2012 MINI Cooper S R58 Build - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 06-18-2019   #1
Rep Power: 7 mpm17 will become famous soon enoughmpm17 will become famous soon enoughmpm17 will become famous soon enoughmpm17 will become famous soon enoughmpm17 will become famous soon enoughmpm17 will become famous soon enough
Default 2012 MINI Cooper S R58 Build
Some basic pics to start with. I haven't really done a serious modification yet but it's time to get on with this. I bought one more Tang Band tweeter 25-2176s for my tweeter pod build. Some 1 1/2" PVC Caps and they fit pretty good in it. I will machine the inside of the cap enough to recess the ring into the cap and epoxy it flush to the lip. The brass fittings will let me attach to the a-pillar trim and run the speaker wire thru it. More pics to follow.
File Type: jpg DIY tweeter pod micro machining needs.jpg (141.5 KB, 18 views)
mpm17 is online now   Reply With Quote Quick reply to this message
Old 06-18-2019   #2
Default Re: 2012 MINI Cooper S R58 Build
The amp I choose to use. Does everything I need and want. Atleast for now. We all know how this stuff grows.
Old 06-19-2019   #3
Rep Power: 43 hankhowdy1 will become famous soon enoughhankhowdy1 will become famous soon enoughhankhowdy1 will become famous soon enoughhankhowdy1 will become famous soon enoughhankhowdy1 will become famous soon enoughhankhowdy1 will become famous soon enough
Will the brass nuts be visible? If there are whatís the solution to hide them. Iím also in the process Of mounting some tweeters. Just looking for ideas. I like the pvc caps.
hankhowdy1 is offline   Reply With Quote Quick reply to this message
Old 06-19-2019   #4
I'm considering a thick black o-ring to hide them after they are tight. I will be able to do the final tightening from the back of the a-pillar. There will be epoxy involved so the o-ring will hide any mess I might make. Also will use a black rubber o-ring between the mounting ring and the tweeter. It fills the small gap and size difference between the PVC cap and the tweeters aluminum dress ring. I'll paint the PVC cap black but I am going to experiment with some texture sprays to find something similiar to the dash or a-pillar. I'll post pics and descriptions of what I finally do.
Old 06-19-2019   #5
Sounds good. I will be mounting them to the sail panel. My sail panels are too small for a tweeter. I have to mount a cup to it. I would like to find an adjustable mount to fit between the cup and sail panel.
Old 06-19-2019   #6
Rep Power: 0 allenm324 will become famous soon enoughallenm324 will become famous soon enoughallenm324 will become famous soon enoughallenm324 will become famous soon enoughallenm324 will become famous soon enoughallenm324 will become famous soon enough
Interested in how the tweeters sound, the mounting, and most of all the texture spray you find works best. I still need to pick a tweeter for my R56, but I know I will be going the pod route for mounting.
allenm324 is offline   Reply With Quote Quick reply to this message
Old 06-19-2019   #7
Mine are not going to be exactly adjustable, but I think I can get them pointed properly. If not I can atleast make a few sets to experiment with. The cups were less than $2 each. My little car doesn't have a sail panel. I'm a little jealous.
Old 06-19-2019   #8
The tweeters in their current location sound good. I have them in the top of the door panel just forward of the interior door panel. I did drill a hole for them but they mount so nice. I'm going to get another set of the C shaped part of the door panels when I get my tweeters mounted to the a-pillar. Unfortunately the Tang Band tweeters I have are no longer available in the USofA. Or atleast I couldn't find them so I ordered a single one from nonsolospeakers.com. Not cheap as shipping was half the total cost. Parts Express pricing was $35 I believe. Nonsolospeaker.com cost me $87. International shipping is not your friend. Stay tuned for more pics after this weekend.
The Following User Says Thank You to mpm17 For This Useful Post:
cadaver (06-22-2019)
Old 06-26-2019   #9
Made a little progress. Came out real good. I had to machine the inner lip of the cup to get the aluminum mounting ring to recess into the cup. I am going to epoxy the rings in place and drill the hole for mounting on the A-pillar. Still no decision on surface texture for the cup. I haven't been able to find a texture spray similar to the dash or a-pillar surface so I might experiment with truck bed liner or rubberized paint.
The Following 2 Users Say Thank You to mpm17 For This Useful Post:
cadaver (06-26-2019), hankhowdy1 (06-26-2019)
Old 07-11-2019   #10
A bit more progress after some vacation time in Mexico. Lots of beer and burritos. Good times.
I ended up using bed liner as my texture coating on the pods. I'm ok(lower case) with the results but I will be messing around with other texture options and maybe some material to wrap it.
File Type: jpg Tweeter pod complete with bedliner.jpg (144.5 KB, 4 views)
cadaver (07-12-2019), chithead (07-23-2019)
