes that issue. Still not going to dig into the low 20s like a good 12 or 15, but that's where the beauty of cabin gain comes in.
Old 02-17-2017   #17
Niebur3's Avatar
High Definition Mobile Audio
Rep Power: 146 Niebur3 is just really niceNiebur3 is just really niceNiebur3 is just really niceNiebur3 is just really niceNiebur3 is just really niceNiebur3 is just really niceNiebur3 is just really niceNiebur3 is just really niceNiebur3 is just really niceNiebur3 is just really niceNiebur3 is just really nice
I have a demo ARC10 mint condition I was looking to sell. PM me if you are interested.
Old 02-17-2017   #18
Thanks for the offer, but I feel like that's going to be out of my roughly $60 price range
Old 02-17-2017   #19
Complacent Audio
Incoherent rambler
Those Dayton 8's look like a fun option.
Old 02-17-2017   #20
I like them, they're definitely over achievers. But a quick run through the reviews makes that no surprise. They have to be ported though when used as a sub, sealed they quickly go from sub bass to mid bass.
SQ confuzzles me
Old 02-17-2017   #21
glockcoma's Avatar
Rep Power: 22 glockcoma will become famous soon enoughglockcoma will become famous soon enoughglockcoma will become famous soon enoughglockcoma will become famous soon enoughglockcoma will become famous soon enoughglockcoma will become famous soon enough
I think I might 2 of the shielded versions of these somewhere in my basement that I used many moons ago.
If I can find them the op can have them for the cost of shipping.
Let me know if your interested
Dragonfish42
glockcoma is offline   Reply With Quote Quick reply to this message
Old 03-02-2017   #22
PPI_GUY's Avatar
Rep Power: 133 PPI_GUY will become famous soon enoughPPI_GUY will become famous soon enoughPPI_GUY will become famous soon enoughPPI_GUY will become famous soon enoughPPI_GUY will become famous soon enoughPPI_GUY will become famous soon enough
OP, what did you finally decide on?
Any update?
Absolutely State Of The Art!
PPI_GUY is offline   Reply With Quote Quick reply to this message
Old 03-02-2017   #23
I bought a single SVC 2 ohm Punch 8" P1, then I just bought a second one. Got them both for $60 on amazon used. I figure if I want cone area 16" is better than 10 Gets decent reviews. Now I have to redesign my box.
Old 03-02-2017   #24
dallasneon's Avatar
Platinum Mobile Audio
Quality Control
Rep Power: 147 dallasneon will become famous soon enoughdallasneon will become famous soon enoughdallasneon will become famous soon enoughdallasneon will become famous soon enoughdallasneon will become famous soon enoughdallasneon will become famous soon enough
NVX NSW104V2 Really nice sub for $60....
SSA Store - NVX NSW104V2: Dual 4 Ohm 10" Subwoofer
Or buy it here for $45
https://www.sonicelectronix.com/item...NSW104-v2.html
dallasneon is offline   Reply With Quote Quick reply to this message
Old 03-07-2017   #25
Rep Power: 21 Wiggler will become famous soon enoughWiggler will become famous soon enoughWiggler will become famous soon enoughWiggler will become famous soon enoughWiggler will become famous soon enoughWiggler will become famous soon enough
Sounds like you already pulled the trigger. In case you saved your receipt and have buyers remorse, consider the JBL Power series P-1000. I had 2 10" GTO series in 1999, they were good, but the power line is above the GTO, and below the GTi series. (don't know if the GTi line still exists) I loved my 10" power series until the drill slipped while installing it in a new box and went through the cone.
Wiggler is offline   Reply With Quote Quick reply to this message
