Retiring from Car Audio...
by AVIDEDTR
Alpine IVA-D106, PXA-H701,...
by Salad Fingers
JL Audio HD900/5
JL Audio HD900/5
by wrcrs24
Tru B4100 Fully Modded
by Black05Hemi
Zapco C2k amps in great...
by Salad Fingers
Morel Supreme Tweeters
by mcgilvrey007
Old 11-27-2009   #1
Rep Power: 0 kepone will become famous soon enoughkepone will become famous soon enoughkepone will become famous soon enoughkepone will become famous soon enoughkepone will become famous soon enoughkepone will become famous soon enough
Send a message via AIM to kepone
Default 2002 Miata with Bose system - What mids and tweeters should I get?
I'm looking to do a budget SQ install in a 2002 Miata LS with the factory Bose system ( which will be ripped out completely )..
I don't need any subwoofer recommendations, the bose system has 8's in the doors already.
I need recommendations of 8's with relatively shallow mounting depths, that are good enough to work in a 2 way setup. Also need recommendations for small form factor tweeters that will preferably fit in the factory upper door locations. The 8's would need to play up to 3khz cleanly if at all possible..
I am undecided if I will go with a passive or active setup, but most likely it will be powered by an Alpine PDX 4.100 or 2.150 and an IDA- X305 for the HU.
This is intended to be a budget setup, not trying to win any competitions, and the system is not my primary focus in this car. I would keep the bose speakers, they sound fine ( and would probably sound better with just an aftermarket HU and amp ), but they run at something retarded like .5 ohm . I have not popped the doors off yet, but from what i've read, the 8's use inverted magnets.
kepone is offline   Reply With Quote
Old 11-27-2009   #2
sam3535's Avatar
Malcontent
Rep Power: 809 sam3535 has a reputation beyond reputesam3535 has a reputation beyond reputesam3535 has a reputation beyond reputesam3535 has a reputation beyond reputesam3535 has a reputation beyond reputesam3535 has a reputation beyond reputesam3535 has a reputation beyond reputesam3535 has a reputation beyond reputesam3535 has a reputation beyond reputesam3535 has a reputation beyond reputesam3535 has a reputation beyond repute
Default Re: 2002 Miata with Bose system - What mids and tweeters should I get?
Long time forum member with some GREAT prices here: http://www.diymobileaudio.com/forum/...udio-se10.html
The IR8's are shallow (less than 3" mounting depth), can play cleanly up to 3khz and take quite a bit of power.
Pioneer - Helix - Kenwood - Fountek - SEAS - xtant - Phoenix Gold
Team EMD - Team Show Kitchen
sam3535 is online now   Reply With Quote
Old 11-27-2009   #3
Rep Power: 52 VP Electricity will become famous soon enoughVP Electricity will become famous soon enoughVP Electricity will become famous soon enoughVP Electricity will become famous soon enoughVP Electricity will become famous soon enoughVP Electricity will become famous soon enough
I long planned on using a set of Hertz Space 8's in a Miata.
musicar northwest portland oregon musicarnw.com
Stop guessing. OEinterface.com
VP Electricity is offline   Reply With Quote
Old 11-27-2009   #4
Weightless's Avatar
Rep Power: 95 Weightless will become famous soon enoughWeightless will become famous soon enoughWeightless will become famous soon enoughWeightless will become famous soon enoughWeightless will become famous soon enoughWeightless will become famous soon enough
You have a good 4" of depth in a Miata door. I too have the blose package in my 99' and they are way shallow. Very reminiscent of the ND8's with the front mounted magnet.
You have many 8's to choose from, budget and x-over points determine which one you can use.
Weightless is offline   Reply With Quote
Old 11-29-2009   #5
94VG30DE's Avatar
Rep Power: 69 94VG30DE will become famous soon enough94VG30DE will become famous soon enough94VG30DE will become famous soon enough94VG30DE will become famous soon enough94VG30DE will become famous soon enough94VG30DE will become famous soon enough
Seems like getting an 8" to play 3kHz and midbass cleanly is going to be a bit of a stretch. But luckily, I don't think you have to. I was looking at the tweeter in the '01 SE (with Bose) this weekend and it seems like the tweeter itself is a 2" diameter cone tweeter. I could be wrong, and I definitely didn't pull the door off, but I was thinking "ok they probably aren't running that 8 past 1,500Hz because that tweeter is huge." I would say take a closer look at your dimension requirements for that tweeter, and go from there.
Originally Posted by alm001 View Post
NO WAY WOULD 100 WATTS EVER WORK, PUT 500WATTS AND DON'T EVER TURN THE VOLUME DOWN.
MY SPEAKERS NEED 50WATTS, I USED TO HAVE A 49WATT AMP, AND THEY WOULDNT EVEN TURN ON. I GOT A 50W AMP AND NOW THEY ARE AWESOME. CANT TURN IT DOWN THO
94VG30DE is offline   Reply With Quote
Old 11-30-2009   #6
Boostedrex's Avatar
DIYMA Sneetch
Zuki Audio
Sales and Customer Service
Rep Power: 112 Boostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really nice
I would suggest PM'ing DS-21 on this forum as he has a Miata with 8's in the doors and he's running a 2-3" full range driver on top of it. He's very sharp and has direct experience with what you're wanting to do. Best of luck to you.
Now if I had to make some driver recommendations for you I would say look at the CSS Trio 8 mated up with the H-Audio X2 "wideband tweeter."
MECA Judge for California
Team DIYMA, Zuki Audio, and Stereo Integrity member
  DIYMA Car Audio Forum » DIY Audio Discussion » System Design - Help Me Choose Equipment For My Car
Buy Car Audio
Car Audio Classifieds
Car Audio Forum
Sound Deadening
