Some horn questions. - Page 6 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 1 Week Ago   #126
Rep Power: 131 LumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura about
Default Re: Some horn questions.
Originally Posted by Jscoyne2 View Post
Dynamics are nice tho
That's why I wanted to fit horns in my Miata so badly.
1986 Bronco Build
2010 Miata Build
Old 1 Week Ago   #127
oabeieo's Avatar
FC -NCO-COL
MECP advanced certified,
Rep Power: 97 oabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enough
A Miata would be a great horn car
Sit low , dash is setup good windshield is more straight up n down
Except for that monster console.
https://youtu.be/VgU6LXY-AjI
oabeieo is online now   Reply With Quote Quick reply to this message
Old 1 Week Ago   #128
Rep Power: 93 Jscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura about
So when you guys talk about the center console in cars. Are you referring to the dash or like where the shifter is and the right console where u rest your arms. Is it better to remove that?
Old 1 Week Ago   #129
We are talking about the part that bolts to the floor. Unfortunately, in most new cars that piece and the dash are one continuous assembly, so getting rid of it isn't a solid options. In my Miata it wouldn't do much good to eliminate it because the transmission tunnel is so tall it almost meets the bottom of the dash.
Ideally you'd have a dash with a completely flat bottom edge that then tapers up to the gauge panel. There would be a big fat gap between the bottom edge of the dash and the floor pan, with no plastic bits between the seats.
Obstructions in the middle cause reflections. The taper from the bottom edge up to the panel help to extend the horn effect and get that nice transition you worked so hard for, and raise the stage up.
That's the idea behind the dash rebuild in my Bronco: (Haven't worked on the bottom edge yet)
1986 Bronco Build
2010 Miata Build
Old 1 Week Ago   #130
oabeieo's Avatar
FC -NCO-COL
Skinny car no console is the primary reason I bought the fit
Plus places to put speakers.
The big console tend to make the horns more separate sounding , like two sound sources instead of playing together as one big seem less sound field. To try to describe the reflection artifacts caused by the console.
His old ford will be so nice for horns. Has all the right items.
A big wide truck with 8s high up in the door and minihorns is one of my favorite sounds. The stage is massive and the center is super massive and pronounced.
I did horns in a older ram truck that thing had suck awesome imaging
Old 1 Week Ago   #131
I feel like my horn fires more into the middle console(front center of car) than the transmission. You can see where it hits coming out of the horn and there is a ton of steel behind that plastic.
hump
Old 6 Days Ago   #132
Stevens Audio
Founder
Rep Power: 161 Eric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the rough
The quick way to test if your console is causing and early reflection is to use large towels draped over and listen.
The strongest output angle is the centerline of the 2 axis flare section of the horn. The output at the angle of your ruler is much lower.
Eric Stevens is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Eric Stevens For This Useful Post:
oabeieo (5 Days Ago)
Old 6 Days Ago   #133
Stevens Audio
Founder
Also dont be shy , call and discuss tuning 310 869 4438
slvrtsunami (6 Days Ago)
Old 6 Days Ago   #134
Hmm
Old 6 Days Ago   #135
Rep Power: 117 Frijoles24 is on a distinguished roadFrijoles24 is on a distinguished roadFrijoles24 is on a distinguished roadFrijoles24 is on a distinguished roadFrijoles24 is on a distinguished road
no joke on that. I bought me some diaphragm replacements from him for my cd ultras, and we ended up talking for 30+ min easy! (had to break off the convo cause he told me he was headed to church and i was holding him)
gave me feedback for my fender airspaced idq15. which is now semi IB. def fixed the problem i was having.
Frijoles24 is offline   Reply With Quote Quick reply to this message
Old 6 Days Ago   #136
slvrtsunami's Avatar
Rep Power: 147 slvrtsunami will become famous soon enoughslvrtsunami will become famous soon enoughslvrtsunami will become famous soon enoughslvrtsunami will become famous soon enoughslvrtsunami will become famous soon enoughslvrtsunami will become famous soon enough
Hmm
Sorry, I really cant see a reason for ding that, the center tunnel is too high...
2014 Focus ST... Stock for now, but not for long!
slvrtsunami is offline   Reply With Quote Quick reply to this message
Old 6 Days Ago   #137
Hmmm
Old 6 Days Ago   #138
Welllll too late!
Old 5 Days Ago   #139
Do you think that dash mats might actually be a bad thing when using horns as the wave follows the contours of the dash, it hits the dash mat and kinda goes all over, instead of continuing to follow the dash curves?
Old 5 Days Ago   #140
Stevens Audio
Founder
The wave may follow thge contour but the strength at that point is very very minimal compared to the direct energy.
So yes, absolutely use a dahs mat.
Old 5 Days Ago   #141
Darn it Eric.... Another thing I have to pass by the wife!!
Old 5 Days Ago   #142
Welllll too late!
More power to you!! love to see how it turns out!
Old 5 Days Ago   #143
oabeieo's Avatar
FC -NCO-COL
hump
Your console isnít ďthatĒ big either
Have you seen a Miata or a BMW 5-Series console ....thatís massive and wide as hell.
The Camry should sound very good.
If you have full-size horns look at the flare. Not the angle of the outer wall.
Look at this home horn , see how it flares at the ends
Now look at your full size horn and look for the flare , itís circular and about 1/4th a full circle , the ends where your ruler are are to help it play low and isnít where most the energy is. If you looking at it, from the far edges and into the horn youíll see the 1/4 (ish) circle shaped flare, thatís where almost all of the sound comes from. In actually the horn is quite small where it matters.
It should start to make sense and basically looks like a rounded horn firing forwards the other side of car
Iíll try and find a pic
Edit hereís a pic ...see the flares on both horns.
The exit angle on Ericís comes strong more forward and towards you and more straight forward than completely sideways , but still is ďaimedĒ sideways if you look at it .
About where the 2nd arrow is where a lot of energy comes out. Is that general area. If your lower dash is buried it can cause some reflection, but it more the entire console instead of the far underside only. More where your right leg is.
And again the Camry console can easily be delt with. Itís not big at all.
Edit: seriously call Eric.
what do forensic anthropologists study
how do i upload images to the forum
Old 5 Days Ago   #144
Thats a layer of mlv with a ton of holes drilledin it and thin carpet on top.
Not done yet tho.
Old 5 Days Ago   #145
oabeieo's Avatar
FC -NCO-COL
Not done yet tho.
Bravo for sayin fuckit and going to town anyway but I donít think itís that necessary, but it definitely canít hurt anything
Look at the lower dash and subdash area under radio
You can seeee how low the horn is in relation and you are in no way firing it into a brick wall.
Your car should be sounding awesome...
Old 5 Days Ago   #146
The motto of this car is fuck it.
The Following User Says Thank You to Jscoyne2 For This Useful Post:
Old 5 Days Ago   #147
I like how the beginning of this thread was like..hey questions on horns... and now im like...lol
Old 5 Days Ago   #148
oabeieo's Avatar
FC -NCO-COL
YOU have to say it sounds good tho....I canít see how it wouldnít
Old 5 Days Ago   #149
The biggest part that is bumming me out is that I am too far away to listen to it!
Old 5 Days Ago   #150
Idk. I have a ton of foam showing up this week so im not gonna test it till then. Im putting in 3in wedges in the bottom half of the door and 1in wedges as a dash mat(maybe).
Mostly ima just throw foam all over the car and see if it sounds nice with dirac.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
oabeieo
To horn or not to horn? HORN!!!! corcraft HLCD 198 04-01-2017 09:31 PM
Horn or not to horn Pimpnyou204 HLCD 10 07-03-2012 01:43 PM
Who uses a Horn Subwoofer in their car? Chad, Patrick Bateman, and the PWK horn captainscarlett Technical & Advanced Car Audio Discussion 65 02-17-2012 03:13 AM
Bandpass / Tapped Horn / Horn woofers Patrick Bateman Technical & Advanced Car Audio Discussion 0 10-13-2009 01:58 AM
HORN GUYS DEADENER ON HORN BODIES oldschoolsq Fabrication, Tools & Tricks of the trade 18 09-28-2007 03:37 PM
