08 Chrysler radio random shutdown - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 2 Weeks Ago   #1
Rep Power: 0 tipsy will become famous soon enoughtipsy will become famous soon enoughtipsy will become famous soon enoughtipsy will become famous soon enoughtipsy will become famous soon enoughtipsy will become famous soon enough
Default 08 Chrysler radio random shutdown
Recently my res Chrysler town and country radio has started to randomly shutdown. It stays off for random lengths of time and then comes back on. Anybody else have this issue or have any thoughts? Seems as though it was doing it more in the colder weather when the heat was on. Now I run the a/c and keep the car cooler and it’s not happening as much but it still does happen.
Are transistors or capacitors overheating and causing it or is there some sort of thermal fuse that blows and then resets?
Thanks for any input.
Jeff
tipsy is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #2
Apicella Auto Sound
Technician
Rep Power: 47 Mullings will become famous soon enoughMullings will become famous soon enoughMullings will become famous soon enoughMullings will become famous soon enoughMullings will become famous soon enoughMullings will become famous soon enough
Does any of the speakers sound funny? Mainly the ones on the dash, The cones tend to dry rot
Mullings is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #3
Mahapederdon's Avatar
Rep Power: 38 Mahapederdon will become famous soon enoughMahapederdon will become famous soon enoughMahapederdon will become famous soon enoughMahapederdon will become famous soon enoughMahapederdon will become famous soon enoughMahapederdon will become famous soon enough
Sounds like a loose or corroded connector or fuse. If you bang on your dash does it come on and off. Look in your owners manual and see where your radio fuse is. Pull it out and put it back in. Look for corrosion around where it plugs in? I could be wrong but it sounds like a loose connection.
Mahapederdon is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #4
Default Re: 08 Chrysler radio random shutdown
I've tried banging. Nothing helps. I will check the fuse. It's very random when and how it happens. No bad sound from speakers. Sounds great and then SNAP! loud electronic pop and it's dead.
I'll check the fuse.
Old 2 Weeks Ago   #5
ckirocz28's Avatar
Rep Power: 29 ckirocz28 will become famous soon enoughckirocz28 will become famous soon enoughckirocz28 will become famous soon enoughckirocz28 will become famous soon enoughckirocz28 will become famous soon enoughckirocz28 will become famous soon enough
This will be absolutely no help at all.
The Chrysler company gremlins were installed in the head unit instead of the ECU.
ckirocz28 is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #6
my fuse box looks as clean as the day it rolled off the line. I pulled the fuse anyway and it's tight and still good. No corrosion either.
