Thoughts On Venting Kick Panels - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 06-05-2019   #1
asianinvasion21's Avatar
Rep Power: 89 asianinvasion21 will become famous soon enoughasianinvasion21 will become famous soon enoughasianinvasion21 will become famous soon enoughasianinvasion21 will become famous soon enoughasianinvasion21 will become famous soon enoughasianinvasion21 will become famous soon enough
Default Thoughts On Venting Kick Panels
Sorry if this thread is somewhat of a repost. The others had limited information in them. Just curious if most of you are running your kick panels sealed or vented? Does a sealed kick panel offer more cone control for the midbass? I'm going to be starting another kick build pretty soon and I wanted to get some input. If I wanted the midbass to play lower, would it be better to vent the enclosure? If so how big of a vent should be cut into the enclosure? I'm sure its going to be different for everyone depending on how much space is available. I just wanted to see how this affected the frequency response of the driver. Thanks for any input.
Pure i20 Optical --> Alpine DVA-9860--> Alpine PXA-H701
Audison LRX 5.1k -->Dynaudio MW172--> Dynaudio MD142
Audison LRX 5.1k -->Dynaudio MW172--> Dynaudio MD102
asianinvasion21 is offline   Reply With Quote Quick reply to this message
Old 06-05-2019   #2
SkizeR's Avatar
Prisoner
Apicella Auto Sound
Janitor
Rep Power: 449 SkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond repute
Default Re: Thoughts On Venting Kick Panels
all drivers require a given amount of airspace. If you can get away with sealing a driver in the kick panel, go for it. But that's rarely the case with midbass drivers. Looks like you have MW172? it would be pretty disastrous if you tried to seal those in the kicks. They expect a large enclosure because they're designed for a door. How you cent them also matters. A small hole will not cut it.
Old 06-05-2019   #3
The new kicks would be for a 6 inch driver. I currently have my dyns in a sealed kick panel enclosure. I guess I should try venting them lol. I did always wonder what they would sound like if I did. Looks like I will have two projects to work on.
Does the driver tend to play lower with a vented enclosure?
Old 06-05-2019   #4
SkizeR's Avatar
Prisoner
Apicella Auto Sound
Janitor
Learn how to use winisd and find out for yourself
