2007 Nissan Frontier SQ/stealth install - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 1 Week Ago   #1
Dirtboy's Avatar
Rep Power: 109 Dirtboy will become famous soon enoughDirtboy will become famous soon enoughDirtboy will become famous soon enoughDirtboy will become famous soon enoughDirtboy will become famous soon enoughDirtboy will become famous soon enough
Default 2007 Nissan Frontier SQ/stealth install
After being spoiled with the Audiotek Fischer DSP in my BMW M2 audio install, I decided to update the audio in my daily ride; a 2007 Nissan Frontier.
When I got the truck in 2015 all it had was the stock single disc headunit and four POS paper speakers. I swapped the headunit out for a OEM Nissan 6 disc/MP3 player and replaced all the speakers and added 2 amps, tweeters, and a sub.
First install parts:
Alphasonik Q2150 amp
Rockford Fosgate amp (not sure the model)
Boston Acoustics Pro60SE front speakers
Boston Acoustics S65 rear speakers
Pioneer TS-SW2002D2 8 sub + UD-SW200D enclosure
All those improvements sounded good; until I did the M2 install
So I gathered up all the stuff I wanted this time around.
AudioEngine B1 bluetooth receiver
Helix P Six DSP Mk2 amp + Director
CDT ES-02 tweeters
Audiofrog GS690 mids
Earthquake Audio SWS-8Xi subs
Since this is my daily ride, I use bluetooth from my iPhone as my audio source. I kept the OEM headunit in just for FM radio and for a stock look. The Audioengine B1 uses AAC bluetooth audio codec for the best possible sound from the iPhones bluetooth audio. The Director is my volume control.
First up, remove all the old stuff.
and install the new stuff.
Coax rear speakers
Sound treatment and speaker cutout
8 sub mounted and more sound treatment
Fiberglassed hole to accommodate the door panel pocket
On to the front doors
First layer of sound treatment
Second layer
Door holes sealed up
GS690 installed
Ran 14ga wire to all the speakers
Installed the Director in the sunglasses holder.
Next Ill be replacing the tweeters.
Dirtboy is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Dirtboy For This Useful Post:
cadaver (6 Days Ago)
Old 6 Days Ago   #2
Dirtboy's Avatar
Default Re: 2007 Nissan Frontier SQ/stealth install
Had some time today to install the ES-02's.
Did a quick tune when I was done.
Left side:
Right side:
Overall impression:
Front soundstage is WAAAAY better than before. The Boston's sounded good, but a bit too bright for my tastes. Truthfully, I'll have to get used to the sound of the ES-02's. They're a big difference from the Morel Hybrid's in my M2. Midbass has improved as well. I'm liking the Audiofrog GS690's.
While I can hear bass all the way down, I don't feel it as much as in my M2 setup. I have the same SWS-8Xi's in both vehicles. The subs in the M2 are getting 160w and the subs in the Frontier are getting 230w. I think has to come down to the enclosures in the M2; I'm sure they are better designed. I tried my best to seal as much of the Frontier's rear door cavity that I could. I estimate each door to be around .55 cuft which is within the range for the SWS-8Xi. Just might think about adding a 10" sub after all.... We'll see....
cadaver (5 Days Ago)
Old 6 Days Ago   #3
Rep Power: 87 Jscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura about
Those reflections are harsh!
Old 6 Days Ago   #4
oabeieo's Avatar
FC -NCO-COL
MECP advanced certified,
Rep Power: 89 oabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enough
Hes boosting a lot at the peaks , it looks like just trying to make it sound good
Its more than likely not gained right and needs a little rta training
At least the helix filters will go all the way
https://youtu.be/VgU6LXY-AjI
Old 6 Days Ago   #5
Dirtboy's Avatar
Yeah I'm still learning all this. The system is tuned pretty close to the Audiotec Fischer house curve. I'm sure I have some cancellations going on in the audio spectrum, but it sounds a whole lot better than the old system.
2014 Nissan Frontier Budget SQ Build cdlowe30907 System Design - Help Me Choose Equipment For My Car 41 03-05-2019 05:35 PM
2014 Nissan Frontier Budget SQ Build cdlowe30907 System Design - Help Me Choose Equipment For My Car 22 01-08-2019 07:08 PM
2014 Nissan Frontier Budget SQ Build cdlowe30907 General Car Audio Discussion 0 11-27-2018 11:05 AM
SQ in my Nissan Frontier final frontier General Car Audio Discussion 7 01-20-2011 09:56 PM
Any Nissan Frontier experience? jisturm Technical & Advanced Car Audio Discussion 0 09-07-2006 06:51 AM
