Three nice 10" subs for...
by tyroneshoes
Hybrid Audio Technologies...
by Black05Hemi
FS:  Tang Band, Peerless,...
by sam3535
ODR 10" sub- old school...
by thehatedguy
Change of Plans...Goodies...
by Complacent_One
Morel Supreme Tweeters
by mcgilvrey007
Old 01-09-2007   #1
internecine's Avatar
Rep Power: 92 internecine will become famous soon enoughinternecine will become famous soon enoughinternecine will become famous soon enoughinternecine will become famous soon enoughinternecine will become famous soon enoughinternecine will become famous soon enough
Send a message via AIM to internecine
Default Using a relay to control remote turn on.
i was suggested to use a relay as a possible fix for my amps turning off while in use.
i will be using the remote turn on to control 3-4 amps and a crossover .
so other than a relay purchased at radioshack, is there anything designed specifically for car audio applications?
internecine is offline   Reply With Quote
Old 01-09-2007   #2
coffee_junkee's Avatar
Rep Power: 87 coffee_junkee is a glorious beacon of lightcoffee_junkee is a glorious beacon of lightcoffee_junkee is a glorious beacon of lightcoffee_junkee is a glorious beacon of lightcoffee_junkee is a glorious beacon of lightcoffee_junkee is a glorious beacon of lightcoffee_junkee is a glorious beacon of lightcoffee_junkee is a glorious beacon of lightcoffee_junkee is a glorious beacon of lightcoffee_junkee is a glorious beacon of lightcoffee_junkee is a glorious beacon of light
Default Re: Using a relay to control remote turn on.
A Bosch or similar relay can be had at Autozone or NAPA for cheap. Rat Shack has them too. wire her up like this:
85-Ground
86-Remote turn on from your deck
87-Fused lead from your distro block or other suitable constant +12v
30-Out to all your amps /processors
That shoud get you fixed up bud!!
Kris
Daily: 2007 NHW20 Prius
Toys: 2001 AP1 | 1999 EM1 | 1993 EH2
coffee_junkee is offline   Reply With Quote
Old 01-09-2007   #3
DaveRulz's Avatar
Rep Power: 82 DaveRulz will become famous soon enoughDaveRulz will become famous soon enoughDaveRulz will become famous soon enoughDaveRulz will become famous soon enoughDaveRulz will become famous soon enoughDaveRulz will become famous soon enough
Send a message via AIM to DaveRulz
I have found this helpful in the past
http://www.partsexpress.com/resources/relays.html
04 Mazda6 S: Alpine CDA-9887/160GB iPod - Kappa255a, Kappa 202a, Dayon RS100, RS180, Sub? tweets? - Kicker Hyperflex 1/0
DaveRulz is offline   Reply With Quote
Old 01-09-2007   #4
jeffrey's Avatar
Rep Power: 69 jeffrey will become famous soon enoughjeffrey will become famous soon enoughjeffrey will become famous soon enoughjeffrey will become famous soon enoughjeffrey will become famous soon enoughjeffrey will become famous soon enough
Yep! And you can use 87a for things that require absence of power to activate.
'99 Eclipse GST
Premier P880PRS
a/d/s/ P640.2, P2110.2
a/d/s/ 641is
PPI Pro 10
jeffrey is offline   Reply With Quote
Old 01-09-2007   #5
specs from the amps im using
4 Channel Amplifier4 x 75 watts into 2 ohms, 4 x 50 watts into 4 ohms, 2 x 150 watts bridged mono into 4 ohms, 0.1% THD from 20 to 20kHz. 85 dB signal-to-noise ratio. 20 Hz - 20 kHz frequency response. Number of channels: 2/3/4/5/6. 150 mV - 4V input sensitivity, 10 k ohms input impedance
is that 150mV voltage used by the remote turn on? if so, isnt that kind of high?
Old 01-09-2007   #6
Rep Power: 268 azngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond repute
no thats from your HU via RCAs iirc
azngotskills is offline   Reply With Quote
Old 01-09-2007   #7
DaveRulz's Avatar
no, that 150mv is not the amp turn on voltage. That's the bottom end of the input sensitivity.
Remote turn on runs off of 12 volts. Run the remote wire from your head unit to 86 on the relay. Run a separate fused constant power wire to 87. Ground 85. Connect the remote turn ons for the amps to 30.
This will turn your amps on with your head unit.
Old 01-09-2007   #8
chad's Avatar
DIYMA Psychopath
Rep Power: 835 chad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond repute
Put a Diode in parallel with the coil of the relay to snub back EMF, it's not REALLY needed for mechanical type closures but for semiconductor based turn on circuits like in a stereo it can mean life or death of the circuit.
Chad
chad is online now   Reply With Quote
Old 01-09-2007   #9
chad, i dont really know what you are saying.
put a diode? in parallel? with the coil of the relay.
so i connect somthing to the remote turn on wire before it reaches the relay?
Old 01-09-2007   #10
solacedagony's Avatar
Rep Power: 86 solacedagony will become famous soon enoughsolacedagony will become famous soon enoughsolacedagony will become famous soon enoughsolacedagony will become famous soon enoughsolacedagony will become famous soon enoughsolacedagony will become famous soon enough
Send a message via ICQ to solacedagony Send a message via AIM to solacedagony Send a message via MSN to solacedagony
So I guess the diode would go between 85 and 86?
2003 Ford Ranger Std. Cab
Pioneer P880PRS | Seas Neo/Exclusive 7" | DIYMA12
solacedagony is offline   Reply With Quote
Old 01-09-2007   #11
chad's Avatar
DIYMA Psychopath
In parallel with the coil of the relay The banded side of the Diode should be on the lug with the remote lead, the un-banded side on the side with ground. Use a 1N4001 or better. An 01 will be quite fine for this app though. Just solder it right to the lugs or incorporate it into the plug if using one. Many Bosch style plugs already have the Diode built in
When a relay disengages it can/will produce an EMF pulse sometimes in the order of tens of times the working voltage, sometimes more, transistor based turn on devices don't care for this too much. This is why you will also see diodes across A/C clutches, etc. ALL relays MUST have them in the electronic world for longevity of the driving circuitry.
Don't believe me? Put your fingers across the batery in your car, don't feel squat eh? Now have someone clack the starter and see how fast you get off of that battery Back EMF rearing it's ugly head. This is why they say to unplug your cell phone charger before starting your car. Reverse polarity diodes in amps and accessories do more than protect from reverse polarity
Chad
Old 01-09-2007   #12
Rep Power: 84 BodegaBay will become famous soon enoughBodegaBay will become famous soon enoughBodegaBay will become famous soon enoughBodegaBay will become famous soon enoughBodegaBay will become famous soon enoughBodegaBay will become famous soon enough
If you did a search, you would have found this DIYMA thread in July 2006 that answer your exact questions.
2008 VW GTI 4-Door DSG
BodegaBay is offline   Reply With Quote
Old 01-09-2007   #13
does the amp rating matter much? 1A or 30A?
also, how do i determine what size fuse i should be using?
Old 01-09-2007   #14
chad's Avatar
DIYMA Psychopath
For the diode? Nope, it is for the coil, the amp rating is the rating for the contacts.
For this app the higher the amp rating is not necessarily better. Higher rated relays usually have a higher pull force which equates to more energy needed to pull the contacts down. If you are having problems such as you are now you need as low of current draw on the turn on circuit as possible! The pull force is higher for a faster disconnect to prevent arcing of the contacts under load if they are just creeping away.
Again the remote turn on current required is peanuts for modern gear, unless you are using older relay controlled devices, and I mean OLDER then I don't see why the headunit can't turn the stuff on and keep it on But I've been baffled before!
The link that Bogeda Bay just provided has a tutorial from BCAE SP? that is very good for you to read right now. It will explain ALL of your questions, but we are always willing to help too!
Chad
Old 01-09-2007   #15
Rep Power: 88 SteveLPfreak will become famous soon enoughSteveLPfreak will become famous soon enoughSteveLPfreak will become famous soon enoughSteveLPfreak will become famous soon enoughSteveLPfreak will become famous soon enoughSteveLPfreak will become famous soon enough
Chad
As usual, Chad's correct. Just get this relay from Navone and be done with it.
http://www.autosound2000.com/filters.html
SteveLPfreak is offline   Reply With Quote
Old 01-09-2007   #16
DaveRulz's Avatar
Yup, I learned something. I'm going to have to put a diode on my amp turn on relay.
Old 01-09-2007   #17
Rep Power: 87 khail19 will become famous soon enoughkhail19 will become famous soon enoughkhail19 will become famous soon enoughkhail19 will become famous soon enoughkhail19 will become famous soon enoughkhail19 will become famous soon enough
The only one I see on that page is the N-52R Isolating Relay, second from the bottom of the page. I'm assuming that's the right one?
Alpine 7998*Phass MW160*Clarion APA4320*Peerless 2"*Seas Neo*Next VRz4.400*OZ ME12*PG x400.1
Premier 860MP*PG Zeropoint ZCS6*Pioneer SW-2541D*Sony ES XM-5046
khail19 is offline   Reply With Quote
Old 01-09-2007   #18
well my gear is new, so this relay may not be my fix at all.
but i might as well try it out with this relay because i can pick it up local
http://www.radioshack.com/product/in...entPage=search
and a 7.5 amp fuse before the amps
Old 01-09-2007   #19
Exactly. The N-52R works great, takes care of back EMF, and has a high input impedance.
Old 01-09-2007   #20
chad's Avatar
DIYMA Psychopath
That and the diode will solve the romote turn on voltage drop (with a fuse (1A) on the relay INPUT side of the new turn-on source)
If that don't work your problems are greater
Lose the 7.5 before the amps. If it does not turn on with 1A then something is very wrong unles you are running something H-U-G-E!
Chad
Old 01-10-2007   #21
relay, diode if it dosent have one, and 1A fuse on the remote
thanks chad, reading it on forum posts and bcae1.com are one thing, but additionally having people help with specific questions is a big help
thanks
Old 01-10-2007   #22
chad's Avatar
DIYMA Psychopath
Need a 1A between B+ and the relay contacts (the new turn-on source), a 1A on the remote won't hurt but is not there normally.
7.5A is WAY too much, if you are consuming (popping) 1A as a remote turn on source there are problems somewhere.
Chad
Old 01-10-2007   #23
the 7.5A was from the relay calculator on bcae1.com but that was suggested to go between the relay and the devices being switched on.
Old 01-10-2007   #24
Rep Power: 89 ws6 beat will become famous soon enoughws6 beat will become famous soon enoughws6 beat will become famous soon enoughws6 beat will become famous soon enoughws6 beat will become famous soon enoughws6 beat will become famous soon enough
Send a message via AIM to ws6 beat
what if you dont use the head units remote turn on instead you use ignition with a switch does that still require a diode.
ws6 beat is offline   Reply With Quote
Old 01-10-2007   #25
chad's Avatar
DIYMA Psychopath
Well...... maybe not..... but YES!!!! why risk it? A diode costs a few pennies. Granted the electrical system SHOULD absorb an EMF Pulse of a little relay but IMHO it's not worth it, I mean your starter does not have one, but again, what's a few pennies?
Chad
  DIYMA Car Audio Forum » DIY Audio Discussion » Technical & Advanced Car Audio Discussion
Just added a bosch type relay, now i have a loud turn off pop. internecine Technical & Advanced Car Audio Discussion 21 01-22-2007 06:38 PM
Help, how to wire a remote turn on lead for two amps Stewart Technical & Advanced Car Audio Discussion 34 01-16-2007 12:28 PM
remote level control (for sub) saintb Technical & Advanced Car Audio Discussion 2 01-01-2007 02:50 PM
Remote turn on for Chevy Full-size truck? chuyler1 Technical & Advanced Car Audio Discussion 3 11-22-2006 10:31 PM
remote turn on feedback giantgloworm Technical & Advanced Car Audio Discussion 3 09-07-2006 11:59 AM
Buy Car Audio
Car Audio Classifieds
Car Audio Forum
Sound Deadening
