Create half door panel Saab ng9-3 bak - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 07-09-2019   #1
Rep Power: 0 toolazy9-3 will become famous soon enoughtoolazy9-3 will become famous soon enoughtoolazy9-3 will become famous soon enoughtoolazy9-3 will become famous soon enoughtoolazy9-3 will become famous soon enoughtoolazy9-3 will become famous soon enough
Default Create half door panel Saab ng9-3 bak
Hi.
Have anyone done that ?
It’s very hard too find stock panels for speakers in the bak doors and if you do they cost a lot.
Stock has 4” speakers there but I’d like too put 6.5” mids or coax.
Anyone have tips ?
With speakers
Without speakers i have these once’s
Skickat från min iPhone med Tapatalk
toolazy9-3 is offline   Reply With Quote Quick reply to this message
Old 07-09-2019   #2
Rep Power: 109 nyquistrate will become famous soon enoughnyquistrate will become famous soon enoughnyquistrate will become famous soon enoughnyquistrate will become famous soon enoughnyquistrate will become famous soon enoughnyquistrate will become famous soon enough
Default Re: Create half door panel Saab ng9-3 bak
So, you have the bottom pictured door panels with storage instead of a speaker grille, correct? Do you want to keep that bottom half to put back in the car when you sell it? If so, it is probably held with some plastic retainers that could be cut off. A new substrate (ABS, hardboard, plywood) could be cut using the bottom door card as a template. Build up from there with wood or fiberglass over cloth.
If you don't care about keeping that bottom portion intact for resale purposes, then the easiest thing might be to cut an access hole for the speaker, insert a mounting ring and fiberglass the remaining hole.
nyquistrate is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to nyquistrate For This Useful Post:
toolazy9-3 (07-09-2019)
Old 07-09-2019   #3
LBaudio's Avatar
Rep Power: 308 LBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond repute
Try to find replacement on junk-jard.
Are there any holes for speakers under that doorcard?
MAke rings from Aluminium or at least PLY wood so you wont have problems because of the watter.
position rings to the metal, cut holes for speakers, close all holes around speaker ring with fiberglass..... after speaker is installed prevent speaker to play under the doorcard with instalation of FAST RINGS - foam rings that will prevent speaker to play under doorcard and will force complete speaker output trough the speaker grill into the cabin
For Fast Moving Concerts
Team LB audio
Team Hybrid Audio
Team BRAX
Team SCB
