how to check if Tweeters are in Phase? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 09-30-2010   #1
s4turn's Avatar
Rep Power: 104 s4turn will become famous soon enoughs4turn will become famous soon enoughs4turn will become famous soon enoughs4turn will become famous soon enoughs4turn will become famous soon enoughs4turn will become famous soon enough
Default how to check if Tweeters are in Phase?
I've wondered how people would check this?
mids, midbass, Sub drivers are much easier to check, but tweeters I have never been able to tell
s4turn is offline   Reply With Quote Quick reply to this message
Old 09-30-2010   #2
s4turn's Avatar
Default Re: how to check if Tweeters are in Phase?
ok found an Answer to my own question
http://www.diymobileaudio.com/forum/...-polarity.html
if anyone has any other better ways, id be keen to find out
and would a battery damage a tweeter when doing this?
Old 09-30-2010   #3
bboyvek's Avatar
Rep Power: 108 bboyvek will become famous soon enoughbboyvek will become famous soon enoughbboyvek will become famous soon enoughbboyvek will become famous soon enoughbboyvek will become famous soon enoughbboyvek will become famous soon enough
Something you want to keep in mind is that you want your tweeters to be in ACOUSTIC phase which can be different from their electrical phase.
bboyvek is offline   Reply With Quote Quick reply to this message
Old 09-30-2010   #4
s4turn's Avatar
how do I check if they are in Acoustic phase? and is this referring to the slope used on the x-over point?
Old 09-30-2010   #5
Rep Power: 115 traceywatts will become famous soon enoughtraceywatts will become famous soon enoughtraceywatts will become famous soon enoughtraceywatts will become famous soon enoughtraceywatts will become famous soon enoughtraceywatts will become famous soon enough
acoustic phase is the phase of the wavelength when it reaches your ear(s). high frequency wavelengths are really too short to make this a concern, unless you drive with your head in a vise. just concentrate on relative intensity at this point.
traceywatts is offline   Reply With Quote Quick reply to this message
Old 09-30-2010   #6
bboyvek's Avatar
The slope used only affects the phase at the crossover point. It determines whether you will have a peak or a dip at the crossover point. Acoustic phase has more to do with how far the drivers are from your ears. If you move a speaker further/closer to you its acoustic phase changes in relation to its relative distance to you.
Old 09-30-2010   #7
s4turn's Avatar
so the battery method to test the electrical phase would be recommended? this is so both tweeters are in phase?
Old 09-30-2010   #8
KP
Bulk Sales Pass
KP's Avatar
Rep Power: 422 KP has a reputation beyond reputeKP has a reputation beyond reputeKP has a reputation beyond reputeKP has a reputation beyond reputeKP has a reputation beyond reputeKP has a reputation beyond reputeKP has a reputation beyond reputeKP has a reputation beyond reputeKP has a reputation beyond reputeKP has a reputation beyond reputeKP has a reputation beyond repute
Send a message via AIM to KP
I turn off everything else except the tweets, lower the volume, drop the crossover to 1K and use a verified track to align everything up by ear. Raise the crossover back up, turn everything back on......
KP is offline   Reply With Quote Quick reply to this message
Old 09-30-2010   #9
Bikinpunk
Rep Power: 25981 ErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond repute
exact same thing I do. I actually go a tad bit lower... closer to 800hz. Makes t/a differences easier to tell.
However, I've had good luck lately just using mono pink noise.
FWIW, tweeters are best set by gains. ILD.
Follow my blog:
http://medleysmusings.com/
Time Delay Calculator:
My 2006 Honda Civic LX Sedan Build Log
Old 09-30-2010   #10
s4turn's Avatar
cheers for the replies
might try the lowering of the tweeter x-over
