Some horn questions. - Page 8 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 2 Weeks Ago   #176
Rep Power: 95 Jscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura about
Default Re: Some horn questions.
Originally Posted by slvrtsunami View Post
I wonder if you realize just at what 'level' you are operating at here... true DIY. Thanks for sharing your trials and tribulations.
Are the reflections THAT bad without the dash mat?
Idk if the dash mat is helping or not I know when i was running a 3 way cone set up. Adding a dash mat just helped that fatigue or listening at high levels and it took the edge off of some frequencies. It wasnt a huge thing, but it did help.
To put it simply. I Just dont know if having absorption in the car is good or not. I wasn't really able to get a straight answer from people and research. So its something im trying to test but not really doing it in a very smart way. Too much too fast.
Il post my measurements of my tiny enclosure and just how badly it messed up the FR.
Old 2 Weeks Ago   #177
No eq, no crossovers, no dirac. Took 1in from the front of the cone. Gross. Im gonna rebuild one with alot more breathing room. See if that helps
Old 2 Weeks Ago   #178
slvrtsunami's Avatar
Rep Power: 147 slvrtsunami will become famous soon enoughslvrtsunami will become famous soon enoughslvrtsunami will become famous soon enoughslvrtsunami will become famous soon enoughslvrtsunami will become famous soon enoughslvrtsunami will become famous soon enough
What is the bandwidth of the drivers?
2014 Focus ST... Stock for now, but not for long!
slvrtsunami is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #179
Im not entirely but prob 60-2k sure.
Old 2 Weeks Ago   #180
have you considered modeling the 8's in an enclosure? It looks like they like very small sealed enclosures best. just a thought.
Old 2 Weeks Ago   #181
OK, so the drivers actually model well in a .25 sealed enclosure, I think if you can manage that, it will help with the two massive peaks.
I also find it interesting the difference between the left and right within the 2k - 3k region.
Old 2 Weeks Ago   #182
So i did an out of car measurement where i mounted the driver in the enclosure and sat it on a desk standing vertical outside. So it'd have the same IB set up behind it. Then did a nearfield measurement.
I had to adjust levels in Rew so they were similar but you can Def see its the enclosure causing the issues and not the breathing room behind it.
Red is inside and mounted in car. Nearfield.
Blue is outside of car and set up Ib.
Old 1 Week Ago   #183
fascinating, there goes my theory!!
Old 1 Week Ago   #184
Stevens Audio
Founder
Rep Power: 162 Eric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the roughEric Stevens is a jewel in the rough
Brian Mitchell was the guy from ARC Audio. We go way back.
For the midbass, I have found the lower the Q of the system (more IB) the better in everyway. Also absorbtion and difraction behind the driver is as important if not more important than difraction and absorbtion in the listening area.
Peaks and dips are the environment
Eric Stevens is offline   Reply With Quote Quick reply to this message
Old 1 Week Ago   #185
I think i may have done those measurements with my headunit eq on. Would explain some things. I need to retest. Leaving this here as a reminder to do so.
Old 1 Week Ago   #186
Behind the driver is very little sheet metal and almost a complete vent to the outside...how does one treat that.
Old 1 Week Ago   #187
Stevens Audio
Founder
Non hardening clay and high desnity fiberglass mat, if there is little surface are to reflect back not much needs to be done.
Old 1 Week Ago   #188
oabeieo's Avatar
FC -NCO-COL
MECP advanced certified,
Rep Power: 98 oabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enoughoabeieo will become famous soon enough
That is truly something worth thinking about.
Itís much more than a blanket statement. Whatís going on behind the driver? .
I like it! So much to think about and how it contributes to the end result.
I forgot about modeling clay! Yes itís brilliant it works so good.
https://youtu.be/VgU6LXY-AjI
Old 1 Week Ago   #189
So i rebuilt my right side enclosure and made it wayyy bigger because i thought maybe i was choking the driver but apparently...i was wrong. That was a lot of wasted glass but atleast i got an answer.
Blue is large enclosure. Red is smaller one. I had to guestimate level matching via rew but i think im right. The 315 and 1250k large differences i believe is due to me having my eq on the headunit for the small enclosure so u can ignore that.
Below are pics of the two different enclosures.
Old 1 Week Ago   #190
Tested.
Old 1 Week Ago   #191
So the blue line is the larger enclosure, without any EQ applied?
Old 1 Week Ago   #192
Ya
Old 1 Week Ago   #193
oabeieo's Avatar
FC -NCO-COL
Your getting good at this ****
See a year ago you had a lot of good questions now your doin it like a boss
Right on! I wish I had the time you must have to play.
The Following User Says Thank You to oabeieo For This Useful Post:
Jscoyne2 (1 Week Ago)
Old 4 Days Ago   #194
oabeieo's Avatar
FC -NCO-COL
Iíve got one of the best tunes Iíve had in awhile now.
And I think I know what I like.
I like an extremely strong center that is up high and far back and pin point clear and intelligible. Above all else that is what I like a super strong vocal that just doesnít quit or give up.
Than 2nd would be a smooth integration where no part of left or right are too strong.
I think Iíve come to the conclusion that 48db slopes are the way to go with horns
And 8s in kicks. I like how 24db and 12db play the horn down into the midrange
But if Iím completely honest with myself and listen to the music and stop thinking about trying to get the horn to go lower or be more dynamic at the end of the day 48db slopes are just better and tune better.
Weather it be a overlapping filter or a standard LR alignment, the fast attenuation makes it so much easier to get the horn and 8 to work perfectly together. They have such different dispersion and so obviously you want to pick a cross point that compliments both. Iíve found 1.4khz on full size And 1.6khz on minis to work good for me. But I know that will be different on different size and shaped dash and cars.
If your running DL try using a LR8 and on the midbass make it complimentary so it also has a LR8 on the HP side of the 8
dgage (4 Days Ago)
Old 4 Days Ago   #195
Will do
Old 3 Days Ago   #196
oabeieo's Avatar
FC -NCO-COL
Will do
Read this also
Excellent white paper
http://users.spa.aalto.fi/mak/PUB/JAES_V57_6_PG413.pdf
To horn or not to horn? HORN!!!! corcraft HLCD 198 04-01-2017 09:31 PM
Horn or not to horn Pimpnyou204 HLCD 10 07-03-2012 01:43 PM
Who uses a Horn Subwoofer in their car? Chad, Patrick Bateman, and the PWK horn captainscarlett Technical & Advanced Car Audio Discussion 65 02-17-2012 03:13 AM
Bandpass / Tapped Horn / Horn woofers Patrick Bateman Technical & Advanced Car Audio Discussion 0 10-13-2009 01:58 AM
HORN GUYS DEADENER ON HORN BODIES oldschoolsq Fabrication, Tools & Tricks of the trade 18 09-28-2007 03:37 PM
