Old 05-11-2011   #1
The A Train's Avatar
Rep Power: 78 The A Train will become famous soon enoughThe A Train will become famous soon enoughThe A Train will become famous soon enoughThe A Train will become famous soon enoughThe A Train will become famous soon enoughThe A Train will become famous soon enough
Send a message via AIM to The A Train
Default Alpine Imprint PXA-H800
It looks like Alpine has noticed all of the complaints people have had with the Imprint processors poor ability to easily get a decent tune, and lack of manual adjustments. The PXA-H800 appears to be one heck of a unit. It has the ability to auto tune for those who like to just plug and play, but it also has the ability to fine tune with: 8 channels each of which has 31 bands of eq, up to 36db/octave slopes, and new tuning software called RoadEQ which automatically correct any road noise issues, in real time. I can't speak of how all of this works because I just installed the PXE-H660 not to long ago. From my research it appears to be in the $700 range. There is a control module, sold seperatly of course, that can be used to make changes on the fly. Its a din sized module that should sell for ~$250. This should be an interesting unit and I anticipate a large following similar to when the MS-8 hit the market.
A late addition to the prestigious CES Innovations Awards, the new Alpine PXA-H800 Processor is a powerhouse of features and technology. The unit has a new version of the acclaimed IMPRINT equalizer technology and provides a range of solutions for the owner of both factory (OEM) sound systems, and aftermarket head units.
As we have covered the current model PXA-H650 in a recent comparison, I thought it would be a great opportunity to have a look at the new version, and it seems all of the shortcomings of the PXA-H650have been addressed and the new PXA-H800 will be well worth a look when it arrives, hopefully in the second quarter of 2011.
Overview
The PXA-H800 has been improved in so many ways, most notably this unit can now allow for manual tuning, just like the old F#1 Status H701. This level of tuning using the new RUX-C800 controller (sold separately), the owner can now personalise their own custom settings from the passenger compartment. The PXA-H800 has the ability to analyse the audio systems acoustical properties and automatically correct the findings, providing premium sound quality. This is accomplished using the supplied omni-directional microphone. This is IMPRINT technology.
IMPRINT Technology
IMPRINT is Alpines advanced system tuning technology, it has the ability to take a speaker level input from most vehicles and provide the user with a level platform for adding aftermarket components, if you already have an aftermarket head unit, IMPRINT can also allow for rca input connections and the owner can make use of the array of processing power. IMPRINT now consists of 5 separate technologies.
■IMPRINT EQ – Automatic tuning technology. Using the omni-directional microphone in various positions in the vehicle the system analyses the data and automatically corrects any problems and then applies the desired target EQ curve.
■AntEQ – This technology removes any factory supplied equalization, leaving a “flat” response to work from.
■RoadEQ – Automatically correct any road noise issues, in real time.
■User Customisation – The user can customise the sound to their liking via manual or automatic tuning using the optional RUX controller or the computer software. Usually the owner would tune automatically, then make minor tweaks manually.
■MediaXpander PLUS – Improves playback from compressed media device such as iPods and can restore the audio data.
A full 4 volts of rca output power is provided for connection to aftermarket amplifiers, this is an increase from 2.7 volts that was offered on the PXA-H650. Increased output signal to noise ratio is the main benefit of the voltage increase.
Specifications
■6 Channel Inputs – Up to 10 volts, both RCA and speaker are provided.
■Dual Optical Inputs – Ai Net and Ai Net Aux.
■8 Channel Outputs – Fully active, 4 volts.
■Equalization – 31 bands per channel.
■Parametric Equalizer – 10 bands on front, rear and centre channel.
■Subwoofer Parametric Equalizer – 5 bands.
■X-Over Slopes – Up to 36dB/octave.
■Signal to Noise Ratio – 110dB Digital / 105dB Analog.
■Digital to Analog Conversion – 24 Bit, high performance.
■DSP – Dual 32-bit floating point operation.
The A Train is offline   Reply With Quote
Old 05-11-2011   #2
rexroadj's Avatar
Rep Power: 108 rexroadj has a reputation beyond reputerexroadj has a reputation beyond reputerexroadj has a reputation beyond reputerexroadj has a reputation beyond reputerexroadj has a reputation beyond reputerexroadj has a reputation beyond reputerexroadj has a reputation beyond reputerexroadj has a reputation beyond reputerexroadj has a reputation beyond reputerexroadj has a reputation beyond reputerexroadj has a reputation beyond repute
Default Re: Alpine Imprint PXA-H800
http://www.diymobileaudio.com/forum/...t-horizon.html
Been a discussion for a while now?
Also the "road eq" is not really "new" per say. It was one of the great features available on the last F#1 setup. It is a great addition to the new H800 though.
I am very excited to see how this unit is? I am waiting to see this and the new 363 from rockford to decide what I am going to put in?
rexroadj is online now   Reply With Quote
Old 05-11-2011   #3
i honestly searched before i posted this, but i must have over looked that thread...
Old 05-11-2011   #4
rexroadj's Avatar
well in all fairness its titled replacement 701 or something to that effect..... It really should have its own title like what you posted.
