FS: 3sixty.2, ESK165,...
by soundnoob
FS: Polk Audio MM6501...
by vfparts
Tru B4100 Fully Modded
by Black05Hemi
Zapco C2k amps in great...
by Salad Fingers
Shok Industries Morel...
by jtaudioacc
(2) Arc Audio Black 12...
by Niebur3
Old 10-30-2009   #1
Rep Power: 34 SQ'in will become famous soon enoughSQ'in will become famous soon enoughSQ'in will become famous soon enoughSQ'in will become famous soon enoughSQ'in will become famous soon enoughSQ'in will become famous soon enough
Default adding tweeters to raise image/stage height
Hey Guys,
Here’s my dilemma, I have the Focal polyglass 165V3E component kit setup as my front end setup.
6.5” in the factory door position (triple sound damped and sealed door)
4” & 1” in fiberglass enclosed kick panels (laser aimed to dome light)
Now during my testing phase I made sure everything was set to zero and flat and only played with X/O points and T/A. I got the image centered and sounding great but found the singer sitting on my Head unit. I then proceeded to add a second set of focal tweeters, off axis to the A-pillars (double side taped) to raise the sound stage and that seemed to do the trick.
My question is will it cause more of a problem adding a second set of tweeters to the system as a whole or should I use EQ to bring the sound stage up instead. As these two tweeters are taking up 2 channels on my Audison 4 channel amp where I can use them to double bridge my 3-way instead. I don’t want to waste EQ power to raise stage height when it could be used to fix peaks and valleys in the FR.
Thanks for all the great info on the site guys it’s really helping out to making a better SQ car. I’m going on 12 hours of reading on DIYMA today, took the day of work, lol
Thanks guys
Frank
SQ'in is offline   Reply With Quote
Old 10-30-2009   #2
Rep Power: 91 bobduch will become famous soon enoughbobduch will become famous soon enoughbobduch will become famous soon enoughbobduch will become famous soon enoughbobduch will become famous soon enoughbobduch will become famous soon enough
Default Re: adding tweeters to raise image/stage height
Welcome Frank. Very well put question. Tell us what vehicle you have. Perhaps someone here with that same vehicle can help.
My tweets are in the kicks (van, and there was no way to get stage high enough otherwise). But IIRC from some old (now unavailable) ECA threads you might try aiming the tweeters a little more towards the HU and/or the roof above the HU. Again, IIRC that helped in some vehicles but not in others.
Good luck and give it some time and others will chime in.
bobduch is offline   Reply With Quote
Old 10-30-2009   #3
Thanks bobduch
I have a 2004 cavailer Z24
Old 10-30-2009   #4
TREETOP's Avatar
Rep Power: 64 TREETOP will become famous soon enoughTREETOP will become famous soon enoughTREETOP will become famous soon enoughTREETOP will become famous soon enoughTREETOP will become famous soon enoughTREETOP will become famous soon enough
Another option may be to move your existing tweeters up, rather than adding a second set. Additional tweeters can be added successfully, but it's difficult to get them to work right without cluttering the imaging from the first set. I prefer one set of tweeters.
TREETOP is offline   Reply With Quote
Old 10-30-2009   #5
Mic10is's Avatar
Rep Power: 78 Mic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enough
pics on the kick panels. and XO points etc....
Team DIYMA SQ,2011 MECA SQL Spirit Award
Mic10is is online now   Reply With Quote
Old 10-30-2009   #6
Rep Power: 96 Luke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant futureLuke352 has a brilliant future
How high is your tweeter crossed? You will get a more coherent result moving your current tweeters to the A pillars if they are crossed high enough as above about 4k tweeters are localizable by volume rather then time like you midrange. A second set of tweeters may fix your height but the other issues that come with this aren;t worth it.
Gradually learning to do more and more with less and less until I can do everything with nothing.
Standard operating procedure.. like blowjobs in porn.
Luke352 is offline   Reply With Quote
Old 10-30-2009   #7
At the moment I don't have pics of my kicks because they are being sent off to the body shop at a local dealership to be painted and I just finished making them the other day. Right now nothing is in the car, it was all taken out because I’m doing a total re-design of the system. As for X/O points, the tweeters in the kick panel were connected to the focal 3-way passive crossover and the A-pillar ones I can't remember because I did the testing a few months ago but the X/O was high, around 8k or 10k. Basically making sure it didn't interfere with the main source point only enough to make it seem like the sound stage was up high.
I did realize I can make the main tweeter placed in my a-pillar but from everything I have learned and read is that the tweeter should always be placed beside the mid so that the sound all blends in as one and of course the Kick panel area is great for PLD.
The focal tweeter is very harsh and ear fatiguing, once placed in the kick with the mid the system really came alive and sounded very good for once. I had the tweeter in the door panel and in the sail panel and this by far is the best location I think.
I’m wondering if anyone else has this similar setup and what do they have the imaging tweeter X/O at?
I'm going to try and dig up some old pictures I took when I was in the test phase and post them.
Old 10-30-2009   #8
TBA
Founder
Rep Power: 63 Eric Stevens has a spectacular aura aboutEric Stevens has a spectacular aura aboutEric Stevens has a spectacular aura aboutEric Stevens has a spectacular aura aboutEric Stevens has a spectacular aura aboutEric Stevens has a spectacular aura aboutEric Stevens has a spectacular aura aboutEric Stevens has a spectacular aura aboutEric Stevens has a spectacular aura about
Reverse the polarity of your mids.
Eric
Eric Stevens is offline   Reply With Quote
Old 10-30-2009   #9
I'll give that a try see what happens
Old 10-30-2009   #10
Brian_smith06's Avatar
Rep Power: 64 Brian_smith06 will become famous soon enoughBrian_smith06 will become famous soon enoughBrian_smith06 will become famous soon enoughBrian_smith06 will become famous soon enoughBrian_smith06 will become famous soon enoughBrian_smith06 will become famous soon enoughBrian_smith06 will become famous soon enough
another cavalier owner I also have an 04 ls sport
I dont really have any tips for you though. I still havent gotten all of my stuff in yet. However, within the next couple weeks I am having some a pillars built for my car. From talking to other cavalier owners the a pillar seems to be a pretty solid spot for the car.
Alpine, Eric Stevens, Stinger, Second Skin
Brian_smith06 is offline   Reply With Quote
Old 10-30-2009   #11
Oliver's Avatar
Looney Tunes
Rep Power: 175 Oliver will become famous soon enoughOliver will become famous soon enoughOliver will become famous soon enoughOliver will become famous soon enoughOliver will become famous soon enoughOliver will become famous soon enough
is 39.99 + shipping cheap enough to find out ?
Orion XTR1002 1" 120W XTR Series Tweeter Kit w/CROSSOVR - eBay (item 170371507003 end time Oct-29-09 21:11:35 PDT)
Your Thoughts and your Feelings, become "Your Life"
Oliver is offline   Reply With Quote
Old 10-31-2009   #12
[QUOTE=SQ'in;869053]
QUOTE]
This is true if your using a 2 way system or 3 way system with a low xover point as your tweeter will be playing freq's that are localizable, as it is with that high xover point, PLD or time alignment will have no real effect on the tweeter, level adjustment will though.
Old 10-31-2009   #13
Hey Brian_smith06,
I saw when looking up cavalier installs your thread came up about your driver in the door hitting the panel. I have experience this two, it’s not easy trying to fit a 6.5” into what once held a 4x6 but instead of placing a screw on the baffle to use as a stopper what you can also do is place a few washers under the factory door screws to give you that extra room you need. If you need pics I can provide them for you.
Did I just jack my own thread, lol
Hey a$$hole, ha-ha amazing name…. I already have the second set of tweeters and have been playing around with position so now it’s just a matter if I need to install them or not. No need to buy anything.
Hey Luke352,
The main tweeter in the kick panel is going to play off the 3-way passive provided by focal and I’m guessing they designed the passive so the speakers blend in together. What I might try is disconnecting it and just paying with the A-pillar one and see what I get. I guess if it sounds better then leave it up there. From all my testing so far it sounded the best in the kick panel, I guess I have some more work to do.
Thanks guys for all the help so far…
Frank
Old 10-31-2009   #14
94VG30DE's Avatar
Rep Power: 69 94VG30DE will become famous soon enough94VG30DE will become famous soon enough94VG30DE will become famous soon enough94VG30DE will become famous soon enough94VG30DE will become famous soon enough94VG30DE will become famous soon enough
You might want to read through this thread if you haven't already, there are some good ideas in there that might apply to your install: http://www.diymobileaudio.com/forum/...stage-2-a.html
If you put your tweeters in a little cup like that with some double-sided tape or something, it's pretty easy to move them around the car and see where they sound best.
Originally Posted by alm001 View Post
NO WAY WOULD 100 WATTS EVER WORK, PUT 500WATTS AND DON'T EVER TURN THE VOLUME DOWN.
MY SPEAKERS NEED 50WATTS, I USED TO HAVE A 49WATT AMP, AND THEY WOULDNT EVEN TURN ON. I GOT A 50W AMP AND NOW THEY ARE AWESOME. CANT TURN IT DOWN THO
94VG30DE is offline   Reply With Quote
Old 10-31-2009   #15
rockinridgeline's Avatar
Rep Power: 44 rockinridgeline will become famous soon enoughrockinridgeline will become famous soon enoughrockinridgeline will become famous soon enoughrockinridgeline will become famous soon enoughrockinridgeline will become famous soon enoughrockinridgeline will become famous soon enough
Send a message via Skype™ to rockinridgeline
There are just too many variables for anyone to be able to say "this will work" or "that won't work". You will just have to experiment and discover for yourself what works.
Most have found that a second set of tweets work best crossed over high. The idea is to try and add some high end sparkle to raise stage height, but not overlap too much with what the main tweets are doing. There are a lot of competitors that do it that way. 8 or 10K on the crossover point would be good to try. If you don't have a way of adjusting the volume independently on the extra tweets, look for some adjustable l-pads from parts express. Usually with tweets in the a-pillars, you need to be able to adjust L and R independently of each other.
Stock...for now
rockinridgeline is offline   Reply With Quote
Old 10-31-2009   #16
Yes I did read through that thread and it was amazing I’m def going to try that out.
I think you hit it bang on rockinridgeline, I’m going to make sure they don't interfere with the overall sound but just add that extra sparkle to raise the stage. They are going to be on independent channels and I will have full control of T/A, Level control and X/O. I'm going to first try them out facing each other across the windshield then maybe angle them in towards the windshield (maybe point to the center) see what different that brings to the car.
Frank
Old 10-31-2009   #17
snaimpally's Avatar
Rep Power: 66 snaimpally will become famous soon enoughsnaimpally will become famous soon enoughsnaimpally will become famous soon enoughsnaimpally will become famous soon enoughsnaimpally will become famous soon enoughsnaimpally will become famous soon enough
The problem with running two sets of tweeters is that you are feeding the same material to both sets of tweeters but due to the distances involved, the sound will not arrive at the same time. For example, you will have 2 right signals arriving at different times. This can cause phasing issues and comb filtering. So I would really avoid using 2 tweeters.
I suggest you move the tweeter up to the A-pillars. See my fabrication thread on fabricating inexpensive tweeter pods that look decent. For that matter, you might try both your mids and tweeters up top on your A-pillars.
MazdaSpeed3: DEH-P01
-> DD S4 -> Seas W18NX + Scan-Speak D3004/6020
-> DD M2 -> 2 Boston Acoustics G512-44
snaimpally is offline   Reply With Quote
Old 10-31-2009   #18
Mic10is's Avatar
Eric
thats too simple and makes too much sense. You should recommend he buy more equipment he doesnt need, use more time alignment, use more dampening or a bunch of other things which really wont resolve the problem either
Old 10-31-2009   #19
Harman International
Product Manager
Rep Power: 464 Andy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond reputeAndy Wehmeyer has a reputation beyond repute
Why does it make too much sense? Someone please explain to me how this will have any effect on stage height, unless it simply fills in a hole between the mid and tweeter.
Global Product Line Manager, JBL Car Audio
Harman Consumer
Andy Wehmeyer is offline   Reply With Quote
Old 10-31-2009   #20
Mic10is's Avatar
Could be a phase problem in midrange, which changing phase of one mid, could bring it into phase with the system.
Typically its the passenger side mid w Kick panels
adding "ambient" tweeters is typically a band-aid solution for less than optimal positioning of the midrange driver.
Old 10-31-2009   #21
Rep Power: 0 hotcress will become famous soon enoughhotcress will become famous soon enoughhotcress will become famous soon enoughhotcress will become famous soon enoughhotcress will become famous soon enoughhotcress will become famous soon enough
I remember using a matching tweeter on a simple cap a few years ago as a sail mounted super tweeter to rise my stage. x-over point was like 6k or something like that. Worked for me.
hotcress is offline   Reply With Quote
Old 10-31-2009   #22
Product Manager
Eric didn't say to reverse ONE. Also, reversing ONE is a bad deal, unless you're reversing the polarity of a speaker crossed over so that it only reproduces the band of frequencies that are a problem. This NEVER works with 2-way systems. It'll place the vocals in the center, but it screws up the midbass and moves the first null to a higher frequency. I have NEVER heard a car where this was done that sounded good or imaged properly.
Harman Consumer
Old 10-31-2009   #23
Mic10is's Avatar
I agree completely. but the OP has a 3way.
and knowing Eric, I knew what he meant by saying Mid(s)--he was just imply to try reversing one or the other
Ive heard several 2way that imaged properly from one seat, but had weak midbass response, especially in the 125-250 region.
Old 10-31-2009   #24
Oliver's Avatar
Looney Tunes
Originally Posted by SQ'in View Post
Hey Guys,
Thanks guys
Frank
Eric
Might work in this scenario as the mid is not being used for bass.
Old 11-01-2009   #25
Product Manager
I doubt that the mid is playing 150Hz.
Harman Consumer
  DIYMA Car Audio Forum » DIY Audio Discussion » Technical & Advanced Car Audio Discussion
Buy Car Audio
Car Audio Classifieds
Car Audio Forum
Sound Deadening
