Rear Filling with C-DSP - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 04-21-2017   #1
Rep Power: 0 twizzly will become famous soon enoughtwizzly will become famous soon enoughtwizzly will become famous soon enoughtwizzly will become famous soon enoughtwizzly will become famous soon enoughtwizzly will become famous soon enough
Default Rear Filling with C-DSP
Has anyone played around with getting a decent Rear Fill setup with just a C-DSP?
I've done a fair bit of searching, most of the discussion revolves around the Helix.
as far as i can tell, the C-DSP only does channel summing, so all I can get is L+R and the inverse of that.
so at best it seems all I can do is sum the channels together to get a mono signal, and bandpass it appropriately and delay it either max (15ms or so) or delay it so the stage is centre of the vehicle.
The only other option I have noticed is daisy chaining a 2x4 miniDSP off the outputs of the C-DSP(or any other DSP for that matter) and using the Rear Fill Plugin they have.
has anyone managed to achieve something decent with just the C-DSP?
twizzly is offline   Reply With Quote Quick reply to this message
Old 04-21-2017   #2
Hillbilly SQ's Avatar
Blue Collar Audiophile
Complacent Audio
Incoherent rambler
Rep Power: 251 Hillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond repute
Default Re: Rear Filling with C-DSP
I'm using a 2x4 with mine since I had it laying around. Diyma user Zippy is getting good results with his 360.3 and he said delay on it is less than the c-dsp. The way he explained it to me was he fades all the way to the left and delays the left rear until the left side raises up with good space and then repeats for the right. Don't think he's channel summing or anything. I'd send him a pm and ask him directly though if he doesn't see this thread.
In your case, I'd try it the way Zippy explained it to me (he did a good job with it because I've heard his work with my own ears). And then sum L-R with the negatives of the rears twisted together and each positive connected to the amp and see how that works out with just 15ms of delay. The idea is to simulate reflections that you'd normally get in a really big venue. This usually requires over 20ms of delay. I'm at 24.58ms with my rears.
'14 Grand Cherokee Limited, OEM U-Connect 8.4a, JL Fix 82, c-dsp 6x8, Arc xdi1200.6v2, Soundstream pn4.520d, stock rears controlled properly by minidsp 2x4 with rear fill plug-in, ID15v3, SB Acoustics SB17NRXC35-4, Seas Neo Aluminum...Rearfill done properly is a helluva drug!
The Following User Says Thank You to Hillbilly SQ For This Useful Post:
Souths1der (2 Weeks Ago)
Old 04-21-2017   #3
Jazzi's Avatar
Acoustical Mad Scientist
Rep Power: 84 Jazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura aboutJazzi has a spectacular aura about
The C-DSP allows manual entry of filter coefficients for the input section, right? I saw someone explain this once and it seemed brilliant.
Essentially you invert the polarity of the right channel on the *input* side of the C-DSP. Then you also invert the polarity of all the *output* channels for your right side speakers (sub, midbass, midrange, tweeter). That should give you a net of no change and everything should sound exactly as it did before.
Then you sum the left input channel with the right input channel and assign it to output 1 (or whatever channel you want). Then output 1 will be an L-R signal which is what you want for surround, and you feed that to both of your rear speakers with a y-splitter cable to send the signal to the amplifier. You can go one step further and wire the right rear surround speaker with opposite polarity from the left rear surround speaker so that the "surround" channels are out of phase with eachother too by flipping the + and - wires on the amplifier terminal.
To invert the phase of the right input channel, you need to use the advanced IIR filters section (might be labeled as biquad) and change one of the coefficients from "1" to "-1". I am pretty sure it is the B0 coefficient you want to change, I think.
The Following User Says Thank You to Jazzi For This Useful Post:
1fishman (4 Weeks Ago)
Old 04-22-2017   #4
correct you can input the filter coeffs manually on both sides, input and output.
I'll chase up with minidsp and or google as to how I go about inverting the biquad(as in which coeff to invert).
I won't be able to achieve more than 15ms delay, but it's better than nothing at this moment in time.
Old 4 Weeks Ago   #5
Rep Power: 21 Ziggyrama will become famous soon enoughZiggyrama will become famous soon enoughZiggyrama will become famous soon enoughZiggyrama will become famous soon enoughZiggyrama will become famous soon enoughZiggyrama will become famous soon enough
Trying to wrap my mind around the L-R rear fill concept. Seems like flipping polarity on the input with preamps is hard. It would require hacking the cable itself, right? How about using high level instead as input into the DSP with reversed polarity? That seems easy to do. Then, sum L and R as mono on the output which will produce L-R? My Zapco can sum input channels into an arbitrary out so I can easily create 2 mono channels from that for both rear speakers. Did I get this right?
Sent from my VS986 using Tapatalk
Ziggyrama is offline   Reply With Quote Quick reply to this message
Old 4 Weeks Ago   #6
Complacent Audio
Incoherent rambler
You can do what you're wanting to do by just doing some special wiring at the amp with speaker wires. You simply twist the two negatives for each speaker together and solder, crimp cap, tape, whatever. Then insert to two positives into the positive and negative on an amp channel, or bridged pair of channels. At least I think that's how it works.
Old 4 Weeks Ago   #7
Rep Power: 66 1fishman will become famous soon enough1fishman will become famous soon enough1fishman will become famous soon enough1fishman will become famous soon enough1fishman will become famous soon enough1fishman will become famous soon enough
Helpful tip for sure. I'm bookmarking this i'm thinking i should be able to do this with a Helix P Six also.
If i understand correctly i could use just one channel (G or H) for rear fill. and the other (G or H) channel for subs.
Old 2 Weeks Ago   #8
Bumping this thread. I got my rear channels hooked up to the Zapco DSP last weekend, delayed by 22ms, L and R channels bridged into mono so each speaker is playing the exact same signal in mono. Currently setting the level by ear using the fader. I have to say, I really like the effect. It creates a more spacious sound, with almost no effect on the imaging and staging. The Haas effect is definitely working. I like it. I haven't tried the L-R setup yet, need to review the wiring again to see how that is done.
The question now is, what should the FR curve be for rear fill? Tune to the same curve or roll the highs off at some point?
Old 2 Weeks Ago   #9
Complacent Audio
Incoherent rambler
Wire it up for L-R and then flatten the curve out with rta from around 350-5000. It's what I did and working great so far. A little goes a long way for rear output.
