XBL^2 Subwoofers - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 05-19-2009   #1
Rep Power: 105 frankmehta will become famous soon enoughfrankmehta will become famous soon enoughfrankmehta will become famous soon enoughfrankmehta will become famous soon enoughfrankmehta will become famous soon enoughfrankmehta will become famous soon enough
Default XBL^2 Subwoofers
Can someone list the best XBL^2 subwoofers available currently?
I was looking for a 12 or a 15 and I won't be using it to shatter windows or chatter teeth or something. Want it for good old SQ
The Stereo Integrity Mag D2 is absolutely on top of that list. But I was looking for a 4 Ohm DVC sub, and not a 2 Ohm DVC.
The DIYMA R12 (even though it's not XBL^2) is a close contender. But there are some reliability issues with the R12 that have been discussed elsewhere. That, coupled with its high shipping weight (it has to come to me in India!) make it a slightly impractial and unreliable proposition for me.
Please chime in with suggestions! Cheers!
Pioneer DEH-80PRS| Hybrid Audio Legatia L6| Illusion Audio CH-1| Morel Tempo| Adire Koda 10 x 2| DLS Ultimate A3| DLS Ultimate A2| Clarion DPX11551| Polycab 0 Gauge Wiring| Monster Audio XLN701| Dynamat
frankmehta is offline   Reply With Quote Quick reply to this message
Old 05-19-2009   #2
Electrodynamic's Avatar
Approved Vendor
Stereo Integrity
Rep Power: 138 Electrodynamic will become famous soon enoughElectrodynamic will become famous soon enoughElectrodynamic will become famous soon enoughElectrodynamic will become famous soon enoughElectrodynamic will become famous soon enoughElectrodynamic will become famous soon enoughElectrodynamic will become famous soon enough
Default Re: XBL^2 Subwoofers
Other than the Mag v4, the only other contenders are the Shiva-X 12" and the CSS 10". Both of which are rated for considerably less power handling than the Mag and even then 10" needs a similar enclosure size than the Mag v4 and the Shiva-X needs a much larger enclosure.
Electrodynamic is offline   Reply With Quote Quick reply to this message
Old 05-19-2009   #3
James Bang's Avatar
Rep Power: 134 James Bang will become famous soon enoughJames Bang will become famous soon enoughJames Bang will become famous soon enoughJames Bang will become famous soon enoughJames Bang will become famous soon enoughJames Bang will become famous soon enough
Send a message via AIM to James Bang
The thread starter did not state anything about power handling ratings or recommended enclosure sizes, so I don't see why had you used those factors to try and put those products below yours. Not cool.
James Bang is offline   Reply With Quote Quick reply to this message
Old 05-19-2009   #4
Boostedrex's Avatar
DIYMA Sneetch
Rep Power: 174 Boostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really nice
I'd also say that the Exodus subs at DIYCable.com, the JBL WGTi, and the Mag v4 would be the top contenders as well.
What car are they going in and do you have any size limitations for either sub or box? That could easily rule out some of these choices IMHO.
Team Stereo Integrity member
Boostedrex is offline   Reply With Quote Quick reply to this message
Old 05-19-2009   #5
there are NO size limitations! i can go even 3 cu ft! its a sedan with a boot volume of 400 litres! so no sweat :-P
Old 05-19-2009   #6
Boostedrex's Avatar
DIYMA Sneetch
So would you prefer sealed, ported, or an IB alignment? This may very well come down to personal preference for you and what kind of alignment you want to run.
Old 05-19-2009   #7
i would like it sealed. IB might make the bass reproduction slightly boomy and inaccurate.
i would like JUST one sub to do the job.
Old 05-19-2009   #8
ciaonzo's Avatar
Rep Power: 102 ciaonzo will become famous soon enoughciaonzo will become famous soon enoughciaonzo will become famous soon enoughciaonzo will become famous soon enoughciaonzo will become famous soon enoughciaonzo will become famous soon enough
I think with some experimenting you will find the opposite to hold true for a correctly implemented IB setup.
ciaonzo is offline   Reply With Quote Quick reply to this message
Old 05-19-2009   #9
Rep Power: 147 monkeybutt will become famous soon enoughmonkeybutt will become famous soon enoughmonkeybutt will become famous soon enoughmonkeybutt will become famous soon enoughmonkeybutt will become famous soon enoughmonkeybutt will become famous soon enough
If you would like to use all of your 3 cu ft. up then there is this:Creative Sound - Product Details
However, if you like the sound of the Illusion Audio IM-12, you should love the SI MAGv4. The ND12 I previously ran is extremely easy to blend and has tight, articulate bass. The SI is is better in these areas and digs deeper w/ great, clean impact if you run the LP at 100 to 120hz or so. It works well in 1cuft sealed and the weight is considerably lighter than a DIYMA12. IIRC it should be a driver swap for your present sub set up w/ some box volume adjustment.
In terms of the D2 vs D4, this sub may just well be worth acommodating.
monkeybutt is offline   Reply With Quote Quick reply to this message
Old 05-19-2009   #10
mSaLL150's Avatar
Rep Power: 115 mSaLL150 will become famous soon enoughmSaLL150 will become famous soon enoughmSaLL150 will become famous soon enoughmSaLL150 will become famous soon enoughmSaLL150 will become famous soon enoughmSaLL150 will become famous soon enough
Send a message via AIM to mSaLL150
Adire Kodas, if you can find them.
2013 Focus ST - In Progress! - MyFordTouch - Audison - Phoenix Gold - Scanspeak - Dayton - Stereo Integrity
mSaLL150 is offline   Reply With Quote Quick reply to this message
Old 05-19-2009   #11
Rep Power: 171 kappa546 will become famous soon enoughkappa546 will become famous soon enoughkappa546 will become famous soon enoughkappa546 will become famous soon enoughkappa546 will become famous soon enoughkappa546 will become famous soon enough
With little limitations for a sealed enclosure and my choice of ANY driver, I would run a W12GTi in 2cf sealed or W15GTi in 4cf.
Dissent is the highest form of Patriotism
kappa546 is offline   Reply With Quote Quick reply to this message
Old 05-19-2009   #12
Rep Power: 156 Luke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant future
Thats what Winisd models, but in reality they don't need enclosures anywhere near that big, the 15" works well in the JBL recommended 1.6cuft and the 12" is recommended for about 1 or 1.2cuft I believe. I run my 15" in 1.6cuft and it's flat to almost 25hz in car.
Gradually learning to do more and more with less and less until I can do everything with nothing.
Standard operating procedure.. like blowjobs in porn.
Luke352 is offline   Reply With Quote Quick reply to this message
Old 05-19-2009   #13
Luke, I know what JBL recommends and you're right they're GREAT in those enclosures. I've owned and used all the WGTi's in a variety of enclosures and like i said, if i had no size restrictions i'd do the bigger enclosures... they just PHENOMENAL (I seriously would not rule out IB, even better). Shoot, I might as well throw in a vote for a 2.5cf tuned to 26hz ported enclosure (JBL's are just another animal altogether ported) with a 6db HP at ~50-60hz for SQ. UH-MAZING sound and headroom/dynamics like you've never heard.
Old 05-20-2009   #14
Brian Steele's Avatar
Rep Power: 132 Brian Steele will become famous soon enoughBrian Steele will become famous soon enoughBrian Steele will become famous soon enoughBrian Steele will become famous soon enoughBrian Steele will become famous soon enoughBrian Steele will become famous soon enough
You guys aren't listening.
The poster lives in INDIA. Shipping costs for those big-butt subs are going to be killer! His shipping costs are likely to be even worse than mine!
Sigh - I wish at least one manufacturer would at least TRY to do an XBL^2 motor with a neo magnet. Until then, I can only look on and lust, as the shipping costs of those oh-look-at-me-with-my-BIG-magnet drivers simply puts them out way of my reach.
I'm using Infinity 122.7Ws at the moment. $100 each from Sonic Electronix, but cost to me after shipping and duties was just over $250 each (basically the cost of a Mag). And these are drivers with neo magnets. Very light (I can pick up two with one hand easily). Shipping costs for other drivers in the same price bracket were more expensive.
Brian Steele
www.diysubwoofers.org
Brian Steele is offline   Reply With Quote Quick reply to this message
Old 05-20-2009   #15
Rep Power: 149 niceguy will become famous soon enoughniceguy will become famous soon enoughniceguy will become famous soon enoughniceguy will become famous soon enoughniceguy will become famous soon enoughniceguy will become famous soon enough
He could try and find some older used AA Atlas subs....I bought the first 2 12"s and still love them. One in the car since new and the other's going in the HT as soon as I get the amp....
There's a ton of them out there....
Jeremy
niceguy is offline   Reply With Quote Quick reply to this message
Old 05-20-2009   #16
DIYMA Founder
Rep Power: 192 npdang will become famous soon enoughnpdang will become famous soon enoughnpdang will become famous soon enoughnpdang will become famous soon enoughnpdang will become famous soon enoughnpdang will become famous soon enough
Xbl^2 subs vary greatly in quality, just as underhung and overhung motors do. The original Adire Koda's were some of the best that I've used.
Old 05-20-2009   #17
bass_lover1's Avatar
Rep Power: 160 bass_lover1 is just really nicebass_lover1 is just really nicebass_lover1 is just really nicebass_lover1 is just really nicebass_lover1 is just really nicebass_lover1 is just really nicebass_lover1 is just really nicebass_lover1 is just really nicebass_lover1 is just really nicebass_lover1 is just really nicebass_lover1 is just really nice
I've got an Adire Koda motor sitting around here at my house.
I plan to get it re-cone here shortly, if you want it let me know and I'll send it to get built to your needs.
- My Ford Touch - Premium Sony Stereo -
bass_lover1 is offline   Reply With Quote Quick reply to this message
Old 05-20-2009   #18
Rep Power: 112 emperorjj1 will become famous soon enoughemperorjj1 will become famous soon enoughemperorjj1 will become famous soon enoughemperorjj1 will become famous soon enoughemperorjj1 will become famous soon enoughemperorjj1 will become famous soon enough
im surprised no one mentioned the old RE XXX. but brian makes a very good point here
emperorjj1 is offline   Reply With Quote Quick reply to this message
Old 05-20-2009   #19
It weighs in at around 55lbs, so shipping that to India would be pricey.
Old 05-20-2009   #20
ca90ss's Avatar
655321
Rep Power: 246 ca90ss has a reputation beyond reputeca90ss has a reputation beyond reputeca90ss has a reputation beyond reputeca90ss has a reputation beyond reputeca90ss has a reputation beyond reputeca90ss has a reputation beyond reputeca90ss has a reputation beyond reputeca90ss has a reputation beyond reputeca90ss has a reputation beyond reputeca90ss has a reputation beyond reputeca90ss has a reputation beyond repute
There's a JBL distributor in India. No need for international shipping.
ca90ss is online now   Reply With Quote Quick reply to this message
Old 05-20-2009   #21
JJDH's Avatar
mine
manager
Rep Power: 103 JJDH will become famous soon enoughJJDH will become famous soon enoughJJDH will become famous soon enoughJJDH will become famous soon enoughJJDH will become famous soon enoughJJDH will become famous soon enough
critical mass ? http://www.criticalmassaudio.com/
JJDH is offline   Reply With Quote Quick reply to this message
Old 05-20-2009   #22
Compare that to the shipping weight of 12 lbs for the Infinity 122.7W...
Brian Steele
Old 05-20-2009   #23
Then the Gti series is a good bet - if the local prices in India are good.
I got to have a look at a W12Gti (previous version) about a week ago. Solidly built sub. The measured Qts of 0.7+ was a bit disappointing though. Looks like low-Qts drivers are out of fashion now...
Brian Steele
Old 05-20-2009   #24
AudioGizmos
Founder & CEO
Rep Power: 0 invinsible will become famous soon enoughinvinsible will become famous soon enoughinvinsible will become famous soon enoughinvinsible will become famous soon enoughinvinsible will become famous soon enoughinvinsible will become famous soon enough
Sorry for going OFF-Topic but how do Si Magv4 Compare to having 2 ID8v3 subs. I mean are mag4 gonna really shine over 2ID8V3, I am looking for more punchier, tight, bass at the same time should go deep which can be felt if ever when I plan to go loud. Now given power is 250RMS. What's the best pick 2 ID8 or Magv4 at this power?
Thanks.
invinsible is offline   Reply With Quote Quick reply to this message
Old 06-04-2009   #25
Rep Power: 191 Patrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nice
Thanks.
The easiest way to make a sub sound "tighter" and "punchier" is to roll off the low end. That's why vented subs have a reputation for sounding "boomy." It's not the alignment, there's literally TOO MUCH low bass. It's pretty easy to make a vented box sound like a sealed box with a high pass filter.
I actually have this problem with the tapped horn in my car right now, I need to get a mic and an EQ in there to fix it.
And don't try to fix it by ear, that'll drive you mad...
