HAT Unity 6.5 or HAT Clarus 6.5 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 01-30-2012   #1
Rep Power: 0 soulman864 will become famous soon enoughsoulman864 will become famous soon enoughsoulman864 will become famous soon enoughsoulman864 will become famous soon enoughsoulman864 will become famous soon enoughsoulman864 will become famous soon enough
Default HAT Unity 6.5 or HAT Clarus 6.5
I really would like to know the difference between the two in terms of sq
soulman864 is offline   Reply With Quote Quick reply to this message
Old 01-30-2012   #2
Rep Power: 134 Mike-G will become famous soon enoughMike-G will become famous soon enoughMike-G will become famous soon enoughMike-G will become famous soon enoughMike-G will become famous soon enoughMike-G will become famous soon enough
Default Re: HAT Unity 6.5 or HAT Clarus 6.5
I have heard that the Unity set consists of basically the Imagine Mid with the Clarus Tweeter. I was going to go with the Unity set myself, but with the recent deal on the used images from Hybrid, I had to jump on that.
Mike-G is offline   Reply With Quote Quick reply to this message
Old 01-30-2012   #3
Rep Power: 138 ZAKOH will become famous soon enoughZAKOH will become famous soon enoughZAKOH will become famous soon enoughZAKOH will become famous soon enoughZAKOH will become famous soon enoughZAKOH will become famous soon enoughZAKOH will become famous soon enough
Just skim through the Unity manual (available here). The manual says that the tweeter and crossover box are from the Clarus set, and the woofer is based on the Imagine woofer. Their parameters indeed look very similar.
It seems like Unity is a better set if you need a more robust crossover box. It gives up 2nd order crossover slopes and optional tweeter attenuation. The Imagine uses first order high pass for tweeter and no option for attenuation. If you're going to run active, then the $100 price difference between Imagine and Unity is buying you a different, hopefully better tweeter. Personally, I'd spend a little more on amplification and run Imagines quasi-active.
Old 01-30-2012   #4
Rep Power: 147 TOOSTUBBORN2FAIL is a name known to allTOOSTUBBORN2FAIL is a name known to allTOOSTUBBORN2FAIL is a name known to allTOOSTUBBORN2FAIL is a name known to allTOOSTUBBORN2FAIL is a name known to allTOOSTUBBORN2FAIL is a name known to allTOOSTUBBORN2FAIL is a name known to allTOOSTUBBORN2FAIL is a name known to allTOOSTUBBORN2FAIL is a name known to allTOOSTUBBORN2FAIL is a name known to allTOOSTUBBORN2FAIL is a name known to all
The tweeter is a little better in the Unity than the Imagine set. However, since your asking between the clarus 6.5" and the unity 6.5", the Clarus has slightly higher xmax (7mm vs 6mm one way), slightly more cone area, higher power handling, and a much lower FS (50hz vs 75hz).
TOOSTUBBORN2FAIL is offline   Reply With Quote Quick reply to this message
Old 01-31-2012   #5
Thank you everyone for the replies I feel a little more knowledgeable on the different sets now. So if I were looking for a good front stage in a civic 2000 ex coupe would the Clarus provide a noticeable difference to the imagine running active?
Old 01-31-2012   #6
If your ok with the price difference, the clarus would be noticeably better, even when ran active. That's not to say the unity's are bad, just that the clarus are a definite step above them.
Old 01-31-2012   #7
My bad, I forgot this was the question about Clarus and Unity after reading the first reply. Yeah.. if you can afford Clarus and have the mounting depth for it, this is a better choice. The main difference is the woofer, which is a step above the Unity woofer. Looking at the specs, it seems like it can be high passed at around 50Hz and actually deliver the goods. I would have loved to see it in my car, but I think the mounting depth of 3inches or so could be pushing it, and the door panels are too close to fit a thick baffle.
