2013 Nissan Altima - Quick Build. Morel, Dynaudio, Helix, Mosconi, Illusion, ResoNix - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 3 Weeks Ago   #1
SkizeR's Avatar
Prisoner
Apicella Auto Sound
Janitor
Rep Power: 449 SkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond repute
Default 2013 Nissan Altima - Quick Build. Morel, Dynaudio, Helix, Mosconi, Illusion, ResoNix
Hey guys, its been a while since ive done a build log due to being so busy with the shop and also getting Resonix Sound Solutions set up. Now that everything is mostly set up, i'm starting to get back into the swing of things. That said, this is Al's 2013 Nissan Altima. He contacted me some time back about a build, and we finally organized a date to actually get everything installed. He supplied all gear except for the deadening supplies, the Sony AX210SXM Radio, and the Helix URC.3. The list of gear is as follows..
Sony AX210SXM
Helix DSP with URC.3
(2) Mosconi AS200.4
Mosconi AS300.2
Morel Supremo Piccolo tweeters
Dynaudio Esotar E650 mids
(2) Illusion Audio C12XL subs.
The full deadening guide for this vehicle can be found here:
https://resonixsoundsolutions.com/ve...VlGX7AhrCyToTM
0 gauge cable was ran from front to back, and a plastic bracket was made to secure the fuse holder near the battery using OEM mounting hardware and locations.
All wiring ran through OEM wiring bundles
The Morel tweeters were installed in the OEM dash location using 1/4" ABS plastic that were routed to match the OEM wideband drivers. They dropped right in and were able to be mounted with OEM hardware.
Matei fabricated a nice bracket that went around the Baltic Birch enclosure and secured everything to the rear deck area.
The Dynaudio E650's were installed into composite baffles that match the OEM baffles and mount using OEM hardware and locations. All deadening was done with ResoNix Sound Solutions products and samples. The full deadening guide can be found here.
https://resonixsoundsolutions.com/ve...ar-deck-trunk/
The rear deck and trunk were also deadened.
Here is what Kevin came up with to mount the amps/DSP and the subs.
Thanks for looking!
The Following 2 Users Say Thank You to SkizeR For This Useful Post:
cadaver (3 Weeks Ago), Coppertone (3 Weeks Ago)
Old 3 Weeks Ago   #2
Rep Power: 8 saltyone will become famous soon enoughsaltyone will become famous soon enoughsaltyone will become famous soon enoughsaltyone will become famous soon enoughsaltyone will become famous soon enoughsaltyone will become famous soon enough
Well done! I love and appreciate the attention to detail. All of the “little things” will work together to ensure the system sounds as nice as possible. Good job!
saltyone is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to saltyone For This Useful Post:
SkizeR (3 Weeks Ago)
Old 3 Weeks Ago   #3
Rep Power: 54 dcfis will become famous soon enoughdcfis will become famous soon enoughdcfis will become famous soon enoughdcfis will become famous soon enoughdcfis will become famous soon enoughdcfis will become famous soon enough
Default Re: 2013 Nissan Altima - Quick Build. Morel, Dynaudio, Helix, Mosconi, Illusion, Reso
That bracket and mounting is awesome
dcfis is online now   Reply With Quote Quick reply to this message
The Following User Says Thank You to dcfis For This Useful Post:
Old 3 Weeks Ago   #4
SkizeR's Avatar
Prisoner
Apicella Auto Sound
Janitor
Thanks guys
