List of usefull DIYMA threads. - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 12-19-2010   #1
schmiddr2's Avatar
do it yourself
Rep Power: 40115 schmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond repute
Default List of usefull DIYMA threads.
If you have any good thread links post them and I will add them to the list. Covering topics from super noob to technically detailed.
Most Important
Searching the forums effectively
the diyma message
12v Glossary
Crossovers, Gains and Tuning
A Basic Guide to Crossovers
Setting Gains w/o Oscilloscope
- - A Mini Tuning Guide for the Active User - -
A simple way to tune courtesy of cmusic.......
Precision time alignment using only noise tracks and your ears
More Power to clean up midbass? Also, some crackling as I increase volume.
Time Alignment and driver seperation????
How To EQ For Better Sound Staging Without an RTA
How to make your RTA with $100 dlls.
TrueRTA Calibration Tutorial
The RTA thread (Use. Not how to Build one)
Flat Response?
Target Curve Comparison
Does Anyone Understand Cabin Gain
Speaker specs. and Choosing speakers
Picking driver and crossover points
The "Real Deal" with 8 ohm drivers
comprehensive front stage set up
$250 2 Way vs $250 3 Way
'Pro Audio' setup for SQ
'THE' Passive SQ System
QMS, QES, QTS, What makes up a speaker?
Attenuating a Tweeter
Midbass
midbass arrays revisited
Need hard, tight, 6.5 midbass drivers....any suggestions?
looking for specific midbass advice
Rear mounted Midbass - Anyone?
midbass in rear of car
Rear Fill Speakers
Rear Fill: do you use it?
Let's talk about "proper" rear Speaker use.
Hey Werewolf, confusion about L-R...
Rear-fill speakers
Subwoofer specs. and Choosing Subwoofers
Somethings up with db's and cone area...
highish sensitivity sub with low vas/Qts?
given that 'cabin gain' is a reality, do we need a low fs?
Fast Bass, Slow Bass - Myth vs. Fact
Larger Subwoofers = Flabby Bass
Myth: More cone area = deeper/"slower" bass
Underpowering a sub?
Designed for sealed or ported
Is the 12w6v2 good for rock/metal music?
Difference between SQ and SPL Subs
Dual 10" vs a single 12" subs for SQ
Install related
on axis vs. off axis
On Axis vs Off Axis ???
kickpanel speaker locations : pros, cons
Troubleshooting noise... What's next?
Midranges and Midbasses in Sub-Optimum Boxes
What are your best ways to bring up a soundstage?
Why are manufacture recommended enclosure volumes...
Sub facing question
Aiming a subwoofer
Aiming a subwoofer
Aiming a subwoofer
Another fiberglass box tutorial..
Best Place to Aim A-Pillar Tweeters?
Improve Your Soundstage for $2
2008 Yaris Sedan Deadening and Sound System
How To Build Amp Racks, Sub Boxes, Trim Panels, Dashes, Just About Everything!
IB (Infinite Baffle)
Low Qts + eq vs High Qts for IB
IB Speaker Specs
Acoustic Elegance IB15 4ohm car version (Idmax comparison)
anyone want to explan why im reading that a higher Fs is recomended for IB?
How do Fs, Xmax and Qtc affect Free Air Subs?
Qts and IB
What specific specs make an IB woofer, IB'able?
Free air IB subs
What's all this "Q" stuff?
Amplifiers
Can someone tell me/explain exactly what clipping is?
Do all competently designed and level matched amps/head units sound the same?
class a/b or d amp for subwoofer sq?
Is amplifier fusing a measure of true amp power?
Power and Wire
what is the real difference in pwr Wire cca vs ofc vs copper weld
voltage x fuse amp = Power output?
Speaker wire: the facts?
RELAYS; how they work and how to Wire it up...
Best RCA cables?
the science of cables
if quality rca cables are so important.....
The Ten Commandments of Noise Prevention
Various ways to use a basic relay
BIG 3, Caps and General Electric stuff
Capacitors Complete waste of money
JBL FAQ
TECHFLEX 101 A Comprehensive Look At This Product
schmiddr2 is offline   Reply With Quote Quick reply to this message
Old 12-20-2010   #2
60ndown's Avatar
Rep Power: 198 60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute60ndown has a reputation beyond repute
Default Re: Please post links to great DIYMA threads about anything car audio
http://www.diymobileaudio.com/forum/...ed-low-fs.html
Old 12-20-2010   #3
ANT
ANT's Avatar
Rep Power: 369 ANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond reputeANT has a reputation beyond repute
List is looking good so far!
Thanks for stepping up, and gtaking the time to do this!
ANT
ANT is offline   Reply With Quote Quick reply to this message
Old 05-06-2011   #4
Rep Power: 87 littlejuanito will become famous soon enoughlittlejuanito will become famous soon enoughlittlejuanito will become famous soon enoughlittlejuanito will become famous soon enoughlittlejuanito will become famous soon enoughlittlejuanito will become famous soon enough
Here's another good one:
littlejuanito is offline   Reply With Quote Quick reply to this message
Old 11-17-2011   #5
Darth SQ's Avatar
the darkside is loud
Automotive Inspections Services
Rep Power: 208 Darth SQ has a reputation beyond reputeDarth SQ has a reputation beyond reputeDarth SQ has a reputation beyond reputeDarth SQ has a reputation beyond reputeDarth SQ has a reputation beyond reputeDarth SQ has a reputation beyond reputeDarth SQ has a reputation beyond reputeDarth SQ has a reputation beyond reputeDarth SQ has a reputation beyond reputeDarth SQ has a reputation beyond reputeDarth SQ has a reputation beyond repute
Default Re: List of usefull DIYMA threads.
I'm quite fond of this one:
http://www.diymobileaudio.com/forum/...g-repairs.html
Bret
PPI-ART COLLECTOR
"It's amazing how good things sound in print."-Anon
Darth SQ is offline   Reply With Quote Quick reply to this message
Old 11-23-2011   #6
Wesayso's Avatar
When the music's over
Rep Power: 96 Wesayso will become famous soon enoughWesayso will become famous soon enoughWesayso will become famous soon enoughWesayso will become famous soon enoughWesayso will become famous soon enoughWesayso will become famous soon enough
I liked lycan's lessons on stereo in this thread:
http://www.diymobileaudio.com/forum/...revisited.html
But Lycan/werewolf has many more that should be added to this list. I miss his posts
And Andy's EQ lessons starting on page 3 of this thread:
http://www.diymobileaudio.com/forum/...esponse-3.html
Wesayso is offline   Reply With Quote Quick reply to this message
Old 07-11-2012   #7
schmiddr2's Avatar
do it yourself
Thanks for the links everyone. I have added lots of threads, anyone have any gems I've overlooked?
Old 07-11-2012   #8
myhikingboots's Avatar
Rep Power: 84 myhikingboots will become famous soon enoughmyhikingboots will become famous soon enoughmyhikingboots will become famous soon enoughmyhikingboots will become famous soon enoughmyhikingboots will become famous soon enoughmyhikingboots will become famous soon enough
subd
"Man I wish I could listen to some Tatooine, Wind & Fire right now."
myhikingboots is offline   Reply With Quote Quick reply to this message
Old 12-29-2013   #9
REGULARCAB's Avatar
Rep Power: 67 REGULARCAB will become famous soon enoughREGULARCAB will become famous soon enoughREGULARCAB will become famous soon enoughREGULARCAB will become famous soon enoughREGULARCAB will become famous soon enoughREGULARCAB will become famous soon enoughREGULARCAB will become famous soon enough
Not sure if you are still stickying threads here but Time Alignment Phase Calculation Spreadsheet was an amazing read through.
Originally Posted by thehatedguy View Post
If you spend 6500 on a single sub, I will drive to your house and punch you in the balls.
REGULARCAB is offline   Reply With Quote Quick reply to this message
Old 12-29-2013   #10
schmiddr2's Avatar
do it yourself
Thanks. I'll add it. I think this thread needs a makeover. Just need to decide on which categories need to be made and how to label them. Then adding these and even more links.
Old 12-29-2013   #11
REGULARCAB's Avatar
I sit here for 8 hours a day slogging through this forum while im at working waiting for the next patient to check in. I have a list of really good threads that I did not find in your tuning list when I was researching it, I will try to find it.
Old 01-02-2014   #12
schmiddr2's Avatar
do it yourself
Find any of those threads?
Might add this one: Time Alignment Via Tape Measure Site... and a nifty tweak, too.
Old 01-02-2014   #13
REGULARCAB's Avatar
I had a nice little list going but I cant find it. Gimme tonight, if we don't have a bunch of crazies in the ER I'll find em.
Old 01-02-2014   #14
REGULARCAB's Avatar
Alright in my infinite wisdom, ive lost my list. Here are a few that helped me out quite a bit. Not all are tuning related and i know im missing some I will post em if i come across them again. There where 2 i remember that had a ton of good tuning info but i can find em.
Some Patrick Bateman Goodness
Crazy Imaging in a stock system
I liked this one on REW
Rew first encounter
I got a lot of answers in this one, tho I find a lot of it is repeated elsewhere
TA or L/R EQ first
Not sure if you have this one stickied but lots of good technical info on placement.
Another opinion on how to T/A
Better technique ear time alignment
Maybe another one for install related
Anyone tried using one tweeter
This one may deserve a sticky, its pretty bad ass
Sound deadening CLD testing
Lots of Opinions in this one but good debate none the less
Solder or Crimp
I personally like the way you have the categories set up.
Old 01-02-2014   #15
Rep Power: 51 Jcharger13 will become famous soon enoughJcharger13 will become famous soon enoughJcharger13 will become famous soon enoughJcharger13 will become famous soon enoughJcharger13 will become famous soon enoughJcharger13 will become famous soon enough
^^^^ those are all good reads.
2013 Dodge Charger
Stock 8.4n HU - Pac adapter - Helix DSP pro
2x zuki eleets v1 4 channel -
Scan 18w revs, 10f's, Illum r3004
HD 1200/1, 12w7ae
Jcharger13 is offline   Reply With Quote Quick reply to this message
Old 01-02-2014   #16
REGULARCAB's Avatar
subwoofer time alignment thoughts?
Old 03-21-2015   #17
brumledb's Avatar
Rep Power: 38 brumledb will become famous soon enoughbrumledb will become famous soon enoughbrumledb will become famous soon enoughbrumledb will become famous soon enoughbrumledb will become famous soon enoughbrumledb will become famous soon enough
Ones that as a beginner I have found interesting/helpful.
First-timers guide to measuring your system
RTA: Binaural Microphones and their application
A tutorial on gain setting and amplifier power usage
Dummy load Help anyone... --- I am on the fence about this one but it is quite informative toward the end when Andy begins explaining the merit of not using a load when setting amp gains with 'scope
2014 GMC Sierra Crewcab
OEM Headunit-->Helix DSP Pro
Audison 5.1k--->Xtant Tweets, AF GB25, (No subs at the moment)
PG Ti2 1000.4-->GZNK 165SQ
(Proper Acoustic Rear Fill)
brumledb is offline   Reply With Quote Quick reply to this message
Old 03-29-2015   #18
Rep Power: 0 Scufi will become famous soon enoughScufi will become famous soon enoughScufi will become famous soon enoughScufi will become famous soon enoughScufi will become famous soon enoughScufi will become famous soon enough
Havent seen this in your list:
Creating The Perfect Soundstage
which is extracted from:
Scufi is offline   Reply With Quote Quick reply to this message
Old 03-29-2015   #19
Rep Power: 80 cerwinvega_fan will become famous soon enoughcerwinvega_fan will become famous soon enoughcerwinvega_fan will become famous soon enoughcerwinvega_fan will become famous soon enoughcerwinvega_fan will become famous soon enoughcerwinvega_fan will become famous soon enough
Thank you!
cerwinvega_fan is offline   Reply With Quote Quick reply to this message
Old 06-16-2015   #20
Victor_inox's Avatar
UNPLUGGED
Victory Sonics
Owner/ Engineer/Sales/Support
Rep Power: 146 Victor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the rough
So basically everyone can post any thread in this? lovely!
Old 06-16-2015   #21
schmiddr2's Avatar
do it yourself
Yes, of course. Just make sure it either gives answers or informs the reader. But I can no longer edit the OP so once a few more links are posted I'll bug Jason to see if he will add them to the OP.
Old 07-28-2015   #22
Rep Power: 0 Mitsushi will become famous soon enoughMitsushi will become famous soon enoughMitsushi will become famous soon enoughMitsushi will become famous soon enoughMitsushi will become famous soon enoughMitsushi will become famous soon enough
Hey nice list you got there ! Thanks !!!
Mitsushi is offline   Reply With Quote Quick reply to this message
Old 07-28-2015   #23
MDubYa's Avatar
Rep Power: 81 MDubYa has a spectacular aura aboutMDubYa has a spectacular aura aboutMDubYa has a spectacular aura aboutMDubYa has a spectacular aura aboutMDubYa has a spectacular aura aboutMDubYa has a spectacular aura aboutMDubYa has a spectacular aura aboutMDubYa has a spectacular aura aboutMDubYa has a spectacular aura aboutMDubYa has a spectacular aura about
Nice!
Gladen XL's, Helix c63c's, Helix DSP... Waiting to be installed
MDubYa is offline   Reply With Quote Quick reply to this message
Old 11-02-2015   #24
Rep Power: 29 jonah1810 will become famous soon enoughjonah1810 will become famous soon enoughjonah1810 will become famous soon enoughjonah1810 will become famous soon enoughjonah1810 will become famous soon enoughjonah1810 will become famous soon enough
Is there no thread on here about picking a location for your midbass/ tweeters for the best imaging possible?
jonah1810 is offline   Reply With Quote Quick reply to this message
