Andy's 2014 Honda Accord Sport - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 07-10-2016   #1
FunkPnut's Avatar
Rep Power: 145 FunkPnut will become famous soon enoughFunkPnut will become famous soon enoughFunkPnut will become famous soon enoughFunkPnut will become famous soon enoughFunkPnut will become famous soon enoughFunkPnut will become famous soon enough
Default Andy's 2014 Honda Accord Sport
I wasn't planning on posting a build because of the amount of other 9th generation Accord builds floating around, but I guess what's one more.
Hopefully it helps out another Accord owner.
This is my 3rd major build, so still learning. Luckily there are some extremely smart 9th generation owners on Drive Accord that have helped me out.
More to come.
2014 Honda Accord Sport MT | Audio Build Log:
Alpine CDE-HD149BT • PDX F4 • F6 • M12 • Helix DSP
AudioFrog GB10 • GB25 • GB60 • IDMAX15 (IB)
FunkPnut is offline   Reply With Quote Quick reply to this message
Old 07-10-2016   #2
FunkPnut's Avatar
Default Re: Andy's 2014 Honda Accord Sport
There's a non-defeatable HPF on the stock head unit and these can't be replaced without losing some important features of the car.
The most acceptable solution for me was to add an Alpine CDE-HD149BT in the lower dash pocket (kudos to keep_hope_alive for the idea).
I used this diagram to build a bypass harness with Metra 70-1729 and 71-1729 adaptors to avoid cutting into stock wiring.
I've since relocated the USB cord to behind the dash so I could put a voltage meter in the 12v accessory plug.
Old 07-10-2016   #3
FunkPnut's Avatar
Amp rack mounted on the rear deck.
1/4-20 threaded rivnuts to hold everything in place.
I used 1/2" MDF to create the amp rack. The rear deck is not completely flat, so you can see there are 2 pieces of 3/4" MDF spacers near the sides so that all mounting locations were solid.
Amp rack just fits Alpine PDX F4 (tweeters and midrange), F6 (bridged to mid bass), M12 (sub), Streetwires CBR44M and a Helix DSP.
A bunch of 8-32 T-nuts were used to avoid from the MDF stripping.
Old 07-10-2016   #4
FunkPnut's Avatar
Not a whole lot to see as far as wiring goes... just tried to follow stock wiring runs.
Ran some 2/0 welding wire I got in a trade to power the system. Too big to fit under the side trim panels, but there is a hole at the bottom of the driver's side seat that allowed me to get it in back.
Old 07-10-2016   #5
FunkPnut's Avatar
The tin can doors needed a lot of attention.
3/4" HDPE speaker rings.
DB3 MLV from Home Depot held in with bolts. Again I used 8-32 threaded rivnuts. Installed Hertz ML1600.2 in the doors and they sounded great.
ScanSpeak D3004 tweeters for the sail panels.
Fits perfectly!
Tried some SI TM65's for a while, but eventually put the Hertz back in and was much happier.
And then I bought a pair of AudioFrog GB60's from a DIYMA member. Although I didn't pay anywhere near retail for them, its still been the most expensive mid I've run to date... no need to explore other speakers.
Old 07-10-2016   #6
FunkPnut's Avatar
Sound dampened the rear deck and covered in CCF (not pictured).
After hearing another member's sick IB install, there was no question that it needed to happen in my car.
Sealed off the stock speaker locations with MDF. Played around with my friend's table router to copy the stock speaker shape.
Old 07-10-2016   #7
FunkPnut's Avatar
Test fitting an IDMAX15... its huge and heavy.
Cut a hole in the arm rest of the back seat to allow bass to flow through.
I had to build a new floor piece to accommodate the baffle depth. I made a bone head mistake and didn't mount the sub high enough.
Because of the angle and depth of the sub, the magnet sat below the floor piece by about 1/4" inch. You can see how I accommodated for this (not very noticeable unless you're looking for it).
I eventually put an all weather trunk liner back there, so the floor looks a lot better now.
Old 07-10-2016   #8
WhereAmEye?'s Avatar
Rep Power: 90 WhereAmEye? will become famous soon enoughWhereAmEye? will become famous soon enoughWhereAmEye? will become famous soon enoughWhereAmEye? will become famous soon enoughWhereAmEye? will become famous soon enoughWhereAmEye? will become famous soon enoughWhereAmEye? will become famous soon enough
I'm glad you did post it, it all looks really good! Good job. I'm in for further potential changes lol.
2017 Civic Hatch
Dayton dsp, AV 5.1k, SI RM12, Stevens SA-6s
WhereAmEye? is offline   Reply With Quote Quick reply to this message
Old 07-10-2016   #9
FunkPnut's Avatar
The sub sounds amazing and has plenty of output for my needs, although getting swapped out soon.
However, there were a couple of buzzes coming from the roof that were driving me crazy.
The headliner just fits out of the rear passenger door.
Added some heat barrier.
First time sound dampening a roof and was only thinking that I'd kill any rattles and reduce some wind noise up there.
I was pleasantly surprised that the bass clarity and overall sound improved! I'm a believer now.
Old 07-10-2016   #10
FunkPnut's Avatar
I was planning on running a 3-way in the car, just didn't have time for a while.
Here are some A-pillars that I worked on, but ultimately ended up going a different direction.
Originally I planned for Audible Physics AR3's in the A-pillars.
Laser jig I made. I eventually made a new jig with this laser and flush mounted it (much better accuracy):
https://www.amazon.com/gp/product/B00X356WZQ/
Testing to see where the stock tweeter were aimed.
Don't be an idiot like me and fiberglass to the bottom edge of your A-Pillars if you want them to fit back in your car.
Old 07-10-2016   #11
FunkPnut's Avatar
Thanks! Haha, I've already determined my final changes so I can just finish up and focus on tuning.
Old 07-10-2016   #12
FunkPnut's Avatar
More bad/expensive decisions.
I found some AudioFrog GB25's for a good price.
Test fitting.
Somehow I got to this point in only a few hours (doing them twice helps ).
The additional depth of the stage was great and the stage was pillar-to-pillar, which is generally typical for these types of installs. I could've probably buried the speakers a little more into the A-Pillars due to them being bite-size.
The tweeters in the sail panels definitely helped by adding a few sound cues of additional width.
Old 07-10-2016   #13
FunkPnut's Avatar
I had always wanted to try midranges in the sail panel location and because of the size and volume requirements of the GB25's, it was doable.
I contacted Andy at AudioFrog and he amazingly sent me a complete set of mounting hardware and answered my potential install questions. Awesome customer service.
Not too many pictures as I was trying to crank these out quick.
Used some SEM Texture Coating
I eventually wet sanding them with 600 grit and the final texture looks very OEM in my opinion.
Just need to find the grills...
The Following User Says Thank You to FunkPnut For This Useful Post:
Chris12 (11-16-2018)
Old 07-10-2016   #14
FunkPnut's Avatar
And this brings us up to today.
I have 2 more planned bad decisions.
Here is one of them.
Bought a pair of AudioFrog GB10's with a minor discount off of retail from a member on here. The Scans would've worked equally as well, but the matched aesthetics of the AudioFrogs was worth a few extra dollars to me.
Started A-Pillar #3 for this build on Friday. Again, minimal pics during a speed build out.
Because I really really really want these to be the last A-Pillars I need to dink around with for this build, I did extensive testing and I think just above the dash hump and pointed a bit off access sounded best to me.
Just waiting for some grill cloth to arrive.
Hope you've enjoyed my good and bad decisions as of date.
More to come in the last stretch of the build.
Old 07-10-2016   #15
Babs's Avatar
Rep Power: 214 Babs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the rough
Holy smokes man!!
K I'm inspired now.
Frogs!!! Love em!
2008 Civic Si Sedan - Fiio X5ii SPDIF, Phone USB HEC, Helix DSP Pro-2, Helix Director, Zapco Z150.6 LX, Z400.2 LX, Acoustic Elegance SBP12 (2)
Build Log
Old 07-10-2016   #16
Babs's Avatar
I love everything about this build. That amp rack is a big ole win!
Build Log
Old 07-10-2016   #17
Niebur3's Avatar
High Definition Mobile Audio
Rep Power: 341 Niebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond repute
Subscribed. Amy good things going on here....lol!
Old 07-10-2016   #18
strong*I*bumpin's Avatar
Rep Power: 184 strong*I*bumpin will become famous soon enoughstrong*I*bumpin will become famous soon enoughstrong*I*bumpin will become famous soon enoughstrong*I*bumpin will become famous soon enoughstrong*I*bumpin will become famous soon enoughstrong*I*bumpin will become famous soon enoughstrong*I*bumpin will become famous soon enough
Awesome install.So basically the stock HU is dead correct?
‘19 Subaru “Big A” Ascent
Wife - “Please leave the stereo alone!”
strong*I*bumpin is offline   Reply With Quote Quick reply to this message
Old 07-10-2016   #19
FunkPnut's Avatar
Hey thanks guys for the kind words!
Old 07-10-2016   #20
FunkPnut's Avatar
Appreciate it.
It still runs the backup camera, active fuel gauge screen and controls the vehicle settings.
All of the audio including the bluetooth phone runs through the Alpine head unit.
There is an updated Metra dash kit available now that is suppose to actually work and retain most of the features that are only available with the stock head unit installed.
Old 07-10-2016   #21
Originally Posted by FunkPnut View Post
Appreciate it.
Cool but does it still illuminate?...Looks like it doesn't in the pic. I have an '11 any aftermarket radio looks like shit and the top display is useless unless you have the upper model Accord where the clock and temp is still displayed.
Old 07-10-2016   #22
FunkPnut's Avatar
Oh gotcha.
Yes, it does illuminate if I turn the radio on, but all it does is draw power, so I just leave it off.
Really its wasted space on the dash at this point.
I am running out of time this summer, but I was going to see if I could move the radio back 2 inches into the dash and mold a removable tablet to sit in front of it flush with the vents. Could just pop out the tablet and have access to the stock radio's controls.
Old 07-10-2016   #23
Oh gotcha.
That's a killer idea with the tablet.Yes summer does seem to go fast ,to bad winters don't do the same.
Old 07-10-2016   #24
Rep Power: 122 edouble101 will become famous soon enoughedouble101 will become famous soon enoughedouble101 will become famous soon enoughedouble101 will become famous soon enoughedouble101 will become famous soon enoughedouble101 will become famous soon enoughedouble101 will become famous soon enough
Looks great!
I am surprised you were able to remove the headliner easily.
edouble101 is offline   Reply With Quote Quick reply to this message
Old 07-11-2016   #25
FunkPnut's Avatar
Originally Posted by edouble101 View Post
Looks great!
Thank you.
I talked to another Accord owner who had removed theirs, which took a lot of guess work out of it.
Its now on my "have to do" list for all future cars.
