Subwoofer Ground Issue - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 07-09-2019   #1
Rep Power: 6 Sai Bhakta will become famous soon enoughSai Bhakta will become famous soon enoughSai Bhakta will become famous soon enoughSai Bhakta will become famous soon enoughSai Bhakta will become famous soon enoughSai Bhakta will become famous soon enough
Default Subwoofer Ground Issue
I puy two 12 in subs and an amp in my car. I taped speaker wires so I use high input into the amp. The signal has Left +/- and Right +/- and ground. I have my ground hooked up to a bolt in the trunk. I have tested it and this is a clean ground. Imma remote turn of wire is from a fuse tap that only turns on with ignition. When I start my car the subs play a quick thump every 5ish seconds regardless of if music is or isn’t playing. When I go to the trunk while the car is on and disconnect the ground for a few seconds then reconnect it the subs suddenly start working perfectly. I don’t know how to fix this. Please help.
Sai Bhakta is offline   Reply With Quote Quick reply to this message
Old 07-10-2019   #2
Rep Power: 193 miniSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the rough
Default Re: Subwoofer Ground Issue
read thru this and see if it helps.
How to Fix Amp / Speaker Turn On / Turn Off Pop | Car Audio Advice
2018 Crosstrek
P SIX DSP MK2 GB10 GB25 Gs690 GB10d4x2 Z-2KD II
miniSQ is offline   Reply With Quote Quick reply to this message
