Noob question - powering DSP - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 4 Weeks Ago   #1
Rep Power: 0 chrmbly will become famous soon enoughchrmbly will become famous soon enoughchrmbly will become famous soon enoughchrmbly will become famous soon enoughchrmbly will become famous soon enoughchrmbly will become famous soon enough
Default Noob question - powering DSP
So, I'm going to feel stupid asking this... I have a Rockford DSR-1 DSP that requires a source for remote turn on AND a source for constant 12v. I didn't realize this until I buttoned up everything (that it needed a constant 12v source).
My dad had the bright (or, maybe NOT so bright) idea of just running a wire off the amp's power to it... So in other words, I have a small gauge cable plugged into the power input for my amplifier next to my big 4 ga wire coming directly from the battery, then run to my DSR1.
I have a feeling I'll be laughed at for this one, or told that my car is a firebomb waiting to happen. It powers it fine, no issues... Was planning on throwing a fuse on that line just to be safe. So, am I an idiot for doing this, or will it be ok so long as I fuse it w/ a low amp fuse?
Thanks - sorry for the dumb question.
chrmbly is offline   Reply With Quote Quick reply to this message
Old 4 Weeks Ago   #2
Rep Power: 155 fischman will become famous soon enoughfischman will become famous soon enoughfischman will become famous soon enoughfischman will become famous soon enoughfischman will become famous soon enoughfischman will become famous soon enough
Default Re: Noob question - powering DSP
Definitely fuse it and you'll be fine. It' not the ideal situation having multiple wires plugged into the single input since the smaller one could potentially come loose, but as long as it's fused and the connection is tight you will be fine.
Josh
fischman is offline   Reply With Quote Quick reply to this message
Old 4 Weeks Ago   #3
Grinder's Avatar
Rep Power: 56 Grinder will become famous soon enoughGrinder will become famous soon enoughGrinder will become famous soon enoughGrinder will become famous soon enoughGrinder will become famous soon enoughGrinder will become famous soon enough
^This^
It's not a dumb question.
Be sure to size the fuse well below the ampacity of that small wire in question, and install the fuse as close to the amp terminal as practically possible.
Grinder is online now   Reply With Quote Quick reply to this message
Old 4 Weeks Ago   #4
fourthmeal's Avatar
Rep Power: 949 fourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond reputefourthmeal has a reputation beyond repute
That'll do but not really, and you know it so I won't chastise. The best way to handle this is to insert a distribution block in the mix. Amazon is selling these integrated power/ground blocks and actually...they are quite good! I think $30 is the going price, and I've had good success with these little blocks and they work great with ferrules (also on Amazon.) They will come with fuses (random sizes but probably good for you) so that should be all you need, along with a tiny bit of re-wiring to put your amp and DSR1 in that distribution block.
2015 Durango R/T, MS-8, Massive N3, set of NX4's, Audiofrog GS690 and GS10, Wavecor center, Sundown SD3 10's
2018 WRX, Helix V Eight and G-One, AD W600, AP AR3 & AR20, AE AV10H-D2
Old 4 Weeks Ago   #5
Rep Power: 111 kanadian-kaos will become famous soon enoughkanadian-kaos will become famous soon enoughkanadian-kaos will become famous soon enoughkanadian-kaos will become famous soon enoughkanadian-kaos will become famous soon enoughkanadian-kaos will become famous soon enough
100% doable that way. Hide the new power wire under the 4 gauge and cover it in split loom... no one will know, but it does need a mini fuseholder inline (they are $5-$8, littlefuse). No need to waste money for a distribution block if you only have one amplifier unless you are planning to upgrade later.
2016 Ford F150 Supercrew Sport: Soundstream Ref 5.1000 (Front High +sub) - Soundstream RN4.1400D(Rear and MB) - DSP 408 - Audio Control DQXS - JL 12TW3 - Image dynamics XS28 + X69, Scanspeak 10f, CTX65 (rear).
kanadian-kaos is online now   Reply With Quote Quick reply to this message
Old 4 Weeks Ago   #6
Rep Power: 187 miniSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the rough
That is how i always ran my HelixDSP...4ga into my amp and 18ga out of my amp and into my HelixDSP. Just be sure to use any fuses that came with the RF, or follow any fusing quidlines in the manual.
2018 Crosstrek
Helix P SIX Mk2-AF Gs690 GB15-SI RM12- Zapco Z-2kd
miniSQ is offline   Reply With Quote Quick reply to this message
POWERING MOREL SUPREMO 602 WITH HELIX P SIX DSP MK2 manojp73 General Car Audio Discussion 9 05-08-2019 01:35 PM
Anyody powering a dual voice coil suwoofer with Helix p six dsp mk2? manojp73 Technical & Advanced Car Audio Discussion 5 07-28-2018 07:41 AM
Helix C-DSP Car off powering Amps ? Ruchab91 General Car Audio Discussion 4 09-02-2015 09:09 PM
Properly powering a mediocre subwoofer vs under-powering a good sub-woofer (750RMS) geforce789 General Car Audio Discussion 4 03-03-2015 05:55 PM
Powering mini dsp bigfastmike Technical & Advanced Car Audio Discussion 13 10-17-2012 08:18 PM
