iPhone 5 analog output measurements - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 10-18-2012   #1
Rep Power: 0 t3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to all
Post iPhone 5 analog output measurements
Did a quick Rightmark Audio Analyzer run on my iPhone 5's headphone output today. Unloaded output level (output voltage in this case) is the same as my 3GS. Here's the link to the 3GS's measurement for reference and added info.
iPhone 3GS
Below is Rightmark's summary of the results plus a modded quote for my 3GS's results.
Originally Posted by t3sn4f2 View Post
Column:
A. iPhone 3GS headphone output.
B. EMU-0404PCI 44kHz/16bit analog loopback. As a CD resolution reference. Same test conditions as the iPhone.
C. This is a perfect 44kHz/16bit test result (same as a digital SPDIF output).
D. This is a 44kHz/24bit ANALOG loopback test to show the input's maximum performance when testing a device capable of high resolution formats. IE the output from the soundcard used to do the loopback test
Looks damn good! Particularly and most noticeably the noise performance which has improved to the level of the CD format's own digital limit (ie ~-97dB).
The separation spec seems to have dropped but that could be due to the new mini jack to RCA cable I am using. Might be flaky, might not. I'll report back on that one.
But then there's this.......
Look at that spread on the base of the fundamental? WTF?! Gonna look into that one as well.
I'll can provide a file share link to an HTML file that contains the complete results, if anyone is interested.
Old 10-18-2012   #2
Rep Power: 128 glastron will become famous soon enoughglastron will become famous soon enoughglastron will become famous soon enoughglastron will become famous soon enoughglastron will become famous soon enoughglastron will become famous soon enough
Aliasing? What was the sampling frequency?
Assuming that that spike is a measurement problem, maybe this will put to rest some of the BS about Idevices having poor SQ
glastron is offline   Reply With Quote Quick reply to this message
Old 10-18-2012   #3
Default Re: iPhone 5 analog output measurements
Both the playback test file and analyzing software same rate were 44.1kHz.
The spike is normal. That is how the harmonics shows on the graph. The problem is at the base of the test 1kHz tone. It should be a thin line all the way to the noise floor in that graph's resolution.
Old 10-18-2012   #4
Rep Power: 0 BuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to behold
Very interesting. I'm getting ready to buy an iPhone and I was actually leaning toward the 4s instead of the 5 for it's smaller size. I'll be following this one.
Old 10-19-2012   #5
Hanatsu's Avatar
Rep Power: 322 Hanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond repute
Interesting indeed, even the analogue output is that good
