Old 05-06-2012   #1
Rep Power: 16 g.costanza will become famous soon enoughg.costanza will become famous soon enoughg.costanza will become famous soon enoughg.costanza will become famous soon enoughg.costanza will become famous soon enoughg.costanza will become famous soon enough
Default 90* out of phase :(
My Camry has an awesome jbl factory stereo but the hu and amp are inseparable. Anyway, ALL I WANTED TO DO was add a sub. I installed a sealed 12 and amp. I tapped into the rear woofers for the speaker level signal for the amp. The problem is that with the sub wired up either at 0 or 180* out of phase with the mains, im getting a lot of cancellation between woofers amd sub. The cars woofers have really good deep bass respsonse, which isnt helping. I imagine that they r either 90 or 240* out of phase. There's really no way for me to hi pass the cars woofers passively. They r 2 ohm...Bass blockers would roll off at like 300hz . I AM NOT GOING TO CHANGE THE FACTORY SYSTEM beyond adding the sub. Any ideas on a way to insert a 90* phase shift? What about a stand alone LOC vs the one built into the amp? Any of those have phase adjustments? This isn't a competition system, btw Thanks!!!
g.costanza is offline   Reply With Quote
Old 05-06-2012   #2
MarkZ's Avatar
Rep Power: 167 MarkZ is just really niceMarkZ is just really niceMarkZ is just really niceMarkZ is just really niceMarkZ is just really niceMarkZ is just really niceMarkZ is just really niceMarkZ is just really niceMarkZ is just really niceMarkZ is just really niceMarkZ is just really nice
Default Re: 90* out of phase :(
What kind of crossover options do you have for the subwoofer? Slope? Continuously adjustable crossover point?
Where, exactly, is the sub located in the car?
MarkZ is offline   Reply With Quote
Old 05-06-2012   #3
chad's Avatar
DIYMA Psychopath
Rep Power: 868 chad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond repute
some amplifiers have variable phase. IIRC there is an all pass filter that continuously adjusts phase also.
There is already likely a HPF on everything else, and it likely slides with volume, compounding the issue.
chad is online now   Reply With Quote
Old 05-06-2012   #4
Diyma Ninja
Rep Power: 156 thehatedguy is a jewel in the roughthehatedguy is a jewel in the roughthehatedguy is a jewel in the roughthehatedguy is a jewel in the roughthehatedguy is a jewel in the roughthehatedguy is a jewel in the roughthehatedguy is a jewel in the roughthehatedguy is a jewel in the roughthehatedguy is a jewel in the roughthehatedguy is a jewel in the roughthehatedguy is a jewel in the rough
18 dB slope.
Done
Old 05-07-2012   #5
Aaron'z 2.5RS/WRX's Avatar
Tap off the front speakers and see if the problem goes away...
Old 05-07-2012   #6
minbari's Avatar
DIYMA super monkey!
Rep Power: 110 minbari is just really niceminbari is just really niceminbari is just really niceminbari is just really niceminbari is just really niceminbari is just really niceminbari is just really niceminbari is just really niceminbari is just really niceminbari is just really niceminbari is just really nice
why only 300hz? bass blocker (IE: HPF) can be made to any freq you like. not sure why you want 90° specifially, but a 6db/oct would give you 90°
Original post whore!
minbari is online now   Reply With Quote
Old 05-07-2012   #7
chad's Avatar
DIYMA Psychopath
I'm wondering how the 90 degree number was chosen, it sounds more of a bass/midbass integration issue rather than a 90 degree phase issue.
Old 05-07-2012   #8
minbari's Avatar
DIYMA super monkey!
ya, not a clue. I suspect if he does get his 90°, it will not fix it, but who knows.
Old 05-07-2012   #9
Diyma Ninja
x2 to the above 2
Old 05-07-2012   #10
envisionelec's Avatar
envisionelec.net
President
Rep Power: 463 envisionelec has a reputation beyond reputeenvisionelec has a reputation beyond reputeenvisionelec has a reputation beyond reputeenvisionelec has a reputation beyond reputeenvisionelec has a reputation beyond reputeenvisionelec has a reputation beyond reputeenvisionelec has a reputation beyond reputeenvisionelec has a reputation beyond reputeenvisionelec has a reputation beyond reputeenvisionelec has a reputation beyond reputeenvisionelec has a reputation beyond repute
A 90° shift is accomplished by using a first order network like a capacitor or inductor. Or using a third order network on one and a second order on the other.
AP (All Pass) filters generally perform the same thing, but only at the crossover frequency.
I've found that the only way to fix this situation is to use time alignment. Related: I used to use a 90° phase shift left to right to move my front stage to the dash - this was well before DSP was affordable. People would always think I had tweeters in the vents (remember those days!?)
"I am one of the ones who contributes, dude....advice, tech support, design, and whatever. Especially the whatever." - cajunner
envisionelec is offline   Reply With Quote
