2019 RAM 1500 Crew Cab Laramie Project - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 3 Weeks Ago   #1
Hillbilly
Rep Power: 136 Sonnie will become famous soon enoughSonnie will become famous soon enoughSonnie will become famous soon enoughSonnie will become famous soon enoughSonnie will become famous soon enoughSonnie will become famous soon enough
Default 2019 RAM 1500 Crew Cab Laramie Project
Figured I may as well get this project posted since it is practically done now. You would think I would eventually grow out of this crazy hobby of car audio, but I love it so much that I just can't shake it.
Love this truck... RAM did it right for sure.
The first thing I did was have it treated with Ceramic Pro... and XPEL PRIME XR PLUS window tint installed, including the front windshield... along with a spray-in bedliner. So I was without the truck for a full week right after I purchased it. But these add-ons have proven worthy thus far.
This RAM came with the 9-speaker Alpine system and the 8.4" display. I will admit that it sounded pretty good... although the sound stage and imaging were lacking, it did a good job of producing an above the dash image. The small 7-8" subwoofer did a remarkable job for a factory sub... and has about the lowest extension I've heard in a factory system, yet it still lacks that lowest octave, thus it is now unplugged. I could actually live with the factory system, but then it wouldn't have been any fun tearing the truck apart.
My goal was to keep it as factory looking as possible. The only noticeable addition is the subwoofer enclosure underneath the rear seat, although it blends in rather well, as you will see later on when I post the final install pics.
The front center has been disconnected... the rear doors remain and can be faded in if needed for rear seat passengers, which will only be on rare occasions. The rear headliner speakers are used in a rear differential setup for rear fill.
Equipment is as follows:
miniDSP C-DSP 8x12 DL Processor
The brains of the unit with the full works... active crossovers, delay, PEQ and of course... my favorite... Dirac Live
PAC AmpPRO 4 (AP4-CH41 with APA-TOS1)
Installed inline behind the factory headunit to enable a flat low level signal sent via an Optical Digital Toslink cable to the miniDSP processor.
Hybrid Audio Technologies (HAT) Unity U5A 5-Channel Amp
75 watts x 4 powering the door and dash speakers + 600 watts x 1 powering the subs.
JL Audio MX280/4 Amp
50 watts x 2 (with 2 spare channels) powering the rear headliner factory 3.5" speakers... located just above the rear window. The rear speakers are setup as a differential rear fill running from approximately 350-3500Hz with a 20ms delay.
HAT L3SE 3.7" Wide-Bandwidth Driver
These replaced the 3.5" dash speakers... rated at 113 Hz - 18 kHz ... crossed over at 350Hz. You may know the guy who competes and won his category with these in his dash in a 2019 RAM 2500 with 6x9's in the doors... no sub and no tweeters.
HAT Unity 6x9 Shallow Depth Midbass Driver (U69-S)
These replaced the front door speakers and are crossed over at 80-350Hz range.
HAT Clarus 10" Long Throw Subwoofer
These are mounted in an MTI Acoustics custom built enclosure underneath the rear seats.
ResoNix
For treating the doors and rear wall.
Here is a pic of the MTI Acoustics enclosure with the Unity amp and Clarus subs installed.
Actual install pics to follow.
Sonnie is offline   Reply With Quote Quick reply to this message
The Following 3 Users Say Thank You to Sonnie For This Useful Post:
cadaver (2 Weeks Ago), chithead (3 Weeks Ago), diy.phil (3 Weeks Ago)
Old 3 Weeks Ago   #2
Rep Power: 86 dgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enough
Default Re: 2019 RAM 1500 Crew Cab Laramie Project
Nice install man!
Have you thought about how a center channel would work with Dirac? I have but have no clues how well it would integrate. Then again, if youíre getting a nice and spacious stage, then I understand why you disconnected.
dgage is online now   Reply With Quote Quick reply to this message
Old 3 Weeks Ago   #3
Hillbilly
The dash speakers were a little larger than the factory speakers, but they dropped right in and fit really snug.
Dampening material in a few places... not really a lot needed as RAM did pretty well with it from the factory. I added some, whether it needed it or not. The ResoNix foam material does a great job of resolving door rattles.. which I added it to the actual doors and inside of the door panel as well... so there is a double layer between the panel and door. The doors have a completely different sound to them when being shut.
I also had to modify the speaker opening trimming about 1/8" to 3/16" off the top and bottom so the HAT speaker would fit. It was supposed to be a drop in replacement, but apparently MTI Acoustics nor HAT actually ever installed any in the 2019, otherwise they would have known they are anything but drop in. It took me an hour with my Dremel tool carving these out... they were difficult to trim too, being the way they were made... not your typical door speaker baffle. Ultimately they fit and I sealed them off really well with dampening material, then wrapped them in cloth tape to help eliminate any shiny material being seen thru the door panel grille.
Under the hood with the battery...
Almost finished up... still need to wrap the wires and make them look nice, but I will wait on my new amp from HAT. They are in the middle of upgrading the U5A and MTI sent me a demo unit of the old model temporarily, so once I get the new one in and replaced, then I'll tidy up the wiring and make it look nice.
The mini amp from JL is attached to the back of the box...
And a look at the MIT box from outside the truck... they did a super nice job on the finish of the box...
The Following 4 Users Say Thank You to Sonnie For This Useful Post:
cadaver (2 Weeks Ago), chithead (3 Weeks Ago), diy.phil (3 Weeks Ago), SHAGGS (2 Weeks Ago)
Old 3 Weeks Ago   #4
Hillbilly
Originally Posted by dgage View Post
Nice install man!
The center imaging is superb... sound stage is nice and wide... no complaints at all... so the only benefit would be for the passenger, which my wife really doesn't care about. I can't turn it up that loud when she is in the vehicle. The only time she likes it loud is when she is in her own vehicle... then she cranks it on up.
I don't think this miniDSP system has center processing, so I don't know how it would work.
The Following User Says Thank You to Sonnie For This Useful Post:
Coppertone (3 Weeks Ago)
Old 3 Weeks Ago   #5
Now that you added the additional picts, I agree, they did a really nice job on that sub enclosure.
No it doesnít have native processing but it could run off some sort of center fill similar to rear fill for processors that donít support it. Donít have a vehicle to play with it but I have just wondered. Nice to hears yours sounds so good that you wouldnít even want to try.
Old 3 Weeks Ago   #6
Hillbilly
Thanks...
Yeah... it sounds really good right now... best I've had in a LOT of different builds since back in the 80's.
I suppose you could send a mono signal to the center... combined from the left and right front dash speakers, but I would think it would interfere with the sound stage with it not being processed as a center. Might would be interesting to try it if it was needed.
Old 3 Weeks Ago   #7
Coppertone's Avatar
Rep Power: 162 Coppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of lightCoppertone is a glorious beacon of light
Oh wow it is sooo great to see a Ram (DT) version being done on here.
(2.5GT) Limited Legacy / Pioneer 4800BS /Audison APK-165
Turbocharged / 6 speed / awd/ goodness ( For SALE )
(2018) Accord 2.0T Touring (10speed) turbocharged
The Following User Says Thank You to Coppertone For This Useful Post:
Old 3 Weeks Ago   #8
Hillbilly
Love the truck... just love it. Best vehicle I have ever owned out of between 50-60 vehicles in my driving lifetime.
Old 3 Weeks Ago   #9
Coppertone's Avatar
Glad to hear, if you have any questions about it please feel free to pm me. Sorry donít mean to clutter your build thread.
Old 3 Weeks Ago   #10
chithead's Avatar
Rep Power: 184 chithead is a glorious beacon of lightchithead is a glorious beacon of lightchithead is a glorious beacon of lightchithead is a glorious beacon of lightchithead is a glorious beacon of lightchithead is a glorious beacon of lightchithead is a glorious beacon of lightchithead is a glorious beacon of lightchithead is a glorious beacon of lightchithead is a glorious beacon of lightchithead is a glorious beacon of light
2019 Ram 1500 Laramie owner here too! Love the upgrades and progress so far!!! Can you still use the Ram Bin with the MTI enclosure? I keep seeing recommendations for those, but really like that Ram weather mat. Do you enjoy the sound of those subwoofers facing upwards into the bottom of the seat? Can't decide in ours whether to go with an enclosure that sits on that mat, trim it, or just build a, "floating" enclosure that allows weather mat removal.
Old 3 Weeks Ago   #11
Coppertone's Avatar
I was told when I contacted them that if you went with the duals, expect it to cover our floor bins. Honestly I rarely use mine so thatís not an issue for me. I just needed more options then just putting an 8Ē solely in there. Also Iím really surprised that they donít have forward facing enclosures for the DT models.
Old 3 Weeks Ago   #12
Hillbilly
Bins are not functional... although I don't use them. I have a toolbox in the back bed that is carpeted. I suspect you could fit 8's in there and not interfere with the bins. My 10's could move back slightly and with 8's, you'd be back a couple of inches, which is really all you need with the enclosure I have to open the bins.
They sound great firing up... very smooth and well rounded sound sealed after tuning them slightly.
I did have a nasty peak at 55-60Hz that was nearfield, so I fixed that in the pre-tune.
Then from the drivers seat I also took out a couple other peaks.
Old 2 Weeks Ago   #13
Rep Power: 111 stickpony is on a distinguished roadstickpony is on a distinguished roadstickpony is on a distinguished roadstickpony is on a distinguished roadstickpony is on a distinguished road
it looks nice man. I hope it doesn't become a repair nightmare after 4-5 years like many dodge trucks are notorious for.
stickpony is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #14
Hillbilly
lol... I likely won't keep it long enough to find out. I typically trade about every 2-3 years. However, I've had a couple of used RAM trucks and they've been very good, even with higher miles. I hear stories about all the manufacturers... and have owned several models over many years... none are perfect, that is for sure.
Old 2 Weeks Ago   #15
saltyone's Avatar
Rep Power: 12 saltyone will become famous soon enoughsaltyone will become famous soon enoughsaltyone will become famous soon enoughsaltyone will become famous soon enoughsaltyone will become famous soon enoughsaltyone will become famous soon enough
I have over 35,000 miles invested in my Ram with almost zero issues. The cruise control button can be a little touchy...but easily fixed. That’s really it. No other issues. I absolutely love this truck, more than any other vehicle I’ve owned. The paint and finish are near show room fresh with no corrections. All I do is wash and dry it once a week or so. The undercarriage is perfect. All trim is perfect.
I bet I get a lot more compliments on my Ram than your average truck owner. They just look good. The other options out there simply look boring to me. Having a full size 4X4 crew cab truck with the throttle response of a mustang is nice too...LOL!
saltyone is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #16
Coppertone's Avatar
I had my last Ram for almost 197,000 miles so Iím feeling Iím good with this one lol.
Old 1 Week Ago   #17
theres always a lemon with every manufacturer for sure. i wish you luck, its a great looking vehicle.
Old 1 Week Ago   #18
the MTI box looks fantastic, it really makes the entire install. and so stealthily hidden under the back seat, i love it!
Old 1 Week Ago   #19
Hillbilly
Thanks guys... I appreciate it. Hopefully I'll get all the miles I need out of it without any issues before I get another one. I'll keep it under warranty, that is for sure.
I'm diggin' the MTI box the more I drive the truck and realize how well it blends in. I've shown it to a couple of folks and they are astonished at how factorish it looks. And it sounds pretty good too, so that helps.
Lovin' the miniDSP with Dirac Live as well... sounds great.
Coppertone (1 Week Ago)
Old 1 Week Ago   #20
Coppertone's Avatar
You sir are really forcing my hand as in copying what you have and selling what I currently have lol.
Old 1 Week Ago   #21
Hillbilly
lol... that's funny for sure. Although I've had several guys copy my home audio and love it. I'd say go for it... you'll no doubt love the truck.
I'd really like some "real" car audio guys to hear my truck and tell me what they think... how far off am I from that subjectively good car tune. I need to quick procrastinating and go visit with Erin.
Old 1 Week Ago   #22
Coppertone's Avatar
Yes if you have access to Erin, I definitely would be making that trip.
Old 1 Week Ago   #23
Rep Power: 0 jr_spyder will become famous soon enoughjr_spyder will become famous soon enoughjr_spyder will become famous soon enoughjr_spyder will become famous soon enoughjr_spyder will become famous soon enoughjr_spyder will become famous soon enough
Nice system Sonnie. I may just copy it all... laugh:
jr_spyder is offline   Reply With Quote Quick reply to this message
Old 1 Week Ago   #24
Hillbilly
Thanks... let me know if you do... would love to hear about your thoughts on it.
Old 1 Week Ago   #25
Well it turns out that I wrote quite a long entry here but it was auto-rejected by the system since I'm a new guy here and it was my first post. That said I'm on loads of other forums, and have been for many years, and recognized as a good guy. I like that there are rules on forums but this one stumped me, and I can't find the actual rule. Not complaining, just trying to sort it out and stay within the rules. I'll break up my comments to you to see if I can get them through piecemeal. Stay tuned...
