ABS Tweeter Adapters - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 1 Week Ago   #1
Rep Power: 9 ajt976 will become famous soon enoughajt976 will become famous soon enoughajt976 will become famous soon enoughajt976 will become famous soon enoughajt976 will become famous soon enoughajt976 will become famous soon enough
Default ABS Tweeter Adapters - Will these work?
Making some adapters for my 2017 Silverado, working on installing some SB29RDCN neo tweeters. I used the OEM 'wideband' as a template, but after making the cutout for the tweeter it left only a small bit of material left for mounting.
Overall diameter is still wider than the flange of the SB29's, is this too thin or do you think I'll be alright?
File Type: jpg IMG_20190812_162551_01_1565652842055.jpg (966.5 KB, 10 views)
ajt976 is offline   Reply With Quote Quick reply to this message
Old 1 Week Ago   #2
The mounting holes are pretty close to the edge but decided to go for it...
Old 1 Week Ago   #3
Rep Power: 19 Mitchc1113 will become famous soon enoughMitchc1113 will become famous soon enoughMitchc1113 will become famous soon enoughMitchc1113 will become famous soon enoughMitchc1113 will become famous soon enoughMitchc1113 will become famous soon enough
I'm no pro, but I do have the same truck. And while you cut it pretty close there I think you'll be alright. They're up out of the way in the dash so unless u get in a wreck they shouldnt be moving around any. Not like a door speaker where its constantly being open and closed... The only real exposure issue in dash is heat, but u used ABS so that's good... I think u should mount them and if they sound good send it!
Mitchc1113 is offline   Reply With Quote Quick reply to this message
Old 1 Week Ago   #4
Default Re: ABS Tweeter Adapters
So far so good. I guess that's the challenge with those large format tweeters...they're large! I used a 2-1/4" hole saw and while there was enough play to comfortably fit them, I still had to notch the top and bottom of the adapters so the speaker terminations and wire could pass.
I guess I didn't figure the need to press fit a tweeter like this.
