Aux in causing high-pitch noise through speakers - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 01-09-2008   #1
Bikinpunk
Rep Power: 25976 ErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond repute
Default Aux in causing high-pitch noise through speakers
My friend bought a Pioneer 7800BT (think that's it). He had a shop do the install. Nothing more than a simple h/u install on factory speakers in his 2001 GMC Sierra.
He had them connect his Sirius portable module (that's never had a problem) to the Pioneer's aux in on the back of the deck.
No matter what the volume on the Sirius unit, as you increase the h/u's volume there's a very audible high-pitched whine. It happens when the car's engine is both on & off. It's not alt whine at all. It only does it when playing something through the aux input.
Any ideas what could be causing this?
He took it back to the shop that installed it and they told him "it happens" and that he can't do anything about it. I call BS... sounds like an excuse to me, but I've been wrong before.
Follow my blog:
http://medleysmusings.com/
Time Delay Calculator:
Old 01-09-2008   #2
audioman42's Avatar
Rep Power: 136 audioman42 will become famous soon enoughaudioman42 will become famous soon enoughaudioman42 will become famous soon enoughaudioman42 will become famous soon enoughaudioman42 will become famous soon enoughaudioman42 will become famous soon enough
Default Re: Aux in causing high-pitch noise through speakers
Maybe try grounding it at the battery? I've never used my aux input. I'll test it out tonight and see if I get any noise.
Originally Posted by chad
if you can't get a 2 way to sound good then a 3 way will rape your mother
audioman42 is offline   Reply With Quote Quick reply to this message
Old 01-09-2008   #3
Vestax's Avatar
Blends No. 27
Hi_Fidelity
Lead Installer
Rep Power: 156 Vestax will become famous soon enoughVestax will become famous soon enoughVestax will become famous soon enoughVestax will become famous soon enoughVestax will become famous soon enoughVestax will become famous soon enough
I've seen a lot of situations where the 3.5" jack has different size leads. Those ones where it is too short will always cause noise. Is he going through the IP Bus?
USUC World Champion - Stock System Class. Super Street Division. Special Edition Bose 26 piece speaker system with enhanced ported tweeters. 89.2 db Legal, 89.6 db Outlaw.
Vestax's Install
Vestax is offline   Reply With Quote Quick reply to this message
Old 01-09-2008   #4
Bikinpunk
Apparently it has a rear Aux input, so I'm sure he's going through that.
You could be on to something about the lead not being long enough.
Follow my blog:
Old 01-09-2008   #5
Buzzman's Avatar
Ignition Mobile Hi-Fi
Rep Power: 157 Buzzman has a reputation beyond reputeBuzzman has a reputation beyond reputeBuzzman has a reputation beyond reputeBuzzman has a reputation beyond reputeBuzzman has a reputation beyond reputeBuzzman has a reputation beyond reputeBuzzman has a reputation beyond reputeBuzzman has a reputation beyond reputeBuzzman has a reputation beyond reputeBuzzman has a reputation beyond reputeBuzzman has a reputation beyond repute
This will cure the problem:
http://www.crutchfield.com/S-VderZok...135&search=PAC
Spkrs.: Phass (DTM25 - Tweeter, MD 0580 -Midrange, MD 0875- Midbass). Amps: Phass (RE 4.25 and RE 50). Subwoofer: Custom AudioTechnology Flex Unit 12" powered by TRU B2200S (Op Amp + Cap Upgrades). Head Unit: Eclipse 55090. Processor: Audison Bit One.1 Modified; Cables: Phass SC1 Spkr. cable and Si1 Interconnect.
Buzzman is offline   Reply With Quote Quick reply to this message
Old 01-09-2008   #6
Bikinpunk
^ Band-aid though.
I'd like to know the true cause of this.
Though, I did say that we can swing by BB tomorrow in between class and pick one of those up if he doesn't want to bother with figuring it out. Most likely he won't. I was just hoping to figure it out and maybe save him some $. Oh well. Not my ride, so I guess there's no reason to be anal about it.
Follow my blog:
Old 01-09-2008   #7
Originally Posted by Buzzdg View Post
to help reduce noise caused by a ground loop
Old 01-11-2008   #8
Buzzman's Avatar
^ Band-aid though.
The problem is a ground loop. This item costs $18, so the amount of time spent trying to "figure" out the cause will bear no reasonable relation to the cost of curing it. I had the same noise with My XM radio going into the Aux of my Clarion DRZ9255. This got rid of it. Just by the thing and call it a day.
Old 01-11-2008   #9
Rep Power: 0 Jonathanh35 will become famous soon enoughJonathanh35 will become famous soon enoughJonathanh35 will become famous soon enoughJonathanh35 will become famous soon enoughJonathanh35 will become famous soon enoughJonathanh35 will become famous soon enough
Is the satellite radio hardwired for power? If so, you need to refrence ground on the sirius Power supply. A poor ground would cause a ground loop which would easily become audible in a 3.5mm Aux Jack.
Jonathanh35 is offline   Reply With Quote Quick reply to this message
Plasma Speakers and Flame Speakers cotdt Technical & Advanced Car Audio Discussion 11 11-13-2010 10:24 AM
EQing - pink noise vs. white noise mvw2 Technical & Advanced Car Audio Discussion 12 12-27-2006 12:25 PM
Noise, high pitched and oscillating. What could it be? demon2091tb Technical & Advanced Car Audio Discussion 11 11-14-2006 09:04 AM
Troubleshooting noise... What's next? rbenz27 Technical & Advanced Car Audio Discussion 11 04-08-2006 08:52 PM
