Amplifier Question - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 07-10-2019   #1
Rep Power: 0 DivebombInc will become famous soon enoughDivebombInc will become famous soon enoughDivebombInc will become famous soon enoughDivebombInc will become famous soon enoughDivebombInc will become famous soon enoughDivebombInc will become famous soon enough
Default Amplifier Question
I have a 2012 Ford F-250 and my sub and passenger side speakers are the only ones working. Of course I've checked the balance and fade, didn't solve anything. I'd like to get another amplifier that will install easily. There is a sub behind the back seat, 2 rear speakers, 2 tweeters in the back doors, and 2 front speakers.
Can anyone suggest something other than OEM that I can install easily?
DivebombInc is offline   Reply With Quote Quick reply to this message
Old 07-10-2019   #2
Rep Power: 35 SlvrDragon50 will become famous soon enoughSlvrDragon50 will become famous soon enoughSlvrDragon50 will become famous soon enoughSlvrDragon50 will become famous soon enoughSlvrDragon50 will become famous soon enoughSlvrDragon50 will become famous soon enough
Default Re: Amplifier Question
You should probably figure out why the speakers aren't working because if your HU is busted and you use the HU to feed a new amp, it still won't work.
2014 Honda Accord LX - JL Audio C2-650, Kicker CSC674, Helix DSP Pro MK1, Pioneer GM-D8604, Rockford Fosgate R500X1D
SlvrDragon50 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to SlvrDragon50 For This Useful Post:
DivebombInc (07-10-2019)
Old 07-10-2019   #3
Is there a DIY way I can do that easily? Stereo's are not my specialty so any advice is greatly appreciated.
Old 07-10-2019   #4
Don't know what the easiest way is. Check the voltage at the outputs and see if they're sending anything.
Old 07-10-2019   #5
BrianSomething's Avatar
Rep Power: 19 BrianSomething will become famous soon enoughBrianSomething will become famous soon enoughBrianSomething will become famous soon enoughBrianSomething will become famous soon enoughBrianSomething will become famous soon enoughBrianSomething will become famous soon enough
Check the speaker wiring going through the boots in the door. They're known to snap right there in the F-Series causing exactly what you mentioned. If that's it, just cut/splice/rewire.
BrianSomething is offline   Reply With Quote Quick reply to this message
Old 07-10-2019   #6
Rep Power: 13 OldNewbie will become famous soon enoughOldNewbie will become famous soon enoughOldNewbie will become famous soon enoughOldNewbie will become famous soon enoughOldNewbie will become famous soon enoughOldNewbie will become famous soon enough
Swap the inputs at the sub. If the driver's side now works and the passenger's side is out, the HU, or the wiring to the amp, is at fault.
OldNewbie is offline   Reply With Quote Quick reply to this message
