2008 civic Si DIY A pillar build scanspeak 10f Beryllium tweeter - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 08-13-2019   #1
Rep Power: 22 Thegenuinearticle will become famous soon enoughThegenuinearticle will become famous soon enoughThegenuinearticle will become famous soon enoughThegenuinearticle will become famous soon enoughThegenuinearticle will become famous soon enoughThegenuinearticle will become famous soon enough
Default 2008 civic Si DIY A pillar build scanspeak 10f Beryllium tweeter
I saw some interesting A pillar builds with these A pillars. They are deceiving in that one thinks shoving a mid into the little window in between the gap would be easy. These A pillars are a complex shape with weird convex and and concave as well as sloping inward into the interior. I wanted to do something old school with a tear drop kick panel type design but try and make it look as clean as possible. It took an unconventional approach using a combination of epoxy plastic filler for adhesion, duraglas, urethane expanding foam, body filler, foil tape for a shaping, high build primer, texture spray, spray paint ....Enjoy the build pics..
Thegenuinearticle is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Thegenuinearticle For This Useful Post:
GreatLaBroski (08-14-2019)
Old 08-13-2019   #2
Rep Power: 88 dgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enough
Default Re: 2008 civic Si DIY A pillar build scanspeak 10f Beryllium tweeter
Looks really nice. Will be nice to see the installed pictures. Did you do any testing prior to selecting the aiming?
dgage is online now   Reply With Quote Quick reply to this message
Old 08-13-2019   #3
Thanks for viewing...The aiming is pretty much the standard driver aim towards passenger/ passenger aim towards driver approach. As always there are tradeoffs and compromises. It being a relatively large baffle for given space if I had aimed more on axis then aesthetics as well as view obstruction whilst driving would have been compromised so this alignment in my opinion given a two way separate setup was the best middle ground. System will be 3 way active DexP99RS, revelator W18 in doors, 12 inch Discovery sub, Arc audio xxk4150 (old school) powering mids/tweets, Audio control ACM 4.300 bridged powering doors, and audio control LC-1.800 powering sub....Thanks again for viewing. I make home speakers as well so please check out those posts...Will post full build thread in the next few weeks.
Old 08-14-2019   #4
GreatLaBroski's Avatar
Rep Power: 35 GreatLaBroski will become famous soon enoughGreatLaBroski will become famous soon enoughGreatLaBroski will become famous soon enoughGreatLaBroski will become famous soon enoughGreatLaBroski will become famous soon enoughGreatLaBroski will become famous soon enough
Those turned out GREAT. Man, that's going to sound good.
2017 Chevy Bolt EV - Work in Progress: Scanspeak D3004/6040-10 Beryllium tweeters, Scanspeak 12mu mids, Scanspeak 18wu midbasses, Scanspeak 32w/4878T00 13" Subwoofer, Scanspeak 10F / D3004/6020's (rear doors), Scanspeak 10F (rear fill). MiniDSP C-DSP 8x12 v2 DL, Arc Audio KS 300.2 v2, Arc Audio SKS300.6 Prototype, Arc Audio KS300.4 v2
GreatLaBroski is offline   Reply With Quote Quick reply to this message
Old 08-15-2019   #5
Thank you Greatlabroski...Appreciate the kind words. They are open backed at the moment and will be beefed up internally with a couple of layers of chopped mat and resin for rigidity, then I will line the insides with modeling clay for mass and resonance taming, and last stuff a bit of virgin wool on the inside before loading the drivers for listening. I'm thinking since the back of the pillars meet up with a small window that I might just leave the backs open as the window will close it off. I can just cut a triangular piece of trunk liner to go over the window. I will see how they sound first this way and take some measurements but I can always just seal off the back later by taping it off and pouring slurry or milkshake in. Full build pics should be coming within the next two weeks but my God is it hot here in Alabama and unfortunately I dont have a nice air conditioned install bay to make short work of tearing down the interior and running all necessary cables. The simplest things in this kind of heat that normally would take 15 minutes seems like it takes 45 minutes when every 5 seconds you are wiping sweat from your face because its blinding you...Hate this time of the year...Trully..
Old 08-15-2019   #6
Rep Power: 27 Stycker will become famous soon enoughStycker will become famous soon enoughStycker will become famous soon enoughStycker will become famous soon enoughStycker will become famous soon enoughStycker will become famous soon enough
Very nice pods. You definitely have some skills. I like the texture paint, it gives them a factory look. Nice speaker choices.
Chevy Sonic: Pioneer DMH-C2550NEX, JL VX 800/8i, VX 1000/1i,Morel CCWR254 AF GB60, SS D3004, SS 12" 30w/4558T. Chevy Silverado: Factory HU, NAV-TV GM-650, JL TWK, NVX JAD 800.4, NVX JAD 1200.1, Audiofrog GS690, Morel 2.5, SS R2004, DA HO 12"(2)
Stycker is offline   Reply With Quote Quick reply to this message
Old 08-15-2019   #7
Thank you for the kind words. I've been in the game since 2000 and have had a fair share of awful projects as well...lol
Old 08-15-2019   #8
Niebur3's Avatar
High Definition Mobile Audio
Rep Power: 340 Niebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond repute
Very nice indeed.
Niebur3 is online now   Reply With Quote Quick reply to this message
Old 08-15-2019   #9
jimmydee's Avatar
Rep Power: 81 jimmydee will become famous soon enoughjimmydee will become famous soon enoughjimmydee will become famous soon enoughjimmydee will become famous soon enoughjimmydee will become famous soon enoughjimmydee will become famous soon enough
Yep, well done. Looks really good.
I can see the tweeter is a Scan Beryllium. But what is the midrange?
EDIT: Nevermind... your post title says that it's a Scan 10F. Somehow missed that.
https://i.imgur.com/6f2B75s.jpg
jimmydee is offline   Reply With Quote Quick reply to this message
Old 08-15-2019   #10
Bikinpunk
Rep Power: 26023 ErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond reputeErinH has a reputation beyond repute
Hey! Another Alabamian with a Civic Sedan and pillar build. Sweet! Where in 'bama are you?
Time Delay Calculator:
Old 08-15-2019   #11
It's the scanspeak 10f 4 ohm midrange. Pretty much a 3 inch mid...Thanks for the nice words..
Old 08-15-2019   #12
The famous ErinH...What's up? I'm in Birmingham (city without a working interstate that will never be completed). I had purchased all of this gear last year and posted somewhere around that time what my plans were for this system. I had been making home speakers and posted those builds here just because I know guys here like that stuff too. Honestly just now have had the time to get around to doing the car ststem. Some of the board members mentioned there are periodic meet and greets for us mobile audio nuts in Alabama. Would love to hang out and meet some nice folks listening to tunes...
Old 08-15-2019   #13
Bikinpunk
Good deal! Install looks good, man.
I live in Decatur so just an hour north of you.
Yea, there's actually a meet at Al's house just 20 minutes north of you in November.
https://www.diymobileaudio.com/forum...y-nov-9-a.html
And Jason is having a meet at his house in a few weeks:
https://www.diymobileaudio.com/forum...-1-2019-a.html
You should come out if you can. All of us car audio guys in this area are really good friends and we have a great time. Always looking for another sucker to pull in to our group. lol
Old 08-15-2019   #14
I definitely would love to come hang out. Sounds like a good time...
Old 08-15-2019   #15
Babs's Avatar
Rep Power: 213 Babs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the rough
Damn you Tapatalk!!
Iím dying to see these.
2008 Civic Si Sedan - Fiio X5ii SPDIF, Phone USB HEC, Helix DSP Pro-2, Helix Director, Zapco Z150.6 LX, Z400.2 LX, Acoustic Elegance SBP12 (2)
Build Log
Old 08-15-2019   #16
Babs's Avatar
Thanks for the pics! Man you did a terrific job! Those will be great Iím betting when you tune up.
Build Log
Old 08-15-2019   #17
Thank you Babs...I think once tuned up with the Dexp99rs and an omni mic setup I have they really should sound nice. Mostly composed of fiberglass reinforced filler they should be plenty rigid and I also am going to line the walls with non drying modeling clay...
Babs (08-18-2019)
Old 08-16-2019   #18
Rep Power: 7 mpm17 will become famous soon enoughmpm17 will become famous soon enoughmpm17 will become famous soon enoughmpm17 will become famous soon enoughmpm17 will become famous soon enoughmpm17 will become famous soon enough
Great work. Looking forward to more pics of the install.
mpm17 is offline   Reply With Quote Quick reply to this message
