Current Draw when vehicle is off.. - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 04-01-2008   #1
Rep Power: 114 LS-N-IT will become famous soon enoughLS-N-IT will become famous soon enoughLS-N-IT will become famous soon enoughLS-N-IT will become famous soon enoughLS-N-IT will become famous soon enoughLS-N-IT will become famous soon enough
Default Current Draw when vehicle is off..
Hey guys, I need a little advice.
I have an 06 Lincoln LS. My factory battery went dead, so I put in a Optima Yellow Top. (I had drained the factory battery dead before, so I knew it was just a matter of time).
I brought it in to the dealer, because I was seeing a 2.5 amp current draw
with the car off. (Turns out, it is suppose to do this. After 20 mins the car powers everything down fully. After that the car only has a .40 amp draw at rest). However, they found when my Head Unit and CD changer is hooked up, the total draw is .70 amps (and additional .30 amps).
I have a Kenwood Excelon DPX701 and the 10 disc changer in the trunk. Is
.30 amps an excessive amount of draw for those two components? The wiring looks fine, the radio and changer work fine, and I do not feel any warmth whatsoever from either unit....
Thanks for your help!
J
LS-N-IT is offline   Reply With Quote Quick reply to this message
Old 04-01-2008   #2
pikers's Avatar
Rep Power: 119 pikers will become famous soon enoughpikers will become famous soon enoughpikers will become famous soon enoughpikers will become famous soon enoughpikers will become famous soon enoughpikers will become famous soon enough
Default Re: Current Draw when vehicle is off..
Sounds like standard standby current draw, usually in place to retain clock settings etc. You changer relies on the HU for power (correct?) so that would be additional draw. Nothing to worry about I wouldn't think.
pikers is offline   Reply With Quote Quick reply to this message
Old 04-01-2008   #3
Yes, there is just one cable from the H/U to the changer. For power, signal, controls etc.. Now, the dealer told me an additional .30 amps is enough to drain the battery down after enough hours.
Old 04-01-2008   #4
Rep Power: 118 stalintc will become famous soon enoughstalintc will become famous soon enoughstalintc will become famous soon enoughstalintc will become famous soon enoughstalintc will become famous soon enoughstalintc will become famous soon enough
In my experience anything over .07amps in a newer car is starting to be a concern. 2.5 amps for 20 minutes seems really high. I am not a dealer so maybe I am wrong, but I haven't encountered a vehicle that had that high of a draw that was not a problem. I'd do some more research, but that seems altogether too high.
Finally have a car after 2 years of relying on a motorcycle. System to follow.
stalintc is offline   Reply With Quote Quick reply to this message
Old 04-01-2008   #5
MadMaxSE-L's Avatar
Rep Power: 140 MadMaxSE-L will become famous soon enoughMadMaxSE-L will become famous soon enoughMadMaxSE-L will become famous soon enoughMadMaxSE-L will become famous soon enoughMadMaxSE-L will become famous soon enoughMadMaxSE-L will become famous soon enough
Send a message via Yahoo to MadMaxSE-L
There are alot of cars that have this type of draw; it is the computer/body control modules that draw power for a certain amount of time after the ignition is switched off - usually 10-30 minutes or so and it's no big deal...
I would say that 0.7a is a little excessive though; that's almost an amp of current draw, and I could see that being a possible problem if you don't drive your car everyday/enough...
-Matt
No room for audio on my Gixxer
MadMaxSE-L is offline   Reply With Quote Quick reply to this message
Old 04-01-2008   #6
Thanks guys.. yes, the Lincoln factory spec for my car is a approx. 2.5 amps for 20 mins, then it powers down and I should have a .4 amp draw. I spoke with the tech directly.
If the .3 amp draw from my H/U is excessive, is it defective then? Im certainly not going to pay money to have the H/U looked at, it would probably be cheaper to just buy a new H/U (although I don't want to do that as this one isn't even a year old)
Old 04-01-2008   #7
Rep Power: 127 Foglght will become famous soon enoughFoglght will become famous soon enoughFoglght will become famous soon enoughFoglght will become famous soon enoughFoglght will become famous soon enoughFoglght will become famous soon enough
.4 amps when the car is off and completely shut down?! I can understand the high current draw when the car is first checked as you have to disconnect the battery and install the monitor in between the battery connection, but after 20 mins or so, depending on make/model, normally anything over 50 mA is too much with an aftermarket system.
Wierd. Remind me not to buy a Lincoln.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Foglght is offline   Reply With Quote Quick reply to this message
Old 04-01-2008   #8
Umm.. scratch this.
Lincoln Tech = Idiot.
What he must have meant was milliamps.. not amps. I just did my own test with my calibrated multimeter, and at first yeah it pulls 2 amps. Once everything has clicked off it goes down to .04 amps.. which is .4 milliamps. Not .4 amps. What a spank
Anywho, with the radio and changer hooked up its just under .5 mA. Im not worried with .5mA
Thanks for the info guys.
Old 04-01-2008   #9
Rep Power: 124 rsvchad will become famous soon enoughrsvchad will become famous soon enoughrsvchad will become famous soon enoughrsvchad will become famous soon enoughrsvchad will become famous soon enoughrsvchad will become famous soon enough
Originally Posted by LS-N-IT View Post
Umm.. scratch this.
Deci -> Centi -> Milli
.04 amps is 40 milliamps, not .4 milliamps. I'm sure you are not drawing .5mA, but 50mA sounds reasonable.
rsvchad is offline   Reply With Quote Quick reply to this message
Old 04-02-2008   #10
Yeah your right. My multimeter has more steps on it than I thought it did.. I had the decimal in the wrong spot still.
It is pulling 40 mA with everything off. It is pulling 48 mA when I have all of my equipment is connected, but off.
The 20 min waiting time anytime you touch something sucks.. but at least I know my car is just fine!
Thanks
J
Parasitic current Draw killing battery... poochieone Technical & Advanced Car Audio Discussion 20 10-23-2007 07:23 AM
Help with Current Draw logikalone Technical & Advanced Car Audio Discussion 4 07-25-2007 09:25 PM
Current draw of Neon Tubes? Lightninghoof Technical & Advanced Car Audio Discussion 8 07-03-2007 06:14 PM
Why does a Eclipse XA4000 draw more current then a JBL PX300.4 t3sn4f2 Technical & Advanced Car Audio Discussion 27 03-15-2007 05:15 PM
Voltage/High Current Explanation from TIPS newtitan Technical & Advanced Car Audio Discussion 19 12-23-2005 07:03 PM
