Wts gb10 audiofrog tweets - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 4 Weeks Ago   #1
Rep Power: 0 B77PEREZ will become famous soon enoughB77PEREZ will become famous soon enoughB77PEREZ will become famous soon enoughB77PEREZ will become famous soon enoughB77PEREZ will become famous soon enoughB77PEREZ will become famous soon enough
Will post pictures.
I have had these tweets for 6 months, have box all accessories, never used mounting gear still factory installation stuff in box
$230.00
. I want to buy gb15
B77PEREZ is offline   Reply With Quote Quick reply to this message
Old 3 Weeks Ago   #2
Bump.
Old 3 Weeks Ago   #3
Rep Power: 67 Souths1der will become famous soon enoughSouths1der will become famous soon enoughSouths1der will become famous soon enoughSouths1der will become famous soon enoughSouths1der will become famous soon enoughSouths1der will become famous soon enough
Default Re: Wts gb10 audiofrog tweets
How are those secured in the door panel?
Souths1der is offline   Reply With Quote Quick reply to this message
Old 3 Weeks Ago   #4
I was able to secure with abs drain screen from home depot 1 1/2" cut out the screen part and it was the exact depth of tweeter then used the back mounting plate and mounting screw/all thread then put the washer and the nut. It fit perfectly. It was like sticking the tweeter into a perfect size cup, the flang on drain ring made another tiny little black ring under the silver beauty ring that came with the tweeter.I think if you zoom in on pics you can see it. Also I had to cut a tiny ring of 2" abs pipe and glue it to the out side of that drain screen, to hold it in the door. Speaker in the screen. Speaker and screen in the door, tiny 2" by 1/2" wide abs pipe ring cut then glued around abs drain screen. I hope that makes sense.... if not let me know.
The Following User Says Thank You to B77PEREZ For This Useful Post:
beak81champ (3 Weeks Ago)
