Helix C-DSP Car off powering Amps ? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 09-02-2015   #1
Rep Power: 71 Ruchab91 will become famous soon enoughRuchab91 will become famous soon enoughRuchab91 will become famous soon enoughRuchab91 will become famous soon enoughRuchab91 will become famous soon enoughRuchab91 will become famous soon enough
Default Helix C-DSP Car off powering Amps ?
Hey so just finished wiring up my Helix C-DSP and having an issue with the small plastic connector or the DSP itself. When i have the wires out REM IN/OUT i can touch the wires together and no power will go to the amps with the car off, But if i plug them into the small plastic connector and then into the DSP both amps will turn on even tho the car is off.
If the car is on and I touch the 2 REM wires together the amps will go on.
I have pulled it apart and re wired it 2 times with the same problem.
Ruchab91 is offline   Reply With Quote Quick reply to this message
Old 09-02-2015   #2
Guest
Malibu's Auto Center
Janitor/Install Manager
Rep Power: 0 jowens500 will become famous soon enoughjowens500 will become famous soon enoughjowens500 will become famous soon enoughjowens500 will become famous soon enoughjowens500 will become famous soon enoughjowens500 will become famous soon enough
What kind of car? And are you using high level inputs?
jowens500 is offline   Reply With Quote Quick reply to this message
Old 09-02-2015   #3
Default Re: Helix C-DSP Car off powering Amps ?
Car is a 91 bmw 8 series.
No i am not using High level Inputs.
The C-DSP is wired directly to the battery via the 12+ Connection and to the factory grounding Point.
I just tried running it with no Ground Cable connected to the C-DSP and strangely enough it still powered on the amps when the car is off.
The Amplifiers are Wired to a Distro Block and then to the + Connection of the Opposite Battery (Car has 2 One per side of the Trunk) and, The Negatives are wired to the Factory ground which i striped and sanded down for a clean connection.
I'm truly at a loss for why its doing this.
Old 09-02-2015   #4
Anyone this problem is causing me grief lol once i have this in i can start tuning the car
Old 09-02-2015   #5
Guest
I got nothing
Sent from my iPad using Tapatalk
