Car Audio | DiyMobileAudio.com | Car Stereo Forum
Car Audio | DiyMobileAudio.com | Car Stereo Forum (https://www.diymobileaudio.com/forum/)
-   General Car Audio Discussion (https://www.diymobileaudio.com/forum/general-car-audio-discussion/)
-   -   2-way Front stage, active, 2 amps questions (https://www.diymobileaudio.com/forum/general-car-audio-discussion/417737-2-way-front-stage-active-2-amps-questions.html)
thisgsx 05-17-2019 05:53 PM
I have 2 JL Audio RD400/4 that is going into my truck. The plan is to bridge each amp. What is the appropriate way to connect the front stage? Driver's side to one amp and passenger side to the other? Or tweeters to one amp and mids to the other? Thanks in advance!
Sent from my LG-LS997 using Tapatalk
kanadian-kaos 05-17-2019 06:27 PM
Re: 2-way Front stage, active, 2 amps questions
Tweeters to one and mids to the other... but that is a lot of power for a set of tweeters. You could get away with bridging one to the mids, and using the other as a 4 channel with two channels for the tweeter, leaving you with two extra channels for whatever.
SkizeR 05-17-2019 06:40 PM
doesnt matter, but i would do drivers side on one, and passanger side on the other. reason being is to 1) not put most of the draw to one amp (midbass will pull much more current) causing one to heat up a lot more than the other, and 2) better left/right separation in theory.
Bayboy 05-17-2019 06:48 PM
Honestly, that's a lot of power for even mids even though many do it including me. Mainly I didn't want the extra channels of a 4 & 5 channel amps going to waste on a 3-way + sub. Basically, that's enough power to run a 3-way+sub if chosen right. Above sub frequencies we don't use as much power as you think for common listening levels.
That's enough rambling...
Man & Machine... Power Extreme!
ckirocz28 05-17-2019 06:58 PM
It doesn't really matter, whatever you want. I have one bridged on mids and one running two channels only on tweets, leaving two channels free. One of these bridged on tweets seems like overkill, and maybe too much.
thisgsx 05-17-2019 10:17 PM
Thanks guys!
Mahapederdon 05-17-2019 10:26 PM
I would do 1 amp for mids and 1 amp for tweets unbridged on the tweet side. My reasoning is you'll be able to keep the gain allot lower on the tweets and you'll have less noise. For me my tweeters have a tiny hiss when my volume is at 0. I only hear it if I get close to the tweeters but if my gain was where my midbass gain is it would probably be worse.
JH1973 05-18-2019 10:12 AM
With all of that power and 8 channels I'd find a way to make it a 3-way front.Bridge the midbass channels and run the mid-range and tweets off the other 4.
ckirocz28 05-18-2019 03:22 PM
In my case, that is the final goal. One amp bridged on midbass, the other amp for tweets and mids. Some of us just take one step at a time, as opposed to putting the whole system together at once.
thisgsx 05-30-2019 12:20 PM
Amps have been revamped and the install is complete. The RD's replaced my Gladens. Thanks guys!
https://uploads.tapatalk-cdn.com/201...1800b53efb.jpghttps://uploads.tapatalk-cdn.com/201...f7498a2d9b.jpghttps://uploads.tapatalk-cdn.com/201...2369c38897.jpghttps://uploads.tapatalk-cdn.com/201...0758c63a1f.jpghttps://uploads.tapatalk-cdn.com/201...8a49497a3e.jpg
ckirocz28 05-30-2019 03:11 PM
Originally Posted by thisgsx (Post 5707165)
So, what do you think about them? Any difference to speak of?
thisgsx 05-30-2019 03:35 PM
The only difference is that the Gladen xl 250c4 sounds warmer and laid back while the RD sounds cleaner and crisper. Not a "in your face" type but just clean. Sort of like in the home audio world, Gladen = tube amp and RD = solid state.
Nothing else changed except for the amps.
Head unit is a Pioneer avh5800bhs
Seas Lotus Reference RT27A tweeters
FaitalPRO 8FE200 8"*woofers
Still need some fine tuning, but so far, I've ran the auto EQ and TA from the HU and it's clean! I've listened to various tracks and haven't really need to utilize the 13 band EQ to cut anything.
ckirocz28 05-30-2019 03:46 PM
Glad to hear they're satisfactory, so far. You can probably tune for that warmer, laid back sound, if you want to. I wouldn't know where to start with that, though.
thisgsx 05-30-2019 03:50 PM
Thanks! It's a sound I would have to get used to.
ckirocz28 05-30-2019 04:12 PM
Did you do one per side, or run them in stereo?
thisgsx 05-30-2019 04:25 PM
I didn't want to pull apart my RCA's to extend the reach so I did tweeters to one amp and mids to the other. If I remember correctly, there's an error in the manual, which states that for bridging, only Channels 1& 3 are used and to set it in 2-channel mode. That's a discrepancy it needs to be set to 4-channel mode. I was having all sorts of phasing issues and it drove me nuts. To the point where I couldn't even listen to my music.
ckirocz28 05-30-2019 04:57 PM
If I recall correctly, the labels on the amp made more sense than the manual, in that regard.
tRidiot 05-30-2019 05:49 PM
Too much power for tweets???
BAH.
I've run alot more than that to tweets, and hell, now I'm running 150x2 to HLCDs. :D
Set your gains, level-match, and don't worry about it.
Chris12 05-30-2019 09:43 PM
Thanks for posting this.
I have a very similar setup to you with my tweets and mids on one xd400/4 and my mid bass on another bridged xd400/4. Your post prompted me to re-visit how mine was hooked up, and sure enough, it was wrong.
I love this site. Thanks again for sharing!
