Noise out of single speaker - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 05-19-2019   #1
Rep Power: 13 Swoopejoy will become famous soon enoughSwoopejoy will become famous soon enoughSwoopejoy will become famous soon enoughSwoopejoy will become famous soon enoughSwoopejoy will become famous soon enoughSwoopejoy will become famous soon enough
Default Noise out of single speaker
Hi guys - I have a tweeter (Dayton nd16) that makes a noise I can’t figure out. My first thought was that it was blown, so I replaced it, yet the noise is still there. It sounds good at high volumes but at quieter parts of songs you can hear a distinct crackle out of it. What are some thoughts on possible issues? Bad amp channel? It’s run off a Rockford 360.3 dsp as well.
Thanks for any thoughts.
Swoopejoy is offline   Reply With Quote Quick reply to this message
Old 05-20-2019   #2
Nottinghamshire Police
Auto electrician/Fabricator
Rep Power: 156 dumdum will become famous soon enoughdumdum will become famous soon enoughdumdum will become famous soon enoughdumdum will become famous soon enoughdumdum will become famous soon enoughdumdum will become famous soon enough
Default Re: Noise out of single speaker
Swap the channel for the other tweeter at the amp (important), if the noise swaps sides itís the amp, if not likely a bad connection between amp or the speaker lead getting earthed somewhere
dumdum is offline   Reply With Quote Quick reply to this message
Old 05-20-2019   #3
Rep Power: 52 Holmz will become famous soon enoughHolmz will become famous soon enoughHolmz will become famous soon enoughHolmz will become famous soon enoughHolmz will become famous soon enoughHolmz will become famous soon enough
Well done.
Old 05-20-2019   #4
Swap the channel for the other tweeter at the amp (important), if the noise swaps sides it’s the amp, if not likely a bad connection between amp or the speaker lead getting earthed somewhere
I’ll do that. I noticed last night certain parts of certain songs can mimic it, and it will be the exact same “pattern” of noise each time that part of the song plays. Some songs it’s very quiet or non existent. Would you expect that to be the case with either of the above two possibilities?
Old 05-20-2019   #5
Rep Power: 369 gijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond repute
What's your HPF set to on them?
Do what has been suggested to help narrow the problem down.
Old 05-20-2019   #6
They are high passed at 5,000. The left tweeter makes zero noise like the right tweeter though so I can’t see how it would be filter or gain related. I could be wrong there though.
Old 05-20-2019   #7
Originally Posted by Swoopejoy View Post
They are high passed at 5,000. The left tweeter makes zero noise like the right tweeter though so I canít see how it would be filter or gain related. I could be wrong there though.
That should be a fine HPF for those, did you every run them lower with a decent amount of power? It's possible that it's damaged, but the swap the wires at the amp, and you'll get some good info. It could be a bad tweeter, amp channel, wiring, etc. Seeing if the noise sticks with the same tweeter after swapping wires will tell you that it's either the wire or tweeter.
Old 05-20-2019   #8
Makes sense. My initial thought was a blown right tweeter, but I replaced it with a new speaker and the noise was immediately still there so I’m thinking I can eliminate that possibility at this point.
Single Box Dual Sub: Single or Dual chamber - single chamber volume is too small. wookielover Technical & Advanced Car Audio Discussion 5 08-03-2016 01:01 PM
WTB single Polk SR 6.5" single midrange and single Audiofrog GB10 tweeter boricua69 Car Audio Classifieds 2 04-24-2016 09:48 AM
WTB: Single HAT L3se, single speaker not pair audijay Car Audio Classifieds 15 07-03-2014 06:06 AM
sine wave, pink noise, white noise, what noise? stanza Technical & Advanced Car Audio Discussion 4 09-22-2011 12:29 PM
Road noise, engine noise, wind noise... meisguy Technical & Advanced Car Audio Discussion 60 02-12-2010 05:29 PM
