Alpine PXA-H800 Processor Discussion Thread - Page 60 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 03-28-2012   #1476
acidbass303's Avatar
Rep Power: 82 acidbass303 will become famous soon enoughacidbass303 will become famous soon enoughacidbass303 will become famous soon enoughacidbass303 will become famous soon enoughacidbass303 will become famous soon enoughacidbass303 will become famous soon enough
Default Re: Alpine PXA-H800 Processor Discussion Thread
Originally Posted by asawendo View Post
I do now what happened in US Version, but for International version after 2 major updates my Alpine PXA H800 working flawlessly without any identified problem.
Best Regards
Wendo
The latest H800 firmware is v1.003, mine is running the same version and still it loses its settings etc if the power wire/harness is unplugged for even a second...
Originally Posted by claytonzmvox View Post
can post the latest update to the PXA? My equipment was purchased in tokospeaker, then it must be equal to its equipment.
http://www.alpine-europe.com/support...re-update.html
Pioneer Dex-P99rs|Morel Elate 6 3W|Helix C-Dsp| JL Audio 12w6v2
Helix Competition A6 | Helix competition A1 | Adcom GFA 4702|McIntosh MC431
acidbass303 is offline   Reply With Quote Quick reply to this message
Old 03-28-2012   #1477
quality_sound's Avatar
Rep Power: 236 quality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nice
Weird, mine doesn't do that. I'll check the software version tomorrow.
Old 03-28-2012   #1478
claytonzmvox's Avatar
Rep Power: 75 claytonzmvox will become famous soon enoughclaytonzmvox will become famous soon enoughclaytonzmvox will become famous soon enoughclaytonzmvox will become famous soon enoughclaytonzmvox will become famous soon enoughclaytonzmvox will become famous soon enough
I was researching and found that latest version is v1.003, but now I was thinking about keeping this response settings. in my case is just the noise that is disturbing!!
Galaxy S4 + MOSCONI 6TO8- SCAN R3004/602000-SCAN 12MU4731T00-SCAN 18W8531G00-GÊNESIS 4CHANNEL- SCAN 30W -DLS A7
claytonzmvox is offline   Reply With Quote Quick reply to this message
Old 03-28-2012   #1479
quickaudi07's Avatar
Rep Power: 120 quickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the roughquickaudi07 is a jewel in the rough
What noise are you getting, is it a ground noise?
quickaudi07 is offline   Reply With Quote Quick reply to this message
Old 03-28-2012   #1480
Yes, a background noise, different from the normal noise or interference caused by wiring of power cables, is a metallic noise. Here in Brazil some friends that use the PXA, said that noise is. And updating the program removes the noise.
Old 03-29-2012   #1481
Rep Power: 97 asawendo will become famous soon enoughasawendo will become famous soon enoughasawendo will become famous soon enoughasawendo will become famous soon enoughasawendo will become famous soon enoughasawendo will become famous soon enough
Smile Re: Alpine PXA-H800 Processor Discussion Thread
Alpine.com*-*PXA-H800 Firmware Update
Bro if you unplugged the device then the hardware is reset but if you follow up the procedure like this
Go to setting like it used to be for example 2 way + Sub or 3 way + Sub (do not change your setting and then follow the setup until it say turn off acc
Just do that and then go to preset and call your memory it will recalled to your previous memory.
asawendo is offline   Reply With Quote Quick reply to this message
Old 03-29-2012   #1482
I'm using 1.003 firmware like yours
Go to setting find input setting turn off what you don't need including digital input. Maybe that can help. Thx
Old 03-29-2012   #1483
He shouldn't have to. Mine doesn't do that. Even disconnected it will retain it's settings.
Old 03-29-2012   #1484
Yeach mine always retained all memory right now (after firmware update) but I always do that before firmware update.
Old 03-29-2012   #1485
csd
owner
Rep Power: 68 Bartbx will become famous soon enoughBartbx will become famous soon enoughBartbx will become famous soon enoughBartbx will become famous soon enoughBartbx will become famous soon enoughBartbx will become famous soon enough
Goodevening,
the early version of the PXH800 did forget its settings, this was cured by the second firmware update, it will ask you to confirm your speaker setup but it will remember the other settings. This confirmation is asked as part of a safety procedure to save tweeters in all active systems. The noise can also come from the setting where you have to choose hi/low input level. I have installed quiet a few pxh800 already in all kind of setups, optical input, speaker input,ai-net and different output systems and have not yet encountered one problem of any kind. Please reset your unit after installation and prior to any programming. Sometimes there can be some processor "pollution" during installation and then you start with a clean install.
Bartbx is offline   Reply With Quote Quick reply to this message
Old 03-29-2012   #1486
Thanks for the tip bro. Its funny that they didn't mention it in the manual. Otherwise my thoughts were the same as this:
Sir, do you have to go through the stated procedure of selecting a speaker output system and then recalling the preset or does your unit retain all the settings and doesn't require any recalling of presets etc?
Originally Posted by Bartbx View Post
Goodevening,
Thanks a lot for the in-depth detail. I will definitely try this the next time I encounter such a situation. It would have really helped if they (Alpine) mentioned it in the manual or the press release. I have a question, how are you guys finding the ImprintEQ? I think the Autotune is pretty decent on this one. Can someone share tips for ideal/best mic locations and levels? ( At one place in the manual it says the mic should be at the ear level and at another place it says to go for shoulder level).
Thanks for the input guys.
Old 03-29-2012   #1487
I'll check tomorrow but I think I might have to redo the output setup.
Old 03-30-2012   #1488
csd
owner
I'm sure you"ll find the correct setup and have fun with your processor, we at least do.The fact about it not or not clear beiing mentioned in the manual , well most of the time manual's are made by specialist who have develloped a product, they know it so well they forget to mention small things that our obvious, at least for them. Discussion treads like this are very helpfull t have feedback or tips from other users.
The question about the Imprint and auto-tune, I never use it. With the fisrst and second one we tried that feature and it sounded rare and ok better than without Imprint, we then tuned the cars manually and it was much better. Don't forget that sound is subjective, everybody prefers other colouring, more frontstage or more rear fill, etc... This is typical a product that you can buy in five minutes and have weeks, months or even years of pleasure with, finding new settings, new combinations and please do experiment with it. Not satisfied, just start over, in one car we nearly spend a week trying out different x-ver points,combinations of 2 channel or 3 channel stereo, etc... Just save them on a laptop and share your findings. I personally like the multichannel setup, try it out, set the pcm mode to 3 channel and listen to your cd's in stereo + center channel mode. Use MX expander when listening to MP3 or Ipod they will sound richer. Greetings from Belgium.
Old 03-30-2012   #1489
csd
owner
One thing about mic placement. I've a 80 page pdf file , from inside Alpine, where they explain every little feature of this phx-800. Please make sure you point your mic upwards, so direct it to the ceeling of your car. DON'T POINT FORWARDS, this is the most common mistake with IMPRINT, a second tip is turn of all amplifier x-overs, bassboost etc.... l. Imprint has to be able to make influence on different settings of your system. Thirth suggestion is place your mic on earlevel and remove the headrests .In some cases his can make a huge improvement in the tuning proces. I'll try to post the parts of the pdf that are usefull for the users of this system.
Old 03-30-2012   #1490
Thumbs up Re: Alpine PXA-H800 Processor Discussion Thread
Please Post it Bro it will be useful for us to learn. Thank you very much!
Old 03-30-2012   #1491
bigguy2010's Avatar
Rep Power: 89 bigguy2010 will become famous soon enoughbigguy2010 will become famous soon enoughbigguy2010 will become famous soon enoughbigguy2010 will become famous soon enoughbigguy2010 will become famous soon enoughbigguy2010 will become famous soon enough
I read about this new processor on the Alpine website. Didn't find anything else new. Does anyone know if they're coming out with any other new amplifiers? Or just PDX still?
2012 F-150 SuperCrew FX4 | JL Audio FiX-86 | JL Audio TwK-88 | Soundstream TN4.900D | Soundstream TN1.1200D | ScanSpeak Illuminator D3004/6020-00 | Audible Physics H6MB | Boston Acoustics G512-44 & GTR12 |
bigguy2010 is offline   Reply With Quote Quick reply to this message
Old 03-30-2012   #1492
It would be very nice and very helpful of you if you do post the insider tips for auto tuning. I remember the same thing happening with my H650 when I had it, the user manual was very ambiguous but a very helpful gentleman on this very forum ( Mr Greg Barnes aka The Baron Groog) sent me a very similar alpine insider guide for tuning and it helped a lot! The H800's manual specifically states that mic orientation is not important and has no effect but there you go, as you stated , it should be placed vertically.. And i will definitely try it with the headrests removed and at the ear level. Thank you very much for your tips mate, really looking forward to the parts of the PDF that you will post up.
Old 03-31-2012   #1493
csd
owner
I'm trying to find out how I can select the pages from the PDF file that are usefull and how to post them here. If anybody can give me some advise on this, I"ll post them as soon as possible. I'll start with the Imprint instructions, they are a step by step guide illustrated with pictures, written in english and there are some very usefull explanations on the technology and how they work.
Old 03-31-2012   #1494
csd
owner
@Bigguy, there will be some new amps coming out, one very nice one the PDX-V9 will be a brand new 5 channel amp. The RMS value for this one 4 x 100+ 1 x 500 at 14,4V and between 2/4Ohms. In the MRX range there will be the MRX-F65, 4 x 110w( 4 Ohm). On the belgian website you can downoad the 2012 catalogue with all the forseen new comings. Greetz.
Old 03-31-2012   #1495
If you want to email the pdf to me and tell me what pages you want I can post them for you.
Old 03-31-2012   #1496
bigguy2010's Avatar
Thank you ! I thought they had something coming out this year. I'll keep an eye on their website over the next few months.
Old 04-03-2012   #1497
Get your hands on it before its gone!
Search results for: 'alpine h800'
Old 04-04-2012   #1498
csd
owner
Ok, I succeeded in splitting the pdf file into several parts, can anyone give me a clue how to get them in this topic. I tried copy,cut and paste but I can't insert them here.I'm sure I'm doing something wrong.
Old 04-04-2012   #1499
Once you reply, click on "Go Advanced"
you will see this
Attach Files
Valid file extensions: bmp doc gif jpe jpeg jpg pdf png psd txt zip
just click on that and select the file that you want to upload ...
Enjoy!
Old 04-04-2012   #1500
csd
owner
Can someone try this link. It should give the explanation and instruction on the Imprint module.Zippyshare.com - 35_pdfsam_pxha800uitleg.pdf
