Alpine PXA-H800 Processor Discussion Thread - Page 44 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 07-14-2011   #1076
Rep Power: 80 ET328 will become famous soon enoughET328 will become famous soon enoughET328 will become famous soon enoughET328 will become famous soon enoughET328 will become famous soon enoughET328 will become famous soon enough
Default Re: Alpine PXA-H800 Processor Discussion Thread
I'm thinking "what setting?!"
Do they mean a f/w setting or what? Either way, it sounds like the problem's been resolved.
I still think that your unit was broken and software update did not fix it. All other users report of white noise with bass sounds but yout problem was different.
But then there is this weird thing, why did some users notice the noise also with P.EQ and some did not? Sadly no one answerer to my firmware version question. Now I noticed, that some user had fw version 1.000, but my unit had 1.001. So did Alpine release even more buggy firmware after the initial version and I was one of the "lucky" ones that had it? This latest fw version is 1.003.
ET328 is offline   Reply With Quote Quick reply to this message
Old 07-14-2011   #1077
Alpine Australia
NSM
Rep Power: 0 Nathan_C will become famous soon enoughNathan_C will become famous soon enoughNathan_C will become famous soon enoughNathan_C will become famous soon enoughNathan_C will become famous soon enoughNathan_C will become famous soon enough
Hi Guys,
To the Alpine Australia customers, we have tested the unit with the new patch and can confirm the resolution of the audio issue. It will be available for download once we have created the instructions for implementation. The dealer absolutely loves the unit and has been enjoying it without the patch but is looking forward to playing with it a little more with the firmware.
Nathan_C is offline   Reply With Quote Quick reply to this message
Old 07-14-2011   #1078
Rep Power: 107 YellowC4S will become famous soon enoughYellowC4S will become famous soon enoughYellowC4S will become famous soon enoughYellowC4S will become famous soon enoughYellowC4S will become famous soon enoughYellowC4S will become famous soon enough
Will the H800 work with the Mobridge DA1000 and will it decode the DD/DTS bitsream from an Audi S5 with B&O?
YellowC4S is offline   Reply With Quote Quick reply to this message
Old 07-15-2011   #1079
Ale555's Avatar
Rep Power: 85 Ale555 will become famous soon enoughAle555 will become famous soon enoughAle555 will become famous soon enoughAle555 will become famous soon enoughAle555 will become famous soon enoughAle555 will become famous soon enough
The question Must Be if the MoBridge can work with the DTS Signal, the H800 can.
The only Unit where I *Know* the DA Works with is the Audison DSPs (As they are Partners in europe). The DA works in the Audi for sure, One guy has it in His Audi allready. He wanted to check if it Works with the Helix DSP.
Ale555 is offline   Reply With Quote Quick reply to this message
Old 07-15-2011   #1080
Alpine Australia
NSM
Hi Guys,
Here is the Alpine Australia link to the update software including install instructions.
Alpine Electronics of Australia
Nathan
Alpine Australia
Old 07-15-2011   #1081
TokoSpeaker's Avatar
TokoSpeaker.com
CEO
Rep Power: 84 TokoSpeaker will become famous soon enoughTokoSpeaker will become famous soon enoughTokoSpeaker will become famous soon enoughTokoSpeaker will become famous soon enoughTokoSpeaker will become famous soon enoughTokoSpeaker will become famous soon enough
Send a message via Yahoo to TokoSpeaker
Alpine Customer Service is excellent.
Thank you for sharing this software V1.003.
Thank you for your help, Mr. Nathan.
TokoSpeaker is offline   Reply With Quote Quick reply to this message
Old 07-15-2011   #1082
I would not use those words. I have seen excellent customer support and Alpine's actions (denial and silence) in this case were far from it.
Old 07-15-2011   #1083
Rep Power: 83 skywolf75 will become famous soon enoughskywolf75 will become famous soon enoughskywolf75 will become famous soon enoughskywolf75 will become famous soon enoughskywolf75 will become famous soon enoughskywolf75 will become famous soon enough
Originally Posted by Nathan_C View Post
Hi Guys,
Nathan
Alpine Australia
Is this update meant for all countries, or only for Australia?
IVA-D800e + SD354 | PXA-H800 Combo | SB6-S + PDX-M6 | L1ProR2 + L3SE + L6SE + Slick40-V3 | A30.01 | 3 * 1m Classic + 2m eKs + 5m Junior | Original One + Original Two | DHA-S690 | TMX-R850 | SC68 + Cap33 + F600 + PSXXL + PCC1000 | Delta Power + Ground Block | BIG 3
skywolf75 is offline   Reply With Quote Quick reply to this message
Old 07-15-2011   #1084
Rep Power: 113 nomed will become famous soon enoughnomed will become famous soon enoughnomed will become famous soon enoughnomed will become famous soon enoughnomed will become famous soon enoughnomed will become famous soon enough
I do not think that H800 have integrated GPS and zone protection like DVD .
nomed is offline   Reply With Quote Quick reply to this message
Old 07-15-2011   #1085
Rep Power: 0 Valkyrie will become famous soon enoughValkyrie will become famous soon enoughValkyrie will become famous soon enoughValkyrie will become famous soon enoughValkyrie will become famous soon enoughValkyrie will become famous soon enough
That's the same file that Alpine Aus got from Alpine Germany, so looks like it's a non-region and/or non-language specific firmware update.
Cheers,
Valkyrie is offline   Reply With Quote Quick reply to this message
Old 07-16-2011   #1086
Another bug, that I talked about earlier, but now I have done better testing:
With master volume set to 0dB (or somewhere between -14 and 0), Euphony or Pro logic switched ON, and you adjust P.EQ or G.EQ to +dB values, H800's output volume is lowered.
This does not happen in stereo mode or rear fill mode. So you get much lower output levels with Euphony & Pro Logic and EQ adjustment works in a silly way unless you lower master level before adjustment.
This may not be a big deal with Alpine HU's but when using car OEM HU and volume control (i.e. H800 set to max vol) this sure is an annoying "feature".
So when will Alpine fix this?
Old 07-17-2011   #1087
Ale555's Avatar
Think about it...if you force the unit to put out max level and then you want "even more" by using + in EQ this can only work with lowering the volume of the other Bands.
Old 07-17-2011   #1088
I still think it's a firmware bug. It doesn't check sound levels, it just lowers output level (and makes master volume's 12-0dB range useless) no matter what EQ frequency you adjust to + values.
If this is a design feature, then why does it not do the same in stereo and rear fill modes? In those modes you just get overload if you adjust EQ way too much (that usually requires stacked EQ bands) and that is the correct way to do it.
Old 07-17-2011   #1089
s4k4zulu's Avatar
Rep Power: 92 s4k4zulu will become famous soon enoughs4k4zulu will become famous soon enoughs4k4zulu will become famous soon enoughs4k4zulu will become famous soon enoughs4k4zulu will become famous soon enoughs4k4zulu will become famous soon enough
looks like its moving along good..i will give it few more months before i jump on one
ipad3-p99rs/krx3/4200se(X2)/8W3
s4k4zulu is offline   Reply With Quote Quick reply to this message
Old 07-18-2011   #1090
I finally installed the PXA-H800 back to my car... And sounds like the H800 has much lower internal dynamic range (or something) than the H701. Output clips (with loud cracking noises vs. H701's soft clipping) at much earlier stage. So I get much lower clean output with the H800 than what I get with H701. Input level adjustment does not help, total usable volumerange is still much lower than with H701.
This is with a system where H800's volume is set to max and oem head unit controls volume.
Old 07-18-2011   #1091
Rep Power: 99 asawendo will become famous soon enoughasawendo will become famous soon enoughasawendo will become famous soon enoughasawendo will become famous soon enoughasawendo will become famous soon enoughasawendo will become famous soon enough
Question Re: Alpine PXA-H800 Processor Discussion Thread
Have you try to readjust your H800 input and output gain setting? Also have you notice the small icon like blinking speaker on your RUX lcd screen when the output clips?
asawendo is offline   Reply With Quote Quick reply to this message
Old 07-18-2011   #1092
H800's gain adjustments do not help, H800 just does not take in and output as much signal as the H701 does. This problem is mostly noticeable with EQ on. For example if you put +9dB at 50Hz (yes, I know, a whopping 9dB), H800 starts to make cracking noises when H700 still outputs clean signal in the same system and listening level. It could very well be, that H700's output is also clipping at that point, but since it does it so cleanly, you don't notice it. But with H800 you surely notice it..
That small output clipping icon usually appears a little late, you already get bad sound breakups before it appears. Input overload does not cause similar cracks, it just clips.
I installed a line driver (my amp does not have input level adjustment) after the H800 and now I get enough gains before this problem arrives. But now there's noise floor problem, I'll have to make a compromise between max output level and noise floor. This, of course, is mainly because in my system H800's volume control is not used.
Old 07-18-2011   #1093
n_olympios's Avatar
Rep Power: 121 n_olympios will become famous soon enoughn_olympios will become famous soon enoughn_olympios will become famous soon enoughn_olympios will become famous soon enoughn_olympios will become famous soon enoughn_olympios will become famous soon enoughn_olympios will become famous soon enough
Why would you need so much output voltage anyway?
Nick
oısɹǝʌǝɹ :ɐʇɐqoɹd snʇɹıʌ
Now stripped out
n_olympios is offline   Reply With Quote Quick reply to this message
Old 07-18-2011   #1094
I'm still using my car's original multichannel amplifier and that is designed to take high level (balanced) input. H701's output was just enough for my listening levels.
Old 07-18-2011   #1095
Smile Re: Alpine PXA-H800 Processor Discussion Thread
I see Bro, because you are not the only one having this issue. I solved this problem by readjusting my power amp gain. Also I can confirmed the H701 have higher clean output before clipping than H800.
Best Regards
Wendo
Old 07-18-2011   #1096
Rep Power: 0 Thrill_House will become famous soon enoughThrill_House will become famous soon enoughThrill_House will become famous soon enoughThrill_House will become famous soon enoughThrill_House will become famous soon enoughThrill_House will become famous soon enough
Just got my H800 and C800 today, cant wait to test them out. Will report back!
Thrill_House is offline   Reply With Quote Quick reply to this message
Old 07-19-2011   #1097
Does anyone know who I should contact at Alpine about that Euphony output level bug? I mean a person that would actually do something about it.
Looks like German Alpine Extranet just deleted my post. I guess it's once again denial and silence treatment by Alpine's technical support.
Problem is this:
With master volume set to 0dB (or somewhere between -12 and 0dB), Euphony or Pro logic switched ON, and you use P.EQ or G.EQ with +dB values, H800's output volume is lowered.
For example: set master volume to 0, start without EQ, switch Euphony ON, set G.EQ or P.EQ ON, adjust one EQ band to +12dB, output level is now also lowered by 12dB. And now master volume control does nothing if adjusted between -12 and 0 dB. Balance also does not work correctly, channel output levels are the same unless you lower master volume below -12dB. Also output levels in x-over setting only have effect after -12 value.
I'm using 0dB setting because I use my car's head unit to adjust volume. This does not happen in stereo mode or rear fill mode, in those modes everything works as it should.
Old 07-20-2011   #1098
ecbmxer's Avatar
Rep Power: 92 ecbmxer will become famous soon enoughecbmxer will become famous soon enoughecbmxer will become famous soon enoughecbmxer will become famous soon enoughecbmxer will become famous soon enoughecbmxer will become famous soon enough
Seems to me that it is designed to be like this so that if you set your amp levels with the EQ flat (all zero), then boost some frequencies afterwards, your not going to clip your amp since you previously set it at 0dB of boost. Can't you just do all your adjustments and then turn up the volume more if needed?
NEW: 2017 Toyota 4Runner ALL STOCK FOR NOW
GONE: 2010 Subaru WRX: H-Audio Enigma, Trinity and Ebony, sealed IDQ10v3, Massive Audio NX5 (sub+midbass) and NX4 (mid+tweet) amps, Alpine INA-W900BT with H100 Imprint, RAAMat/Ensolite, KnuKoncept/DIY wiring
ecbmxer is offline   Reply With Quote Quick reply to this message
Old 07-20-2011   #1099
But it doesn't do it in stereo-mode. Surely it should do it in that mode also if it's a feature and not a bug? If it's a feature, then balance should still work correctly. It also sounds like it limits output on just those channels where you adjust the EQ to + values, so master volume between -12 and 0dB still raises output of other channels. So fader and sub adjustment don't keep their settings.
Sure I can adjust everything for example at -30dB level, then raise master volume until problems appear and then turn up amp gains to compensate lower output. But then I get lower dynamic range/higher noise floor than in stereo mode.
Old 07-20-2011   #1100
t3sn4f2's Avatar
Rep Power: 225 t3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to all
I think it's a feature needed when a .1 channel setup is active. Something about the extra dynamic range (ie gain) the .1 channel needs. IIRC the article below explains this.
The Misunderstood 0.1 LFE Channel in 5.1 Digital Surround Sound
t3sn4f2 is online now   Reply With Quote Quick reply to this message
