Sundown Audio E8 - $65 each - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 05-29-2008   #1
Approved Vendor
Sundownz
Rep Power: 210 sundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond reputesundownz has a reputation beyond repute
Default Sundown Audio E8 - $65 each
Re = 3.37 ohms (4 ohm nominal)
Fs = 34.9 hz
Qes = 0.5323
Qms = 6.93
Qts = 0.4943
Vas = 7.6 L
BL = 13.3 N/A
Mms = 127.7 grams
Cms = 162 um/N
Xmax = 12mm one-way linear (70% BL method)
Rated RMS Power = 200 watts
Depth = 4.25"
OD w/ gasket = 8 5/16"
Cut Out = 7"
Sealed Box:
0.280 ft^3 w/ F3 of 50 Hz (Qtc = 0.707)
Ported Box:
0.60 ft^3 tuned to 30 Hz
F3 of 25 Hz
Paypal $65 each to sundownz@sundownaudio.com for one driver.
If you want FOUR of them then send over $240 and they are yours (60 each).
If you want EIGHT of them then send over $440 and they are yours (55 each).
Prices are shipped in the continental USA.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- I DO NOT USE PMs -- Email me at sundownz@sundownaudio.com
sundownz is offline   Reply With Quote Quick reply to this message
Old 05-29-2008   #2
Approved Vendor
Sundownz
Default Re: Sundown Audio E8 - $65 each
This is an intro sale that will be open for a few weeks, by the way.
One picture not included above:
Back plate has gap vents and a pole vent, this little guy has some good thermal potential. This photo is from the prototype (chrome basket) - the production model black finish is smoother as well, as you can see from the new photos.
- Jacob Fuller
Old 05-29-2008   #3
Boostedrex's Avatar
DIYMA Sneetch
Rep Power: 176 Boostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really nice
Nice looking woofer Jacob. How do you think this would do as a dedicated midbass?
Boostedrex is offline   Reply With Quote Quick reply to this message
Old 05-29-2008   #4
Approved Vendor
Sundownz
Efficiency is a bit low for that - as it was optimized as a true subwoofer driver. It also won't like to be played much over 200 Hz.
Basically, if as low as you want to go is mid-bass it's not really optimized for that. It will work fine up to 200 Hz but may not be the *best* choice as a mid-bass driver.
- Jacob Fuller
Old 05-29-2008   #5
W8 a minute's Avatar
Rep Power: 132 W8 a minute is a jewel in the roughW8 a minute is a jewel in the roughW8 a minute is a jewel in the roughW8 a minute is a jewel in the roughW8 a minute is a jewel in the roughW8 a minute is a jewel in the roughW8 a minute is a jewel in the roughW8 a minute is a jewel in the roughW8 a minute is a jewel in the roughW8 a minute is a jewel in the roughW8 a minute is a jewel in the rough
2 questions:
What is the VC config?
Is that rubber gasket around the mounting holes removable?
Knowledge is knowing that a tomato is a fruit. Wisdom is not putting it in a fruit salad.
With proper thrust pigs fly just fine.
W8 a minute is offline   Reply With Quote Quick reply to this message
Old 05-29-2008   #6
Approved Vendor
Sundownz
Originally Posted by W8 a minute View Post
2 questions:
Single 4.
Yes, the gasket is removable.
- Jacob Fuller
Old 05-29-2008   #7
wu501's Avatar
Rep Power: 119 wu501 will become famous soon enoughwu501 will become famous soon enoughwu501 will become famous soon enoughwu501 will become famous soon enoughwu501 will become famous soon enoughwu501 will become famous soon enough
cute lil guys Almost makes me want to do an extra project....
wu501 is offline   Reply With Quote Quick reply to this message
Old 05-29-2008   #8
Approved Vendor
Sundownz
I'm planning several installs around them!
I have a customer that may purchase 64 of them *laughs*
- Jacob Fuller
Old 05-29-2008   #9
wu501's Avatar
(64) 8's would look cool as hell ...if you have that kind of power available.
Old 05-29-2008   #10
Approved Vendor
Sundownz
He plans to use an SAZ-3000D per 16 drivers
- Jacob Fuller
Old 05-29-2008   #11
Rep Power: 119 CJ8501 will become famous soon enoughCJ8501 will become famous soon enoughCJ8501 will become famous soon enoughCJ8501 will become famous soon enoughCJ8501 will become famous soon enoughCJ8501 will become famous soon enough
Send a message via AIM to CJ8501
How do these fair in IB?
CJ8501 is offline   Reply With Quote Quick reply to this message
Old 05-29-2008   #12
Approved Vendor
Sundownz
They model out with a ~55 Hz F3 point. Power handling will go down mechanically, obviously.
- Jacob Fuller
Old 05-29-2008   #13
wu501's Avatar
They seem like a god candidate but I'm sure Jake will chime in soon enough
**nvmd..Jake beat me to it
Old 05-29-2008   #14
Approved Vendor
Sundownz
When testing them before shipment I do so with around 120 watts free-air on my bench to make sure they are okay... I do run a quick burst around 200 watts or so too, to make sure the spider stays glued down. But the actual power handling IB is going to be 100-120 watts or so to get full excursion.
- Jacob Fuller
Old 05-29-2008   #15
Hillbilly SQ's Avatar
Blue Collar Audiophile
Complacent Audio
Incoherent rambler
Rep Power: 253 Hillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond repute
ported wall in a van to take on the boys running fifteenz and eighteenz in spl?
'14 Grand Cherokee Limited, OEM U-Connect 8.4a, JL Fix 82, c-dsp 6x8, Arc xdi1200.6v2, Soundstream tn1.1200d, stock rears controlled properly by minidsp 2x4 with rear fill plug-in, Alumapro Alusonic 12 ported, SB Acoustics SB17NRXC35-4, Seas Neo Aluminum...Rearfill done properly is a helluva drug!
Old 05-29-2008   #16
captainobvious's Avatar
more SQ
Rep Power: 199 captainobvious is a name known to allcaptainobvious is a name known to allcaptainobvious is a name known to allcaptainobvious is a name known to allcaptainobvious is a name known to allcaptainobvious is a name known to allcaptainobvious is a name known to allcaptainobvious is a name known to allcaptainobvious is a name known to allcaptainobvious is a name known to allcaptainobvious is a name known to all
Whats the sensitivity on these ?
Old 05-29-2008   #17
Approved Vendor
Sundownz
That is his idea.
- Jacob Fuller
Old 05-29-2008   #18
Approved Vendor
Sundownz
~80 dB - being that they are optimized for really low frequency duty a high sensitivity with such a low cone area is not an option.
- Jacob Fuller
Old 05-31-2008   #19
Approved Vendor
Sundownz
I put two, ported, in my Dad's truck yesterday
Pretty good result both sound-wise and output-wise. I'm tempted to go meter it *laughs*
Sounds quite good on his typical classic rock music... mid-bass needs serious help to blend, though, as the other speakers are still stock. That is the next step!
- Jacob Fuller
Old 06-05-2008   #20
Rep Power: 113 Audiomechanic will become famous soon enoughAudiomechanic will become famous soon enoughAudiomechanic will become famous soon enoughAudiomechanic will become famous soon enoughAudiomechanic will become famous soon enoughAudiomechanic will become famous soon enough
These drivers look really good! I modeled the specs last night in WinISD and they seem pretty perfect for what I wanting to do. Where might I purchase these E8's?
BTW, My name's Shane and I live in Houston. I'm wanting to install 4 of these in a sealed downfiring box for my '99 Dodge Ram Reg cab. SQ is my goal before SPL.
Pleasure to be a member and meet you all!
Audiomechanic is offline   Reply With Quote Quick reply to this message
Old 06-05-2008   #21
Aaron Clinton's Avatar
Supporting Vendor - SSA
Sound Solutions Audio Inc.
Co-Owner
Rep Power: 151 Aaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really niceAaron Clinton is just really nice
If you want in on the intro-sale price email sundownz@sundownaudio.com.
Aaron Clinton is offline   Reply With Quote Quick reply to this message
Old 06-05-2008   #22
Thank you very much for the info, Denim!
Old 06-05-2008   #23
Approved Vendor
Sundownz
denim is correct, you can e-mail me about it.
If you have a Paypal account I do accept Paypal.
- Jacob Fuller
Old 06-09-2008   #24
Approved Vendor
Sundownz
This will run until the 20th.
- Jacob Fuller
Old 06-10-2008   #25
Approved Vendor
Sundownz
nismos14 is working on a review of these installed IB
- Jacob Fuller
Journey in Car Audio (info-rich for Beginners!!!) Part 1 artcali Technical & Advanced Car Audio Discussion 41 06-20-2010 10:31 PM
FS Arc SE, 880PRS, OZ, Alto Mobile, Massive Audio Melodic Acoustic Car Audio Classifieds 13 06-19-2008 01:14 PM
Does anyone have a phone number for Jacob (Sundownz) at Sundown Audio? grampi Technical & Advanced Car Audio Discussion 6 05-06-2008 08:32 PM
Hybrid audio clarius haibane Technical & Advanced Car Audio Discussion 1 03-01-2008 06:42 PM
Arc Audio KAR vs. JL Audio Slash ducrider Technical & Advanced Car Audio Discussion 0 01-30-2008 09:14 PM
