Just realized an EASY way to calculate time delays - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 07-18-2006   #1
Rep Power: 137 notacop will become famous soon enoughnotacop will become famous soon enoughnotacop will become famous soon enoughnotacop will become famous soon enoughnotacop will become famous soon enoughnotacop will become famous soon enough
Send a message via AIM to notacop
Default Just realized an EASY way to calculate time delays
Ok, so my mind is a little hyperactive and I find myself doing whatever I can to keep it occupied, sometimes that involves math.
Long story short, measure the difference in distance from your speakers to your listening position. Calculate the difference in distance from the furthest Speaker to all the others and divide by 13.4 if you measured in inches or by 34 if you measured in CM. The result is the delay in ms that you need to properly setup your time alignment.
Read on below for an in depth discussion of how I came to this.
For example lets say you have a 3 way front stage plus sub and your distances are as follows (in inches)
L Tweeter 24
R Tweeter 33
L Mid 26
R Mid 32
L Midbass 22
R Midbass 23
Subs 45
Then you pick the furthest speaker, in this example that would be the Subs. They will be 0 adjustment on time alignment. So you need to know how much closer these are than the subs, so you can digitally delay them so they appear to the ears as being exactly as far away as the subs.
So you take the 45" the subs are away from you and subtract the distance for each given speaker, this will give you the difference.
L Tweeter 21
R Tweeter 12
L Mid 19
R Mid 13
L Midbass 23
R Midbass 22
Now here is the really easy part..... Simply divide by 13.5. That will give you the delay in ms that you will need to enter. If you are one of those types that likes the metric system, and you just had to measure everything in cm simply divide by 34. How did I come to this math you ask? The speed of sound is 1115 ft per second, and 340 meters per second (rounded the numbers to make them a little easier to work with, a difference as little as this will make less than 0.01ms difference in the end result).
Since speed is distance/time (miles per hour, meters per second etc) we can flip that equasion around to get time. That formula would be time=distance/speed. So we now know the distance and the speed we can calculate for time. To get results in the units we need, we need to convert the speed of sound to either inches per millisecond, or centimeters per millisecond, depending on which measurement system you use. To convert 1115 feet per second to inches per ms, we first multiply by 12 to go from feet to inches, this gives us 13380 inches per second. To go to milliseconds we simply divide by 1000. That gives us the much easier to work with 13.38 number. I use 13.4 for a little simpler calculations. Similar calculations can be made to convert from 340 meters per second to inches per millisecond. Meters to cm you multiply by 100. Seconds to ms you divide by 1000. This gives us 34 cm per second.
I had not read anything that gives as easy of a calculation so I thought I would share this in the hopes it would benefit others.
2007 Honda Civic Si Sedan
Alpine W200 With Sirus and Ipod
Nine.5 on DLS Nobelium 6.2's and prototype 13av.2
notacop is offline   Reply With Quote Quick reply to this message
Old 07-18-2006   #2
Rep Power: 0 Smoked Tails will become famous soon enoughSmoked Tails will become famous soon enoughSmoked Tails will become famous soon enoughSmoked Tails will become famous soon enoughSmoked Tails will become famous soon enoughSmoked Tails will become famous soon enough
Default Re: Just realized an EASY way to calculate time delays
Awesome, thanks for posting. I'm running my 9830 to the stock mids and tweets in my old Vauxhall. I did t/a by fading all the way to the front and listening for what sounded best. Which, BTW, still sounds like crap.
The reason I set it up that way was because the manual made it waaaaaay to difficult to get a grasp on. With your method, I could have saved fifteen minutes of dicking around.
I know that I'll be coming back to this when I get around to doing an install in my car.
Smoked Tails is offline   Reply With Quote Quick reply to this message
Old 07-18-2006   #3
Rep Power: 133 squeak12 will become famous soon enoughsqueak12 will become famous soon enoughsqueak12 will become famous soon enoughsqueak12 will become famous soon enoughsqueak12 will become famous soon enoughsqueak12 will become famous soon enough
Send a message via MSN to squeak12
Sounds good. Also people with Alpines with i-personalize just need to sign in on there and type in some numbers for T/A.
squeak12 is offline   Reply With Quote Quick reply to this message
Old 01-29-2010   #4
Rep Power: 133 savagebee will become famous soon enoughsavagebee will become famous soon enoughsavagebee will become famous soon enoughsavagebee will become famous soon enoughsavagebee will become famous soon enoughsavagebee will become famous soon enough
bump for a useful thread
/\Eclipse 8443><2xCadence 30 Band EQ/\/\ 2xUS Acoustics 2080><Tang Band Bamboo w3/\/\2xUS Acoustics 2150><Dayton RS225/\
/\Elemental Designs 9.1><Elemental Designs 19Ov.2/\
savagebee is offline   Reply With Quote Quick reply to this message
Old 01-29-2010   #5
ncv6coupe's Avatar
Rep Power: 96 ncv6coupe will become famous soon enoughncv6coupe will become famous soon enoughncv6coupe will become famous soon enoughncv6coupe will become famous soon enoughncv6coupe will become famous soon enoughncv6coupe will become famous soon enough
Sub-woofer reference point!!
ncv6coupe is offline   Reply With Quote Quick reply to this message
Old 01-29-2010   #6
Rep Power: 139 Hernan will become famous soon enoughHernan will become famous soon enoughHernan will become famous soon enoughHernan will become famous soon enoughHernan will become famous soon enoughHernan will become famous soon enough
Is not necessary but I use the sub as my 0 reference. I does not hurts.
PD: disable the LP when measuring impulse response.
Under Construction...
Hernan is offline   Reply With Quote Quick reply to this message
Old 01-29-2010   #7
Rep Power: 121 tanakasan will become famous soon enoughtanakasan will become famous soon enoughtanakasan will become famous soon enoughtanakasan will become famous soon enoughtanakasan will become famous soon enoughtanakasan will become famous soon enough
Cool, Garrett! Thanks for the tips!
Robert
'06 Scion xB, 880PRS+Matrix, MMATS 1400.1+13Av2, Zuki Eleets 4+Oz Matrix Elite CS180, Rock (Zed) RA4.55+Oz Matrix Elite CS25, 125 sq/ft eDead v1SE2
tanakasan is offline   Reply With Quote Quick reply to this message
Old 01-29-2010   #8
DynaudioNut's Avatar
Rep Power: 89 DynaudioNut will become famous soon enoughDynaudioNut will become famous soon enoughDynaudioNut will become famous soon enoughDynaudioNut will become famous soon enoughDynaudioNut will become famous soon enoughDynaudioNut will become famous soon enough
I have a DRZ 9255 and I was under the impression you only had to measure the distance you are from each Speaker and convert it over to cm's... Actually, I think this should be my question instead of a response to this thread. Nevertheless, I would like to know is the aforementioned process applies to the DRZ as well.
DynaudioNut is offline   Reply With Quote Quick reply to this message
Old 01-29-2010   #9
The useful thing for this measurement type is on decks that measure out delay in ms, like my eclipse 8443. If its a deck like a lot of pioneers (i think pioneer does this) than you just need to put in the distance from each
Old 01-29-2010   #10
Rep Power: 94 DirtyDog will become famous soon enoughDirtyDog will become famous soon enoughDirtyDog will become famous soon enoughDirtyDog will become famous soon enoughDirtyDog will become famous soon enoughDirtyDog will become famous soon enough
Can't hurt to see what happens. I'll have to see where my delays are currently at compared to the calcs. Only thing that I question is the wavelengths. Wouldn't that make a difference in the time that it reaches you?
This post is reeeaaally old...lol
DirtyDog is offline   Reply With Quote Quick reply to this message
need 4 way active crossover + time delays slow2.2sonoma Technical & Advanced Car Audio Discussion 7 08-10-2006 09:21 AM
time delays slow2.2sonoma Technical & Advanced Car Audio Discussion 8 07-19-2006 11:00 AM
WOW credit checks to use paypal now? WHOA newtitan Technical & Advanced Car Audio Discussion 0 10-27-2005 06:54 PM
