DIY Clarion CeNet Y-splitter cable? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 05-20-2008   #1
Rep Power: 113 batook will become famous soon enoughbatook will become famous soon enoughbatook will become famous soon enoughbatook will become famous soon enoughbatook will become famous soon enoughbatook will become famous soon enough
Default DIY Clarion CeNet Y-splitter cable?
The CCA519 Y-splitter for using two Clarion CeNet changers is $75.
Would it be possible to just splice the end of the cable that came with the second changer onto the existing cable, thus effectively making a Y-splitter out of the two cables?
Anyone ever try this, or have an opinion on whether this would work or not?
Only problem I can see is trying to insulate each separate wire once they are spliced together, and I am assuming that each of the internal wires is color-coded to separate colors.
batook is offline   Reply With Quote Quick reply to this message
Old 05-20-2008   #2
Rep Power: 135 thatvan will become famous soon enoughthatvan will become famous soon enoughthatvan will become famous soon enoughthatvan will become famous soon enoughthatvan will become famous soon enoughthatvan will become famous soon enough
Default Re: DIY Clarion CeNet Y-splitter cable?
You can splice them together. If you take apart the y splitter you will see thats all Clarion did. Just go pin for pin and heat shrin all the connections you will be fine. Careful with the audio wires as they are coax lines.
thatvan is offline   Reply With Quote Quick reply to this message
Old 05-20-2008   #3
Thanks for the reply. By coax lines do you mean like a coax cable, with a layer of foam insulation surrounding the wire core? Why would that require extra care?
Old 05-21-2008   #4
They are regular coax cable. Just real small.
Old 05-22-2008   #5
Fing forums
Seated
Rep Power: 134 Attack eagle will become famous soon enoughAttack eagle will become famous soon enoughAttack eagle will become famous soon enoughAttack eagle will become famous soon enoughAttack eagle will become famous soon enoughAttack eagle will become famous soon enough
And don't forget to readdress the second changer to another 'number'... IIRC correctly they can be set from 1-4 right next to the cenet plug, but it Is/Was SUGGESTED by Clarion in the changer install manual when they first came out that you only use 3 and/or 4. (im guessing the DSP and tv tuner (the only other devices available at the time) used address 1 and 2)
Attack eagle is offline   Reply With Quote Quick reply to this message
The Correct Clarion Optical Cable - DRZ9255 to changer less Technical & Advanced Car Audio Discussion 24 01-03-2016 05:36 PM
Where to buy DIY RCA cable in SF Bay area? old-school Technical & Advanced Car Audio Discussion 20 09-13-2007 12:31 AM
Clarion Optical Cable azngotskills Technical & Advanced Car Audio Discussion 5 09-03-2007 02:11 AM
WTB Clarion CENET or Optical cable 8675309 Car Audio Classifieds 6 03-29-2007 07:13 AM
What speaker cables do you use with your CA18? mojako Technical & Advanced Car Audio Discussion 56 11-04-2005 07:07 AM
