Mosconi DSP help - no output - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 08-08-2019   #1
Rep Power: 91 chiefgeek will become famous soon enoughchiefgeek will become famous soon enoughchiefgeek will become famous soon enoughchiefgeek will become famous soon enoughchiefgeek will become famous soon enoughchiefgeek will become famous soon enough
Default Mosconi DSP help - no output
I am sure I am doing something totally wrong, I can't get any output signal out of mosconi 6to8 (v1 I think, using the oldest version of dsp software on site).
I have the following outputs from my kenwood connected to the DSP like this:
Front on channel 1,2
Rear on channel 3,4
Sub on 5,6
I have the mixer panel set like this
I plan to run 2-way active (1,2,3,4) ,sub (5,6), someday maybe rear fill (7,8).
I have set checked the input signal at the input of the DSP with a DD-1 and signal is clean up to max volume.
I created some crossover settings for channel 5,6 only and currently only trying to use channel 5,6.
chiefgeek is offline   Reply With Quote Quick reply to this message
Old 08-08-2019   #2
Hammer1's Avatar
Rep Power: 114 Hammer1 will become famous soon enoughHammer1 will become famous soon enoughHammer1 will become famous soon enoughHammer1 will become famous soon enoughHammer1 will become famous soon enoughHammer1 will become famous soon enough
Default Re: Mosconi DSP help - no output
If your only running one set of RCAs to inputs 1 & 2 on the 6to8 then you should should set all outputs on 1 & 2 to 100%. check to see if you have the channels muted
00 Dodge Ram Cummins Twin Turbo. IPad 9.7 Pro in the Dash. Illusion Audio C12XL C8,C5,Illusion Tweeters,Mosconi AS300.2,AS200.2, AS100.4. Mosconi 6to8 Aerospace
Hammer1 is offline   Reply With Quote Quick reply to this message
Old 08-08-2019   #3
nothing is muted. I see 8 green boxes on left bottom of screen.
Old 08-08-2019   #4
Old 08-09-2019   #5
Rep Power: 36 Petererc will become famous soon enoughPetererc will become famous soon enoughPetererc will become famous soon enoughPetererc will become famous soon enoughPetererc will become famous soon enoughPetererc will become famous soon enough
Is the laptop connected to the dsp? 6to8v8 software lower left shows status of connection in red font
Petererc is offline   Reply With Quote Quick reply to this message
Old 08-09-2019   #6
I didn't screen shot that, I just loaded my last saved settings while not connected to the DSP (car is in the shop getting DPF replaced)
Old 08-09-2019   #7
Hammer1's Avatar
Check to see if high/low level input is set correctly and have you tried adjusting input gain
Old 08-10-2019   #8
I tried both positions of the hi/lo button.
I also tried all levels of gain pot.
Old 08-10-2019   #9
probably did already but how about a reset?
Old 08-10-2019   #10
I have not tried a reset, need to figure out how to do that.
Old 08-10-2019   #11
Turn down volume or dont play any media. Connect DSP to laptop and load a blank the preset with no changes made to it. After it loads hit the reset remote control level on the software. Then load your custom preset and see if it works. Can’t remember but you may have to disconnect and reconnect the dsp to laptop to load custom preset
Old 08-11-2019   #12
Rep Power: 0 Monk47 will become famous soon enoughMonk47 will become famous soon enoughMonk47 will become famous soon enoughMonk47 will become famous soon enoughMonk47 will become famous soon enoughMonk47 will become famous soon enough
Bing has a video on You Tube about tuning a 6to8 DSP. It's called 6to8 tutorial. It helped me when I tuned me Mosconi DSP.
Monk47 is offline   Reply With Quote Quick reply to this message
